Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Hotpoint Superba side by side 2169955 water dripping out of dispenser
The ice-maker works as long as I keep it clear, but the water dispenser in the door will not stop dripping steadily unless we cut off the water supply to the fridge completely. We did this a few months ago only to come home yesterday to find it dripping again. My husband tightened the valve at the back yet again, but we are both wondering how long this will hold.
Perhaps a valve or a gasket needs replacing, but we don't even know how to get to the innards to do this. We (my husband and I) are complete newbies to home repair. We don't know how to get into the door dispenser guts or anything. This fridge came with our home and we can't find any manuals or anything on it.
Can it be repaired? Should we just disconnect it from the water supply altogether? The freezer and refrigerator both work just fine minus the luxury of supplying ice and cold water, so adding this fridge to a landfill for my own convenience would just be wasteful. It would be nice if we could get the water and ice going again.
Thanks for your help.
    Sergeant:
  • 409 Answers
sounds like you may have something broken on the icemaker case itself.
if the water is leaking down the front, it could be the front casing.
if the water is leaking inside the door, it's something a bit bigger.
i would recommend a technician to come and take a look.
Posted on Sep 17, 2008
Ice maker isw not producing any ice. Water filter is ok.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
Feb 04, 2011 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
My ice maker is not getting water. The water despenser is o.k.---I did remove the water filter.
A strainer before the inlet valve can also get stopped up restricting flow.
Nov 28, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker will not work. Water is coming into the back of the refrigerator and water dispenses out of water dispenser. But no water will go to the ice maker.
Try swapping the wires on the dual water inlet valve. It’s on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 23, 2010 | Maytag MSD2651 HE Side by Side...
Water dispenser is dripping water when not in use. how do i stop it from dripping
replace the water valve its not shuting off completly . things do go bad . this is a dual valve and controls both foutain and ice maker .. mm
Aug 18, 2010 | KitchenAid Superba Architect KSCS25INSS...
No Ice
put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Apr 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker is not getting water, water dispenser is. there is notheing frozen but the line leading to the ice maker doesn't have any water in it
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 30, 2009 | Frigidaire FRS26R4A Side by Side...
Water dispenser leaks, ice maker won't make ice. Hve disconnected line at bottom front, and tried blowing out the lines, no help. Model EDQ22DQFNX00
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line.
Jul 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Our KitchenAid just started leaking. it is coming from the front ice dispenser on door. seems many people are having this problem. there is also "snow" on ice maker and bucket. and the temperature...
The excess frost on the ice maker and bucket can be caused by the ice chute door not closing all the way or a leaky door gasket letting air in.
Jul 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice maker does not work on my Hotpoint sise by side. the water dispenser works, i've replaced the filter, the green light is on, but nothing happens with the icemaker, no running water sound, no ice
Jul 01, 2009 | Hotpoint HSS25GFP Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
145 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
