Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Freezer working but fridge is not getting cold
The freezer is working but the fridge is not fridge is not getting cold, what can i do to check
  • 1 more comment
  • keithma Aug 05, 2008
    Freezer is working but fridge not getting cold.
  • pokerlouie Sep 11, 2008
    i have the fridge at max and it does not cool that much. the fan next to the compresor is not working, please help
  • James Helmer
    James Helmer May 11, 2010
    Check your freezer section for frost buildup on the back wall. This frost in the freezer freezer section indicates a defrost system problem. When frost builds in the freezer it stops the air circulation that cools the refrigerator section.
Its a kenmore side by side 59652673200
Posted on Oct 15, 2008
  • 291 Answers
Check to make sure freezer fan blowing & fan by compressor, No blockage in supply or return vents, Look in freezer to make sure NO frost is coming thought indicating defrost problem
Posted on Jun 10, 2008
3 Suggested Answers
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
SOURCE: Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Posted on Oct 09, 2008
Fridge Freezer not cold
Is there a fan inside the freezer compartment to direct cold air to the fridge? Check it's working. If not fanned, check rear wall of fridge. If not cold, unit may be short of gas.
Apr 20, 2014 | Refrigerators
The fridge is not working, not getting cold but all lights are working. The freezer is working fine. Fridge just getting not getting cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 17, 2011 | Fisher and Paykel E522BRXUSS Stainless...
I have an iced diamond fridge freezer. Turned off unit to defrost freezer. When I turned back on freezer works but fridge never got cold again.
check t ensure that the fan inside the freezer is working properly if the fan is not working inside the freezer then your refridge willnot get cold also if you pull off the back panel inside the freezer you wil see the holes that the air pushes through to go into the fridge section make sure these holes are not blocked if they are your fridge will also not get cold hope this helps if you need a new fan motor for the freezer try marcone appliance uyou can find them online and they directly mail to your door
Jul 13, 2010 | Hotpoint Refrigerators
I defrosted the freezer last week and the fridge will not get cold the light in the fridge is working and so is the freezer.
There is nothing that work in the fridge it is just a box everything comes from the freezer. Check if the fan is running this is how the fridge gets its cold air. Check your freezer setting in your fridge. make sure it says warmer fridge. it a door that opens and closes.
Jun 06, 2010 | Refrigerators
Freezer works, but fridge doesn't
try checking the fan in the freezer at the top which pushes the coldness over to the freezer
Jul 08, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Fridge won't get cold
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
Apr 28, 2009 | Refrigerators
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
576 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
