Question about ViewSonic VX2235WM Monitor
Monitor bad focus. horizontal transistor blows
  • 348 Answers
This is definetly fault of EHT that big part in monitor replace it with original only duplicate or cheap may cause the problem adjust focuss control on EHT after fitting in on condition solder original transistor at h- output
Posted on Nov 23, 2008
Lg 29'' flatron tv circut diagram
Check the LOT. If it is faulty, horizontal output transistor will blow out. Check the capacitor connected across the collector of the horizontal output transistor to Gnd. If it is bad, or have any loose solder terminals, H-Out transistor will blow out. If you wish to get more http://electronicshelponline.blogspot.com/ check this link. Pull up older posts there, either by its left side bar, or see it in Timslide option.
Jun 22, 2013 | LG 29" Stretch LCD 17:6 aspect Mo TV
Pincushion distortion of LG 500G CRT monitor, which parts is responsable for this.
hi,
You have to check the pin control transistor in the horizontal section. It will be fitted on the same heatsik on which the horizontal output transistor is fitted.It will be a small transistor as compaired to the horizontal driver. Also you have to check the three mosfets in this section used to control the width.
ok
Jul 31, 2011 | LG Studioworks 563N 15" CRT Monitor
Hi,im a technician and i got a problem with a Sony Trinitron Colour television model Kv-T29mn3. I replaced an Str, capacitors & Horizontal Output Transistor. Voltage output its okay but it keeps on...
These sets had alot of problems with bad FBT flyback tranfomers,You might need to change FBT.
Heres another thing they also had Bad Picture Tubes that will blow hori output and you will not know its the Tube untill you replace the FBT.Use a high voltage probe to monitor Voltage coming from the anode button, if you dont have a HVP then disconnect the CRT board and monitor set.
Jun 26, 2011 | Sony KP-57HW40 57" Rear Projection...
Screen horizondally pulled right side and screen rolled to left side
hi,
your monitors horizontal deflection side have some problem. you have to check the horizontal width cotrolling transistor mounded on the aluminum heatsik near the lot( line output transistor). also check the three mosfets which adjust the width for different resolutions. there are three such mosfets in the horizontal section.
fist of all replace the width controlling transistor in the heat sink. photo of mosfet and transistor is added for reference. not the exact number.
ok
Jan 27, 2011 | AcerView 99C 19" CRT Monitor
Monitor no raster power has been ok
The screen is blank with no raster at all. There are indications that the channel numbers are changing in the display. This indicates that some of the low voltages are present but these may be derived from the standby supply.
Assuming there is no deflection and no High Voltage, you either have a low voltage power supply problem, bad start up circuit, or bad horizontal output transistor (HOT) or other bad parts in the horizontal deflection.
Check for bad fuses.
(If you have High Voltage as indicated by static electricity on the front of the screen and you hear the high pitched whine of the horizontal deflection when it is turned on, then the following does not apply).
Use an ohmmeter to test the HOT for shorts. If it is bad, look for open fusable resistors or other fuses you did not catch.
Assuming it is good, measure the voltage on the collector-emitter of the HOT (this is safe if there is no deflection). You should see the B+ - probably between 100 and 150 V.
If there is no voltage, you have a low voltage power supply problem and/or you have not found all the bad/open parts.
If there is voltage and no deflection (no high pitched whine and no HIGH VOLTAGE), you probably have a start up problem - all TVs need some kind of circuit to kick start the horizontal deflection until the auxiliary power outputs of the flyback are available. Some Zeniths use a simple multivibrator for this - a couple of transistors. Others power the horizontal osc. IC from a special line-derived voltage. The multivibrator type are sometimes designed to fail if someone keeps turning the set on and off (like kids playing) since the power rating is inadequate.
Test the transistors if it is that type with an ohmmeter. If one is shorted, you have a problem. The usual way a TV service person would test for start up problems is to inject a signal to the base of the HOT of about 15.75 kHz. If the TV then starts and runs once this signal is removed, the diagnosis is confirmed. This is risky - you can blow things up if not careful (including yourself).
If you hear the high pitched whine of the deflection and/or feel some static on the scree, confirm that the horizontal deflection and high voltage are working by adjusting the SCREEN control (probably on the flyback). If you can get a raster then your problem is probably in the video or chroma circuits, not the deflection or high voltage.
hope this helps......
Aug 06, 2010 | SAMTRON 77V 17" CRT Monitor
Every time i change the fuse it blows up
You have a shorted Horizontal Output transistor and a bad capacitor or two. Look for a bad resistor and you may have a bad flyback transformer [rare]. But yes the transistor is down!
Apr 11, 2010 | Zenith B25A02Z TV
No display
test all HV mylar capacitor around the horizontal circuits.. usually .22 1600volts with color orange or blue..replace caps that value has changed..
Jan 23, 2009 | Compaq V700 17" CRT Monitor
Acer tft monitor al 1516a , fuse blows immedeatly
Check the horizontal output transistor. Its probably shorted.
Dan
May 23, 2008 | Computers & Internet
Fuse blows, Disney DTD1363
It look like this is the PN p5nk50zfp.
This site has your part. Data sheet
This part, it might be your voltage regulator not the horizontal output transistor.
Good Luck.
Mar 12, 2008 | Disney DTD1363-CAR 13" TV/DVD
ViewSonic VX2235WM Monitor Logo
87 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
