Question about Sony Ericsson Walkman W810i Cellular Phone
Nokia 8600d luna
Downloaded sims city from 02 wap and since then my phone keeps restarting all the time. what can i do
    Brigadier General:
  • 7,752 Answers
Delete the game that you install on to the phone.....if it was working fine before you downloaded the sim city and starting restarting after you installed it then it is the game you downloaded.
Posted on Jun 14, 2008
Nokia 5610d-1 light problam lcd
nokia 5610d-1 light problam so crt digram indicat
Feb 29, 2012 | Nokia (BP-5M) 5610/ 5700/ 6110/ 6290/...
Tip
SAMSUNG TIPS 2
Samsung Secret Codes Part 2
#*4773# Incremental Redundancy
#*7785# Reset wakeup & RTK timer cariables/variables
#*7200# Tone Generator Mute
#*3888# BLUETOOTH Test mode
#*7828# Task screen
#*#8377466# S/W Version & H/W Version
#*2562# Restarts Phone
#*2565# No Blocking? General Defense.
#*3353# General Defense, Code Erased.
#*3837# Phone Hangs on White screen.
#*3849# Restarts Phone
#*7337# Restarts Phone (Resets Wap Settings)
#*2886# AutoAnswer ON/OFF
#*7288# GPRS Detached/Attached
#*7287# GPRS Attached
#*7666# White Screen
#*7693# Sleep Deactivate/Activate
#*2286# Databattery
#*2527# GPRS switching set to (Class 4, 8, 9, 10)
#*2679# Copycat feature Activa/Deactivate
#*3940# External looptest 9600 bps
#*4263# Handsfree mode Activate/Deactivate
#*2558# Time ON
#*3941# External looptest 115200 bps
#*5176# L1 Sleep
#*7462# SIM Phase
#*7983# Voltage/Freq
#*7986# Voltage
#*8466# Old Time
#*2255# Call Failed
#*5376# DELETE ALL SMS!!!!
#*6837# Official Software Version: (0003000016000702)
#*2337# Permanent Registration Beep
#*2474# Charging Duration
#*2834# Audio Path (Handsfree)
#*3270# DCS Support Activate/Deactivate
#*3282# Data Activate/Deactivate
#*3476# EGSM Activate/Deactivate
#*3676# FORMAT FLASH VOLUME!!!
#*4760# GSM Activate/Deactivate
#*4864# White Screen
#*7326# Accessory
#*7683# Sleep variable
#*3797# Blinks 3D030300 in RED
#*7372# Resetting the time to DPB variables
#*3273# EGPRS multislot (Class 4, 8, 9, 10)
#*7722# RLC bitmap compression Activate/Deactivate
#*2351# Blinks 1347E201 in RED
#*2775# Switch to 2 inner speaker
#*7878# FirstStartup (0=NO, 1=YES)
#*3838# Blinks 3D030300 in RED
#*2077# GPRS Switch
#*2027# GPRS Switch
#*0227# GPRS Switch
#*0277# GPRS Switch
#*22671# AMR REC START
#*22672# Stop AMR REC (File name: /a/multimedia/sounds/voice list/ENGMODE.amr)
#*22673# Pause REC
#*22674# Resume REC
#*22675# AMR Playback
#*22676# AMR Stop Play
#*22677# Pause Play
#*22678# Resume Play
#*77261# PCM Rec Req
#*77262# Stop PCM Rec
#*77263# PCM Playback
#*77264# PCM Stop Play
#*22679# AMR Get Time
*#8999*364# Watchdog ON/OFF
*#8999*427# WATCHDOG signal route setup
*2767*3855# = Full Reset (Caution every stored data will be deleted.)
*2767*2878# = Custom Reset
*2767*927# = Wap Reset
*2767*226372# = Camera Reset (deletes photos)
*2767*688# Reset Mobile TV
#7263867# = RAM Dump (On or Off)
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*#7465625# = Check the phone lock status
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
Type *#9998*627837793# Go to the 'my parameters' and there you will find new menu where you can unlock phone.(not tested-for samsung C100)
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600)
If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Airtel Secret Codes
Dial *123# to see your credit balance. Dial *110# and follow the options.
Dial *109*9898631902# to display the call cost after each call.
on Sep 27, 2010 | Cell Phones
I have downloaded facebook on my lg kp 265 phone but i cant play it says i must check my wap settings and i did but still i cant play
1.Firstly check your network weather you sim is internet active or deactivated.
2.Delete all the setting and clear it.
3.Get the new setting and save them and make it default.
4. check the wap setting weather setting have saved.
Then restart your handset.
Aug 19, 2011 | Cell Phones
I bought a sciphone from china its unlocked but cant get settings for internet on o2.the phone model is i68 4g quadband cellphone dual sim.
There are the settings. They are the same for MMS as for WAP. I hope this helps and I have given you some help below on setting this up for O2. Thanks.
APN wap.02.co.uk
USER o2wap
PASSWORD password
HOMEPAGE http://wap.02.co.uk
PROXY 193.113.200.195
PORT 9201
APN wap.02.co.uk
USER o2wap
PASSWORD password
PORT 9201
1- Main Menu click on Entertainment then click on Services
2- Click on Data Account-> click on GPRS
3- Choose any account-> click on Edit
4- 1- Account Name
O2
2- APN
wap.02.co.uk
3- User Name
o2wap
4- password
password
5- Auth. Type
Normal
CLICK ON DONE AND SAVE IT
CLICK ON BACK TWICE IT WILL TAKE YOU BACK TO SERVICES
CLICK DONE AND SAVE IT->CLICK ACTIVATE PROFILE AND SAVE
Oct 06, 2010 | Computers & Internet
Master reset after i download a theme
Try Other Downloading way.. example: U were using WAP for downloading files use now ur Pc to download files for ur Phone iwth a Phone-Pc Cable CHEERS
May 18, 2009 | Nokia 8600 Luna Cellular Phone
Problem of hanging & many more...
your cell phone is infected with virus you want to HARD FORMAT, switch off your mobile phone 1st, then press and hold 3 keys at a time star key, green dial key, and no. 3 key. then switch on your phone.
do not unhold all three key's until nokia's logo come's [hand shake] . it's done. you have to select your city. mean's your phone is virus free now.
[get backup of your contacts and messeges before formatting or you will lose your data]
Apr 17, 2009 | Nokia N72 Cellular Phone
Nokia luna
This is also happened to me and it was because i had water in the phone and it was just playing up. I seperated battery and sim card and left to dry and it did work after. Try a different sim i also tried that and it did work instantly. If you live in birmingham active phones on walford rd the place to go.
Jan 08, 2009 | Nokia 8600 Luna Cellular Phone
Sony Ericsson Walkman W810i Cellular Phone Logo
379 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
