Tally by default tally showing companies in h: how to change to d:
  • 304 Answers
Hi Subbu
On Desktop u can see the tally shortcut icon on that right click
on that select Properties Option and select Find target to access tally default installation folder. in that folder choose Tally.ini configuration file open it with notepad and find a line having "Default companies = YES" change it "Default companies = NO" then Save and close the file. Open tally then you can see the option "Select Companies".
Hope this will be helpfull
Please rate me when this solved
Have fun
Posted on Jun 04, 2008
Tallyerp 9 memory access violation
If there are any user defined TDLs defined in the Tally.ini file set Default Companies to NO start Tally and check.
If the problem persists
Increase the screen resolutions to 16 bit high color small fonts, Load Tally and check.
Delete the printer drivers available in the Printer panel. Execute Tally. If this resolves the issue you can then re-install the printer drivers.
If the difficulty persists
After checking above-mentioned in case the difficulty persists please check the following.
Check for viruses in the system
Delete the Tally.sav file and check
Re-install Tally in a different folder and check
Disable the real time protection of the Anti Virus Software
Incase the problem persists please send an email to .
In case the problem is rectified when Default Companies is set to No in Tally.ini it indicates that the default company is corrupted. In such cases please follow the steps mentioned below
Take a backup of your company data
Execute Tally 9
From the Company Info Menu press Ctrl Alt R.
The Rewrite company screen is displayed. From the List of Companies screen select the Company in which you are facing the difficulty. The screen Rewrite Yes or No is displayed. Press Enter to re-write.
The error message indicates a data corruption. Please restore an earlier data backup which did not have this problem and proceed.
If you do not have the Backup then create a copy of the existing data and rewrite it by clicking Ctrl+Alt+R before selecting the Company.
Before rewriting ensure that the Company you wish to rewrite is not in use on any of the nodes and the command has to be applied before selecting the Company.
The data preferably should be available in the local hard disk. Ensure that you create a back up of the data in the the hard disk or a medium like CD.
Check http//
I found this howto here: https//
Mar 31, 2014 | Computers & Internet
When i m migrate tally72 data to tally erp 9 data then show the message migration is unable to reach tally.ERP 9 server post request failed
go to data folder of tally
rename the new data 10000 to 10000n
open tally erp 9 crack version
on select company press ctrl+alt + r
your new data will not b showing
than open tally data folder again and change the name of folder from 10000n to 10000
than press again ctrl+ alt +R
now in list you will be shown with new data
press enter
the data will be rewrite in older version
Oct 06, 2013 | Great Star Software Technology R Tally...
I have a proplem opening the tally erp9 memory access violation
find the tally.ini file and set default companies = no
Save the file and open up tally
Return to company info menu and press CTRL+ ALt + R to rewirte that company
Apr 05, 2012 | Computers & Internet
How to Solve a Incorrect Version in Tally ERP 9, after Restoring the Data?
tally incorrect version (11) ....for gold ultimate crack users...
i have solved it ...
press enter
further clarification post here
Nov 02, 2010 | Tally T2245 Matrix Printer
Error message : File is damaged. Rewrite!
Step 1: Start Tally.
Step 2:
Step 3:
Tally asks to select the company to rewrite. Select the desired company to rewrite and then press Enter key.asking-tally-to-rewrite-a-company.png
Step 4:
Rewrite confirmation will be appeared on the screen, press "y" to start rewriting process.rewrite-confirmation-in-tally.png
Step 5:
After rewriting the data Tally creates Tally.rew file in Tally it in any text editor and go through it about the corrupted data.rew-file-in-tally.png
Sep 15, 2009 | Computers & Internet
Tally 5.4 error
try to configure your configuration setting. change the data source where you data saved.
Exp (from program files, configuration setting) :
;; Tally eis 5.4 workstation specific parameters file
; Specify location of Data files
Data = D:\data tally\Tally 2\DATA
;; Specify list of companies to preload
; ** TO STOP DEFAULT LOADING set the following line to NO
Default Companies = Yes
Load = 0001
;Load = 0002
; Specify list of TDL files for user defined reports and changes
; ** TO STOP LOADING TDL FILES, set the following line to NO
User TDL = Yes
;TDL = <TDL file 1>
; Specify location of TALLY.SAV (saved configuration of Tally)
Config = c:\TALLY
; Specify Color details of local monitor
Color = Yes
a bold letter is the source of data that you must change.
Jun 22, 2009 | Computers & Internet
Tally 7.2 Data Corrupt
1)Start Tally and at Company Info Screen press Ctrl + Alt + R then select the corrupt company and press enter to start rewrite process.
2)If it does not worked then there is another method for rewrite:-
Click Start > Run > Type ’C:\(Tally 7.2 directory name)\Tally72.EXE C:\(Tally Data path)[space]/
then press enter
for Eg: c:\tally7.2\tally72.exe c:\tally7.2\data /
after pressing enter tally will get open and at company info screen press Ctrl + Alt + R then select the corrupt company.
Nitin Bankar, Pune
Mar 23, 2009 | Tally T2250 Matrix Printer
Nov 12, 2008 | Tally Line Matrix T6050 Printer
My tally 9 single user not opening my selected company
i have problem regarding tally9 internal error
software exception errorc0000005
Aug 25, 2008 | Computers & Internet
Computers & Internet Logo
226 people viewed this question
David Payne
David Payne
