Question about Sirius Starmate ST2 Satellite Radio Receiver
No antenna detected
Wire that incerts into antenna wire broke off any way to repair radio
The wire is soldered to the board after going through the white insulation inside the connector barrel. After opening the unit, place the solder iron in the hole provided where the barrel is attached to the board. Push the broken piece out using a piece of 18AWG bare solid wire. This is a little tricky... make sure you don't damage other components on the board while pushing the old piece out. Then use the same 18AWG wire for the repair. Push it though from the outside of the barrel. Use the small lower opening to get the solder in place. Leave some space to move it back further when you solder into place. Then cut the wire flush with the outside of the barrel. Warm the solder again, and pushed the wire back in a little so it is recessed in the barrel. Let the solder get hard, and that's it... Works perfect. Should take 5-10 minutes.
Posted on Aug 24, 2008
2002 Chrysler Town & Country antenna installation
Did the antenna break off in the mount or did the mount break.If antenna broke off in mount I would try drilling and tapping it.If you need a whole mount.Remove plug from back of radio attach good mechanics wire to it undo outer mount when you pull the wire out of the car the mechanics wire will follow afer you get it out put the mechanics wire on the new one tape over the wire to make it a smooth transition and pull mechanics wire inside the vehicle to reroute the antenna wire back to the radio.Be carefull you shouldnt have to pull super hard
Jun 04, 2012 | 2002 Chrysler Town & Country
The antenna on my ICF-SW7600gr broke off. I want to solder on a new wire lead. should i only connect to the top solder point, or to all three where the old antenna plate rested?
There is only one antenna connection. That is the wire or pin in the middle of the coax connector where the old antenna was connected. Hook that to your new antenna, the other connectors are usually at ground potential and won't help a bit. Often a piece of wire the same length as the old antenna will work fine. Stretch it in the vertical position as was the old antenna.
Jun 23, 2010 | Sony ICF-SW7600 AM/FM/SW Radio
Antenna not detected what could this be
Usually the antenna is not plugged-in all the way, or you have broken the little tiny antenna wire. Try another location first, then try another antenna.
Jun 14, 2010 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
The coaxial cable antenna broke on my RCA tv
The part is called a Female Belling-Lee Socket. Radio Shack, or anywhere that sells antennas, CB radios, repairs TV sets, should have one. Soldering it in, is another matter. Be careful.
Feb 04, 2010 | RCA Scenium D40W20 40" Rear Projection...
The antenna base on my Maxon HCB-10C CB Radio got pulled out. Can I fix this?
Not sure what you mean here...
If the antenna is broke, then you should just get a new antenna. If the antenna connector was pulled out of the radio, it is usually fixable.
If the connector is broke off the antenna, it may may be fixable, I would have to see it. If its done wrong, you could hurt the transmit section of the radio.
You should just get a new antenna.
Sep 25, 2009 | Maxon HCB-10C CB Radio
Can not hear no body but can hear weater chanell.
Make sure your wire going from the radio to the antenna is not pinched or broke or split any where.If all your wires are good then you antenna is just not high enough to pick up signal.
Apr 01, 2009 | Cobra 29 WX NW ST 40-Channels Base CB...
Antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
No antenna detected
More than likely, it is the antenna. Sad to say, but the Sirius antennas go bad very easily. Make sure there is no undue pressure on the antenna wire itself, as that can aide to premature failure. Bad antennas are the number one reason for the unit to read 'antenna not detected.' I have seen plenty of the antennas go bad and they were not misused one bit. If you contact Sirius, they're usually pretty good at understanding the misfortune of losing your paid service. Sometimes they'll ship you out a new antenna.
May 11, 2008 | Xact Communication XTR1 SIRIUS Radio...
Antenna not conecting to radio
I would take it to radio shack. Reason is that you can beat your self up over no signal and sit there and waste time on trying to think I fixed it ALMOST! In fact that is not the solution. Is your antenna catching as it is incerting into the femle connection...slightly snapping in or not? Is it falling out? Either way you may have radio shack test this part for you.
Dec 02, 2007 | Sirius Satellite Radio Receiver
Sirius Starmate ST2 Satellite Radio Receiver Logo
295 people viewed this question
Top Sirius Audio Players & Recorders Experts
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
