Question about AOpen AX4BS (91.32Q10.002) Motherboard
Bios password loocked my sys
Sir,
locked my bios in Bios pass word I remove the battery and connect. But that complaint not clear... sir, what's next idia pls tell and help me ?
    Genius:
  • 1,027 Answers
Ftp site for manuals
c= chinese
e= english
g= german
j= japanese
s= spanish
This will clear the bios.
Posted on Jun 04, 2008
    Guru:
  • 1,342 Answers
Make sure you leave the battery out for up to 30 minutes to clear the bios.
More tips and tricks
Toshiba satellite pro u400-130 bios password
  • The CMOS is, in basic terms, the part of the motherboard that stores the BIOS settings. To remove the BIOS password from your Toshiba laptop, your best option is to forcibly clear the CMOS.
    To clear the CMOS, you must remove the battery from your laptop and leave it out for at least 30 minutes to an hour. The way to remove the battery from your Toshiba will largely depend on the model. A common way to remove the battery--particularly with newer models--is to release the battery lock on the bottom of the laptop, while sliding the accompanying tab over to the side. This will pop the battery out from its tray so that you can then pull it out all of the way out.
    Before you remove the battery, turn off the laptop and remove the AC adapter. Otherwise, you could end up harming yourself or the laptop components. You must also ground yourself to prevent damaging the laptop with static electricity.
    After about a half an hour or more, return the battery back to its tray and lock it into place. Power on the laptop. The computericon1.png, ideally, should no longer ask you for a BIOS password.
    It's important to keep in mind that resetting the CMOS means that all of your BIOS settings will be reset to factory default. Also, sometimes you may need to leave out the battery for much longer than an hour to reset the password.
  • If resetting the CMOS doesn't work, then your next bet is to try using a backdoor password. A backdoor password is basically a password that manufacturers include with the BIOS so that technicians can access the computersicon1.png that people send in for repair. An example of a Toshiba backdoor password is, unsurprisingly, "Toshiba." When the BIOS prompts you to enter a password, entering "Toshiba" may allow you to access your PC and clear the old BIOS password. Another option is to hold the left "Shift" key down while booting.
Jan 26, 2013 | Toshiba Satellite Computers & Internet
I forgot my bios password. Need help!
Hello sir, hi, most laptop and desktop computers BIOS is powered by a cmos battery, removing this battery and power on the unit will clear the cmos momentarily. including no password. BUT removing the battery needs dissassembly of the laptop. Some laptops the battery is under the keyboard, if this is not your options try google and search removal bios password.
Oct 27, 2010 | Sony VAIO VGN-FZ470E/B Laptop
My laptop is asking for PhoenixBIOS Setup Utility password. Can you please help me out with da password?
tRY THIS LIST AND OTHER ALTERNATIVES THAT FOLLOW...GOOD LUCK
WARNING: Some BIOS configurations will lock you out of the system completely if you type in an incorrect password more than 3 times. Read your manufacturers documentation for the BIOS setting before you begin typing in passwords.
Award BIOS backdoor passwords:ALFAROME BIOSTAR KDD ZAAADA
ALLy CONCAT Lkwpeter ZBAAACA
aLLy CONDO LKWPETER ZJAAADC
aLLY Condo PINT 01322222
ALLY d8on pint 589589
aPAf djonet SER 589721
_award HLT SKY_FOX 595595
AWARD_SW J64 SYXZ 598598
AWARD?SW J256 syxz
AWARD SW J262 shift + syxz
AWARD PW j332 TTPTHA
AWKWARD j322
awkward
AMI BIOS Backdoor Passwords:AMI BIOS PASSWORD HEWITT RAND
AMI?SW AMI_SW LKWPETER CONDO
Phoenix BIOS Backdoor Passwords:phoenix PHOENIX CMOS BIOS
Misc. Common PasswordsALFAROME BIOSTAR biostar biosstar
CMOS cmos LKWPETER lkwpeter
setup SETUP Syxz Wodj
Other BIOS Passwords by ManufacturerManufacturer Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
Toshiba BIOS
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
IBM Aptiva BIOS
Press both mouse buttons repeatedly during the boot
Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop.
Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time.
Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system.
ALSO, HIREN'S BOOT CD HAS SOME BIOS PASSWORD CRACKERS ON IT IF THIS DOESN'T WORK.
Oct 21, 2010 | Toshiba Computers & Internet
How do I change pass word in bios setting?
hi
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it.
May 25, 2010 | IBM Computers & Internet
PASS BIOS ACER 2930 ASPIRE
Hi the only possible way to reset the password in the BIOS is to reset the CMOS battery. It is located in one of the panel below the sys (you must have proper expertise to do this) towards the right hand side. The battery is set on a jumper You first need to disconnect all power source i.e adaptor and battery. than remove the panels to try and locate the CMOS Battery. Remember not to tuch anything else or connect any of the cables any where else it may cause a problem for the sys and you. Once the CMOS battery is reset the BIOS password will have gone.
All the best
Feb 09, 2010 | Acer Aspire 2930-4661 Notebook
How can i reset my bios password for an acer aspire laptop?
IF YOU KNOW THE BIOS PASSWORD YOU CAN GO TO BIOS AND CLICK ON CHANGE PASSWORD AND IF YOU FORGOT THE BIOS PASSWORD YOU NEED TO OPEN THE SYS. AND ON MOTHERBOARD THEIR IS A SMALL JUMPER THAT SAYS BIOS JUMPER ON IT YOU NEED TO REMOVE IT AND PUT IT IN PRONK 2 &3 AND RESTART THE SYS. AND THEN AGIN TURN OFF THE SYS. AND PUT THE JUMPER BACK TO PRONK 1 & 2 AS IT WAS EARLIER. AND IT WILL REMOVE THE BIOS PASSWORD.
Oct 25, 2009 | Acer TravelMate 2300 Notebook
Cant remove my bios password on my IBM Thinkpad A21m
Dear Sir,
Getting around the Laptop BIOS password is tricker then the desktop...I don't know if your system would go passed POST or not...in either case, there are few software out there that would allow you to clear the bios.....but you need to do some reading first...
Check out this site: http://www.i-hacked.com/content/view/36/68/ search for this section "Password cracking software" , you will find four software which may help you out (please note that you have to be registered user in order to download the software.
Enjoy..
Sep 19, 2009 | IBM ThinkPad A21m 2628 Notebook
How to remove cmos/bios password ?
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Aug 23, 2009 | HP (350030-001) for Compaq dc7100...
Where is Cmos Clear jumper on motherboard to clear Bios password.
If you can't find the jumper, just remove the CMOS battery wait for 1/2 + hour and the re-insert the battery. This will reset the BIOS back to the default settings and you then need to set the Time & Date.
It may not remove the BIOS password if the laptop stores the password on an EEPROM chip.
Apr 16, 2009 | Acer Computers & Internet
Forget my bios password
on the underside you can take off a panel with a screw driver by unscrewing the philips head screw, and from there, you should find a small, flat, round looking battery, it may be in a yellow or black coating. you have to disconnect this, and then reconnect it. this will reset your bios.
Jan 06, 2008 | Acer Aspire 5100 Notebook
AOpen AX4BS (91.32Q10.002) Motherboard Logo
98 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
