Question about RCA HDLP50W151 50" Rear Projection HDTV
Hd50lpw175x7 Good Morning, I purchase the power board. Hey how do i remove the power board? J
  • RCA Master
  • 8,617 Answers
It should either be secured with screws or plastic clips that need to be pressed in to release the board
Posted on Jun 04, 2008
Hey guys, my caravan started this morning then shut off and won't start again. Heres what I did so far checked fuel pump fuse good, fuel pump relay good swapped with other. Removed neg battery cab
If you have voltage at the fuse and relay, and at the pump, but no fuel pressure, I would say the pump has died or the tank is empty.
Have you checked for voltage at the pump yet ?
Jul 24, 2012 | 2005 Dodge Grand Caravan
When copier turned on this morning, alternating with the Ready signal, it said Replace Photoconductor. What does this mean?
Hey!
The photo conductor is your machines drum unit!!Its easy to replace and should be available for purchase at your nearest dealer!!
Good Luck!
Feb 10, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
Can I purchase a power board for 32
A power supply board can be found at a good price at Shopjimmy.com or Ebay. Make sure the board number matches up. Normally, the numbers can be found on the corners.
Dec 30, 2009 | Westinghouse SK-32H240S Television
Hey anyone there? I have a WS-55513 with a
There are 4 capacitors on the dm board that cause this problem if they are not puffed up, however the dm board will need to be replaced.
Dec 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
POWER SUPPLY
Replace bad capacitors or hire a tech to do the job.....
Sorry,most power boards are not available......T.
Dec 21, 2008 | Akai LCT2716 27 in. LCD Television
MITSU 65513 BLINKING GREEN LIGHT WONT POWER UP
Good Day, xbossux;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 09, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Hd50lpw175x7
Ballast Verification Process
1. Short out door switch (SP001)
2. Apply AC power and wait till DM module boots
3. Press power switch and observe spark gap on ballast
4. If spark gap arcs, suspect Lamp. If color wheel starts but ballast won’t strike
lamp, go to next step.
5. Measure BP252 on AC IN CBA for +300Vdc. If missing check door switch, cable
from AC IN CBA to switch and AC IN PCB. If correct go to next step.
6. Monitor pin 2 of BT251 for Ballast ON command from Light Engine. If present
suspect Ballast. If missing suspect Light Engine. Pin 5 of BT251 starts at 3.3V
after power switch is pressed and drops to .18V when the Light Engine sends the
start command. No change on pin 5 indicates Light Engine is suspect, change
on pin 5 with no ballast start, ballast is suspect.
Note: Lamp may arc but not start. Pin 5 of BT251 is "LAMP LIT" and goes to 1.48V
when lamp is lit. If ballast strikes lamp but lamp won’t stay lit, suspect Lamp.
Jun 09, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Hd50lpw175x7
The capacitors are solderd into the circuit board so you have to melt the solder with a solder Iron to remove the legs of the capacitors from the circuit. Then you have to install the new capacitors in the same pin holes and resolder the legs. Be sure that the negative side of the capacitor goes back in the correct hole like the old one was.
May 30, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Hd50lpw175x7
The power supply is what provides all the standbye voltages that get routed to the various other boards. The capacitors have to be unsolderd and the replacements solderd in.
May 29, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
