Question about Intel D845GLLY Motherboard
Graphics card Can we use any Graphics card in the D845GLLY motherboard
    President:
  • 2,351 Answers
Hi Harikris, no you can not install just any graphics card. You're Intel D845GLLY board uses an onboard graphics card. (It's an AGP graphics card).
If it's you're intention to install a new graphics card you must use a PCI graphics card. (Understand that the AGP onboard graphics is faster than a PCI graphics card). However, the PCI cards do use their own memory. (Which fee’s you're system memory to run windows.
The Intel D845GLLY has 4 PCI (White) slots, onboard. You can add a video card into the system. You're onboard video card does use you're system memory to function. If you're PC has 512MB of system memory & you're video card is set to use 128MB of memory. Than you're system is left to run with 128MB. One would think you're system is running a little slow.
The Intel D845GLLY motherboard can use up to 256MB of system memory. You can set the amount of system memory in the bios as shown on page 49, table 18. In you're manual. If you do not have you're manual you can download it from here: http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-008853.htm
May I suggest you increase you're system memory to 1GB. Than increase you're graphics memory to 256MB. You're system will run faster & so will you're graphics card. These older Intel motherboards require memory current for you're board. Click this link: http://www.memory-up.com/Memory/IntelD12696.html
If you still feel that you want to use the slower PCI graphics card you can choose from any listed on this link: http://www.newegg.com/product/ProductList.aspx?N=2000380048+1069609642&Submit=ENE&SubCategory=48&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-NA-_-NA-_-NA
You will also need to change a setting in you're bios to boot to the PCI card instead of the AGP onboard card. Page 49.
Good Luck!
M
Posted on Jun 07, 2008
For D845GLLY ,i tried with 512MB SDRAM(Duble side),had booting pb
make sure the ram is working fine just connect to other working system and check the ram are ok .but i m sure this is motherboard problem kindly show it service center or change the motherboard.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 17, 2010 | Intel D845GLLY Motherboard
For D845GLLY ,i tried with 512MB SDRAM(DS) had boot problem
Is the memory you have possibly PC100 and not PC133 ?
Dont have motherboard cd,m not able to find LAN Drivers on net
You have 2 choices. 1. Call Intel tech support & see if they can find a solution for you or 2. Install a standalone ethernet/wireless card, depending on your setup and disable onboard LAN. I had to go the 2nd route as my onboard LAN wass not compatible with Windows Vista. Hope this helps.
Dec 24, 2008 | Intel D845GLLY Motherboard
Audio installing
THE PROBLEM IS THE AUDIO DRIVER OF INTEL D845GLLY MOTHERBOARD FOR XP SERVICE PACK 2 NOT SUPPORTED PLEASE HELP ME FOR DOWNLOAD THIS DRIVER NOW
Oct 21, 2008 | Intel D845GLLY Motherboard
Problem in installing drivers
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=829
put your operating system in then select what drivers you need
hope it helps
Aug 12, 2008 | Intel D845GLLY Motherboard
XFX card
Sure will. All PCI (White in color slot), as the same. Age is not an issue.
Mike
Jun 09, 2008 | Intel D845GLLY Motherboard
PCI card
I like XFX cards because they carry a life time warranty. How about A PCI with 512MB DDR2 memory.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3735736&CatId=1603
Enjoy!
Mike
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
Intel Desktop Board D845GLLY
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
Intel D845GLLY Motherboard Logo
218 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
