Micrografx Webtricity 2.0 Full Version for PC Logo
Posted on Oct 18, 2010
Windows 7 on my computer,when i isert microgafx 8 it will not work , compatability issue ?
Will the sony nwz a818 work with windows 7/8
The Sony NW LATER NWZ-A818 is a portable media player that was released in 2010. It may work with Windows 7 and 8, but it's officially supported only for Windows XP and Vista.
You can try to connect the device to a Windows 7 or 8 computer and see if it is recognized by the operating system, but if you run into any issues, it may be difficult to find troubleshooting solutions as the device is quite old.
It's always recommendable to check the device's official website or the manual to check the compatibility with the operating system you have.
It's also worth noting that newer versions of Windows may require additional drivers or software to be installed in order to recognize older devices like the NW NW LATER LATER NWZ-A818.
Is the Pandigital SCN02 Photolink One-Touch Scanner compatible with Windows 8?
Are you using it currentrly? What is your current Operating System? I've been searching and can't see anywhate a windows 8 driver for this scanner.
Bu let me tell you, I'm using currently a Genius ColorPage, originally released for windows 98. Installed windows 2000 driver in compatibility mode for findows XP. There is no driver for Windows XP nor for Windows 7 and coldn't make it work in Windows 7. So I run it on a computer with dual bootWindows XP / Windows 7.
When I need to scan, I simply start up as windows XP. When finished scanning, reboot to windows 7
I Have Windows 7 on a 2 Tb HD SATA and Windows XP on 200 Mb IDE. Is more economical to have a dual boot then buy a new Scanner.
If your scanner won't run on windows 8, install on another HD or a partiton, Windows 7. doual boot Windows 7 / 8 work like a dream.
See comments for this scanner in Amazon;
Amazon com Customer Reviews Pandigital SCN02 Photolink One Touch Scanner...
I am trying to get my CTL-460 Wacom Bamboo Pen Tablet to work on my new computer, a Toshiba Satellite, which uses Windows 8. I have attempted to download the drivers multiple times, including from the
When loading the latest driver for it from Wacoms site, be sure to change the compatibility on the EXE file to "Windows 7". If that doesn't work, you will need to look at purchasing a newer model. The CTL-460 Wacom Bamboo Pen Tablet was only compatible with XP and Windows 7. Newer Microsoft operating systems are not supported on that product from Wacom.
Can I install windows 7 in my windows 8 computer
Yes you can for as long as there are drivers which compatible for windows 7. What is the build of your computer?
David
Upgraded from windows 7 to windows 8 ,now storage device not showing.
Have you tried to shut down the computer, unplug the usd external drive, reboot the computer, plug in the USB external HDD the should apply the driver. That said, Have you tried a Thumb Drive or any other USB device in the USB ports? It's a common problem when upgrading a OS that Hardware issues popup. Open the Device Manager, Is your USB controller working? Enabled? Any other devices in error? Unknown devices? Use the Win 7 drivers for your computer found on the computer manufacturer's website. Change the compatibility on the driver for Win 8.
1helpful
D-Link DPR 140 doesn't work with Windows 8?
Windows 8 is still new and there are some companies like D-Link which might not have the firmware for their products which are compatible with Windows 8 yet. I tried searching for a firmware for your product and I can't find one.
I suggest that you contact D-Link regarding this issue, they should have the fix for this and I'm sure that a lot of people are experiencing this same issue. This happens when new operating system are produced in the market. http://www.dlink.com.au/corporate/contact/
I also suggest that you install RadarSync in your computer. It's a technician's software. What it does is it automatically updates all outdated drivers in your computer. It works great with Windows 7 and Windows 8.
I hope this helps!
Carlo
My create a card cold is not compatable with my windows 7 computer
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. Do the same for the installer if it wouldn't install. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Is there a Creatacard CD compatible for Windows 7?
Creatacard cannot be run under Windows 7 because of compatibility issues. You have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
1helpful
2answers
Will elements 6 work on windows 7?
Yes it will work, but not all the features.. there are still some issue regarding the compatibility
Top Micrografx Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Micrografx Computer and Internet Expert? Answer questions, earn points and help others
