Question about Kenmore 53542 / 53544 Side by Side Refrigerator
Fridge not cooling
Freezer working, but fridge getting warmer
  • Anonymous Dec 07, 2008
    fridge is warm inside
There could be a number of reasons why this is the case. Read on for what may apply to your fridge. Frost build-up on coils , or Self-defrost failure has occured, or Cooling fan has stopped working.
Check out this link - http://www.save-myfridge.com/fridge-trouble/my-refrigerator-is-not-cooling-well/ or http://www.save-myfridge.com/fridge-trouble/my-fridge-is-not-cooling-at-all/
Posted on May 02, 2012
I have the same problem. Ice builds up in the frost free freezer(!!!!) abd blocks the cold air that should go into the fridge. Temporary solution is to defrost the freezer by switching it off for 24 hours and mopping up the mess, Fridge should now work ok
Posted on Jan 14, 2009
Man, I'm ticked. Brand new SBS and the freezer works and the refrigerator is at 55 degrees. WHAT? Sears is coming out tomorrow, but this is very disappointing....
Posted on Aug 25, 2008
Problem is this my fridge is not defro his freezer ice coil is icee and he is not stingworking. fridge is totly heat his freezer fan is run and he did not work. when i clean his icee coil with water he work well please tell me what i do. my fridge model is rg s462qvc pl pl any one who knows tell me thank,s alot
Posted on Jul 15, 2008
  • sumitmahata
    sumitmahata Mar 29, 2012
    hey , you may like to post your query tohttp://www.save-myfridge.com/ . their experts may be able to answer your question properly.
  • sumitmahata
    Hey, you may post your query tohttp://www.save-myfridge.com/. their experts may be able to answer your question properly.
Fridge not cooling
3 Suggested Answers
  • 183 Answers
SOURCE: fridge is hot while freezer works fine
Defrost for 24hrs with doors open, turn back on it will then work ok. Regards Advisor
Posted on Aug 23, 2007
  • 670 Answers
SOURCE: Fridge not cool enough but frosty at the back
Since you are getting frost in you frost free refrigerator, tell me that the defrost circuit has a problem. It is made of a defrost timer/module, defrost heater and defrost thermostat. What should happen is that the defrost timer should periodically turn off the compressor for about 30 minutes and turn power to the defrost heater via the thermostat. The heater is attached to the evaporator coil and melts any frost build up on those coils.
It sounds like the defrost circuit has not been working for a while because the ice build up is not allowing the air to circulate around the coils to cool the refrigerator. The typical failures to the defrost circuit are the defrost timer motor fails to advance, or the defrost heater burns out. Hope this helps you.
Posted on Jul 14, 2010
The fridge part of it is not staying cold. The temp is getting warmer and warmer.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 24, 2011 | Refrigerators
Freezer works, but has some ice forming and refrigerator not cooling.
The refrigerator half of a refrigerator/freezer does not produce any cold! The refrigerator is cooled by transferring air from the freezer to the fridge. The fridge temperature setting controls a flapper between the freezer and the fridge. There should be a fan which blows air from the freezer into the fridge (through the damper).
If the ice forming in the freezer is concealing the cooling coil and air can not move through the coils, then the overall result will be a warm freezer (even though there may be ice in one location) and a warmer yet fridge. This can be tested by unplugging the fridge and allowing a complete thaw. If the ice is the cause of the problem, then it should work for a short while until it freezes up improperly again
:o).
Jun 04, 2011 | Whirlpool GB2FHDXWS (63 cu ft) Top Freezer...
The freezer appears to be working fine, however the fridge is not cold at all. For the last week it has been getting warmer and warmer.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2011 | GE Refrigerators
The fridge is cold but the freezer won't freeze
It has seperate cooling circuits as you describe the problem can be a leak of refrigerant in the freezer circuit.if there is no heating up in the freezer condensing coil.It has to be check for the leakage.
Jul 01, 2009 | Freezers
The grill being the condenser coil- The sealed system is low on freon or the compressor isn't working correctly.
Jul 01, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer only cools on the bottom half
check the seals on the fridge sounds like there might be a section not connecting with the fridge
Jun 07, 2009 | Freezers
Fridge won't get cold
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
Apr 28, 2009 | Refrigerators
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
708 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
