Question about Philips Magnavox 52MF437S/37 52 in. LCD TV
Magnavox 81 cm LCD TV Model No. MLCD32
Lower 2/3rds of screen is black. Sound and top 1/3rd of screen is OK.
TV is a little over 2 years old and is now out of warranty. Performance prior to this problem was excellent.
    Problem Solver:
  • 14 Answers
No setting or troubleshooting can fix this. TV needs service. Sounds like a control board or buffer board went out.
Posted on Sep 16, 2008
Were can I get a circuit diagram of a Magnavox lcd t.v. set model mlcd32?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2014 | Televison & Video
Magnavox LCD Black Clouds on Screen
Problem can be caused by oxyde on board IC contacts, try using circuit cleaning solution.
Apr 14, 2008 | Televison & Video
Lost entire picture, sound and everything else OK
check the invertor boards resistors they power the back lights
also check for any capactors that have blown (raised tops) they look little bateries
Dec 12, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Magnavox model S1MP6100D/37 I have a large screen
there are 2 stk392-120 chips mounted to a large heat sink. both are bad, also 6.8 ohm 1/4 watt resistors are bad . need ohm meter top check these.
Nov 16, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
Magnavox 42MF231D/17, screen just turned black,
power supply or inverter board failing if the power board is the problem it will have blown caps
little cans with puffy tops because the caps have vented if you don't see that then your inverter has died that model id out of production so try shop jimmy. com
Sep 22, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
32 in. LCD Flat Screen Blank Screen
Is it under warrentee?
It sounds like the main fuse inside blew. Does the outlet work at all?
If not, reset the circuit breaker or if it is on a power strip, reset the strip trip switch.
Mastersage....................
Feb 08, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hi how are you going im
Try new/different cable, if still have problem? You have a loose connection in the unit on the connector.
Feb 23, 2008 | Televison & Video
TV will not Power Up / Blinking Green Light on Power Button
May be the same problem Magnavox is having with their 27MF231d. I found the fix on this site and it took care of the same problem with my set. Not the easiest thing to do, but it worked. If you do not know how to solder, get some help with this one. If you take it to a Magnavox Authorized repair location, they will just replace the bad capacitor with another bad capacitor of the same type and voltage. The problem is they have a 25w capacitor where a 35w capacitor should be. Mine was bulging, with black tar looking stuff coming out of it. It was obviously bad. Follw the instructions below.
1. Remove all screws around perimeter, one screw at the lower right at (Side A/V), and 2 1”round plastic knob s.
2. Remove back cover
3. At lower left side remove 2 screws for On/Off switch cut tie wrap that holds wire down for free movement.
4. Disconnect wire connector to side A/V at lower right side
5. Disconnect wire connector to right side circuit Board
6. Disconnect wire connector to left side circuit board
7. Remove the 2 mounting brackets upper left and upper right 2 screws each.
8. Remove 3 screws each side of the metal box in the middle
9. Fold back metal tape off bottom and top of metal box
10. 1 wire connector at top of box I left connected
11. Flip metal box over towards top of Tv. Be careful of wire at top thats still connected.
12. On left side in box is power supply board
13. Towards bottom of board you should see the numbers C2081 and C2074
14. Remove the six screws holding down power supply board
15. Flip board down towards bottom of Tv.
16. Unsolder capacitors replace with new 1200uf 35v and 2200uf 35v 105°C radial capacitors
17. Capacitors should be around 1/2” to 5/8” dia. X 1.25 long appox. 2 Wires come out of one end should be .030 dia.
18. Reassemble in reverse order and enjoy
Nov 26, 2007 | Philips Magnavox 52MF437S/37 52 in. LCD TV
Philips Magnavox 52MF437S/37 52 in. LCD TV Logo
402 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
