Question about Lexmark Office Equipment & Supplies
Every time I switch on it prints out 10 copies..I alter it to one and it prints what I ask, the next print it does the ten copies Please help!! pensioner can't waste the paper!!aLL IN ONE P6250
    Master:
  • 638 Answers
When u alter it to one just click apply button to fix ur setting permanently for future.
Posted on Jun 04, 2008
My MX882 keeps feeding from back tray. How do I get it to print from front tray ?
Press the MENU button, select TOOLS or SETUP, select DEVICE SETTINGS, then plain paper feed settings and alter the settings to suit. This can also be performed from the computer from the printers and faxes folder (or devices in Win8). Open the printer window, click "Printer" then printer preferences and select paper source.
Feb 22, 2015 | Canon Pixma Mx882 Mx 882 Photo All-in-one...
Write a program to print" Readmore" for ten times.
The following RPL program will put ten copies of the string onto the stack:
<< 1 10 START "Readmore" NEXT >>
Nov 17, 2013 | Computers & Internet
On the Ip4300 the yellow light flashes at 10 times intervals. The printer does not responde to anything. Thanks Dave
This is from Canon's web site...
Ten flashes:The Cassette is not installed properly/Cannot perform duplex printing
  • When loading from the Cassette, install the Cassette properly and press the RESUME/CANCEL button.
  • When performing automatic duplex printing, the size of paper may not be compatible with automatic duplex printing. The sizes of media suitable for auto duplex printing are A3, Regal, 11" x 17" (Tabloid), B4, A4, Letter, 10" x 12", 8" x 10", B5, and A5". Make sure that the size of the paper loaded in the printer is correct. Pressing the RESUME/CANCEL button will eject the paper and restart printing from the front side of the next paper. The reverse side of the ejected sheet will not be printed.
May 04, 2011 | Canon PIXMA iP4300 InkJet Photo Printer
Problem with Canon Pixma 4300 inkjet. Orange alarm lamp flashes 10 times on switching printer on. Have tried plugging and unplugging power cord, and checked that there is no paper jam. Please help. Brian
Hello Brian,
I found the following on Canon's website.
Not sure if it will fix your issue but thought it might be worth a try:
Best of luck
Regards
Mar 02, 2011 | Canon Office Equipment & Supplies
Our 1320c prints 3 copies only,Any thoughts why?
Check the paper format of the program and the paper format of the printer.
If there is a mismatch only 3 pages come out.
Solution: the paper size should be matched other wise the printer gets confused.
Best regards,
Walter Spierings
Nov 14, 2009 | Dell 1320c Laser Printer
Bizhub 250 slow to print files
When you ask to print the page are you asking for more the one copy? If you are there is a collate check button next to the requested sets box, in the print dialog box. Make sure its not check. Collating the print means your PC sends a copy of the file for each requested copy. IE: you print one page and ask for six copies, your PC sends the file six times, one copy of the file for each print requested.
Also because your printing from a windows application IE: Excel you should be using the PCL print driver as apposed to a PostScript print driver. The time it takes to convert the file into PostScript for the printer to process it is time consuming.
May 08, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Epson stylus cx7400 wont print but one copy at a time
Epson Stylus S20, when I alter number of copies required from 1 to say, 8, it prints only ONE. Why? wgaynair@gmail.com
Jan 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Will not print multiple collated two sided publications without individually sending each job
I would try changing the driver you are using. There are multiple drivers and it really sounds like that will resolve your problem.
For the drivers go to Xerox.com.
on the tool bar select Support and Drivers.
Then enter your printer number, being phaser enter phaser 7300 in the search .
Select your operating system and there will be PS and PCL drivers.
I am 99.9 percent sure the issue is in the driver.
Dec 26, 2007 | Xerox Phaser 7300DN Laser Printer
Printer
Have you defragged and scandisked lately?
Are you doing anything while printing.
printing takes a lot of resources. you may also want to buy more ram.
Nov 16, 2007 | HP DeskJet 940c InkJet Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
    1. Turn on the HP PSC 1200 or 1300 series product.
    2. Disconnect the USB cable from the all-in-one.
    3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
      1. Press and hold Cancel .
      2. While holding Cancel , press On .
      3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
      4. Press Cancel again.
      5. Press Copies .
      6. Press Paper Type .
      7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
    4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
    5. Reconnect the USB cable.
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
24 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
