Question about Motorola Mobility RAZR V3i Cellular Phone
Cannot connect my moto to MiDlets manager
I want to set new theme i download ctheme1.1 but the MIDlets Manager doesn't read my mobile phone
    Brigadier General:
  • 7,752 Answers
Go to www.motodev.com and download the USB driver for the pc
Posted on Jun 06, 2008
How to set new downloaded theams
move all the themes downloaded from pc to themes folder of phone...then in ur mobile go to file manager ...in that open themes folder...select particular theme then set it....the new theme will get set....
May 26, 2010 | Sony Ericsson F305 White +512MB Unlocked...
Tip
Samsung Secret Codes
Tips & Tricks For Samsung :: You can try these in case you downloaded corrupted or incompatible Java midlets or other media, which are causing problems with the phone.
*2767*JAVA# Java Reset and (Deletes all Java Midlets)
*2767*MEDIA# Reset Media (Deletes All Sounds and Pics)
*2767*WAP# Wap Reset
*2767*CUST# Reset Custom EEPR0M
*2767*FULL# Reset Full EEPR0M (Caution)
For example : *2767*JAVA# would be keyed in as *2767*5282#
Note : Not all codes will work with SGH-C100.
on Jan 09, 2008 | Samsung SYNC SGH-A707 Cellular Phone
How can i install .jar file in my v3i cellular phone?plz answer me
to install java application jad or jar file to your motorola RAZRV3i go to http://www.modmymobile.com and download MOtorola Midlets Manager v0.62.1YE.this software is It have abilities to:
1. Install Java applications with JAD or JAR only
2. Manage the permissions of the applications
3. Removes java applications
4. Renames java applications
5. Save midlets both in trans flash and phone
6. Manages java settings in seem 0032_0001
7. Adapts games from other phones for Motorola
8. Move applications from phone to flash memory and vice versa
9. Ability to attach application to one of the base phone keys
Apr 02, 2010 | Motorola Mobility RAZR V3i Cellular Phone
How to reset the Samsung Sway?
Input *2767*3855#
Hope this helps and good luck!
-KC GTO Dad
Sep 18, 2009 | Televison & Video
Cannot install java on samsung i640
Im very sorry Dude
  • It is NOT officially possible to install java MIDlets on samsung handsets (excluding smartphones) via bluetooth, IrDa, USB cable or serial cable. MIDlets can only be downloaded by Over-The-Air (OTA) via a download server
  • There is currently no method for installing MIDlets on other platforms other than by OTA/GPRS via a download server.
BUT THERE ARE SOME UNOFFICIAL METHOD PLEASE TRY THIS BUT RISK IS WITH U.
Install JAVA games on your Samsung via a USB cable, BT or even an IR port
The method here is rather straightforward. It has been tested on my two D500 phones without a single problem biggrin.gif
1. Download and install Softick PPP from here. The software is designed for Palm users, so if you receive any error messages such as unable to locate USBPORT.dll, just ignore them.
2. Active your IR connection or hook your USB cable into the phone.
For IR users, you need to active the IR connection on both of your laptop and D500, and approach the laptop with your D500 to let it find the phone prior to any transferring.
For USB connection, the one I tested is from fonefunshop
3. Start Softick PPP, and check if it has your connection in its 'Settings->Bluetooth/Serial'. Active it if done.
4. Run 'Uploader.exe' program and add a jad file.
5. Enable Serial Java download - #*536963#.
6. Enter Serial Java menu #*5737425#, and choose USB from "1 PPP UP'. Please bear in mind, just do it once for each switch on/off!
Select second option - "2.Serial Download"
7. Let upload and softick PPP access the net if you installed a firewall.
-More details--------------------------------------------------------
If you are using a USB cable, please take the following steps:
1. deactive Softick PPP, and exit it.
2. connect the cable,
3. run Samsung's PIM & File Manager to make sure that you get connected. If not, please switch off and on your mobile and try it again.
4. run Softick PPP
5. go to it's 'Settings->Bluetooth/Serial' to check if it has a connection such as COM7 Devicess_mdm0. If so, select it, otherwise exit the Softick PPP and go back to the first step. (you may find the proper COM setting from the windows device manager->modems->Samsung Mobile USB modem)
6. active Softick PPP.
7. run Uploader.exe
8. ......
For IR users,
2. active your IR connection。
3. approach your phone to the laptop, and make sure there displays an icon in your tray area and it gives a message 'there is a device around....'
4. run Samsung's PIM & File Manager to make sure that you get connected via IR. If not, please switch off and on your mobile and try it again.
5. run Softick PPP.
6. enable IRDA interface support in 'Settings->Options'
7. go to it's 'Settings->Bluetooth/Serial' to check if it includes a connection such as 'COM4 Device
Jun 26, 2009 | Samsung SGH-i640 Cellular Phone
I installed some Java Midlets (.jar)on my HTC Touch (WM 6)having intent java midlet manager preinstalled. Now I want to uninstall the Midlets only.
1. Using the FileManager goto Application Data\Tao\intent\app\jam\midlets
2. Here u can see the installed Midlets in their seperate folders.
3. Delete the folder (and the files inside it) of the Midlet u want to uninstall
4. repeat step 3 for all the Midlets u wish to remove/uninstall
5. close FileManager
6. open MidletManager, u can see different icons for the Midlets u have removed. click on one of those icon and Intent will update its database.
7. Open MidletManager again and u'll see only the Midlets u wished to remain.
May 13, 2009 | HTC Touch P3450 Smartphone
HOW TO INSTALL GAME IN MY SAMSUNG D780 MOBILE
  • It is NOT officially possible to install java MIDlets on samsung handsets (excluding smartphones) via bluetooth, IrDa, USB cable or serial cable. MIDlets can only be downloaded by Over-The-Air (OTA) via a download server.
  • A hacking method has been devised for phones with the Dragonfly platform (see post #1 for platform list). All java serial codes discussed in the forum apply to phones with the Dragonfly platform only.
Try this link to understand the crack : http://forum2.mobile-review.com/showthread.php?t=24750
Thanks
Fame !
Apr 29, 2009 | Cell Phones
Digital audio player
i suggest to install your Midlets in your phone memory using motomidman (Midlets File Manager) try to search the software in yahoo...
Jul 09, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Razor V3
You have to use the program "Moto Midman" or "Moto Midlets Manager" to upload a Java app to the phone. MPT wouldn't upload JAVA.
Feb 05, 2008 | Motorola Mobility RAZR V3
FORGOTTEN PASSWRD
try this
try the FULL RESSET *2767*3855#\
all phone files will be lost
Jan 01, 2008 | Samsung SGH-D600 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
108 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
