Please help me
There an error on my computer i install an anti virus but it said htkey/software/run/failed
  • kalii Jun 04, 2008
    hi i have an problem i install an anti virus on my computer but its failed htkey/software/current version/run/failed please help me
    Problem Solver:
  • 19 Answers
What anti-virus are you installing?
You should check first the system requirements for the software.
Posted on Jun 04, 2008
Tip
How to Recover Your Computer from Virus Attack {XP ,VISTA ,WINDOWS 7 ,Etc }
Software 1:DiskHeal
download
this software is used to Restore the
A:folder Option (Hidden files option restore)
B:C:, D:, E, F,_ _ Etc Drive not opening when double clicked from "MY Computer" Pendrive not opening etc.
C:Task man not openning (ie to recover Task Man is disabled by your ADMINISTRATOR error")
and more............
D:Restore Registry Editor
Software 2:Autorun virus removal (can remove autorun virus form your computer)
download
A:restore Exe file error's
B:anti-virus not installing {some viruses block installation of Anti-virus software } provide solution for these problem
C:can repair Safe Mode Option{if you are unable to access Safe mode .some viruses block's the safe mode}
and more........
software 3:similar software (file size is 22MB)
download
software 4:Antivicrypt
To recover files infected by .viCrypt” extension. virus
download
4:Install antivirs software
update and do full system scan
download
5:Go to Run type Cmd and Type SFC/SCANNOW and press enter key
if your windows files are missing this command will restore the missing
files from windows CD"
make sure that you have the windows installation CD to try command
6:Install Registry cleaner
download
Registry cleaner software -delete invalid entry in the registry thus speed up your system
(please rate me)
on Jan 12, 2010 | Computers & Internet
Avg anti-virus will not install
check for virus or another anti virus software was installed
Oct 08, 2009 | Computers & Internet
Internet Explorer script error do you want to continue running scripts on this page? Library not registered
it could be possible that The author of the webpage you are accessing has simply made some sort of programming error and this is typically the most common reason.or that You are possibly running a pop-up killer of some kind which closes the pop-up too quickly which causes the script of the website to fail and thus giving you the error because it didnt complete.
possible You (still) have some sort of spyware or adware infection that tries to launch something such as a popup but causes script errors.
this is the most likely issue in your situation.
Solution:
1. Make sure your Anti-Virus software is up-to-date and then run a full system scan.
2. Try running a scan with other malware detection software. (Malwarebytes )
3. Be sure your are not running Rogue Anti-Virus software ( Security Center, Anti-Virus 2009, and Anti-Virus 2010).
4. Take a look into the Event Viewer to see the path of where the script is coming from. Some more detail may show up in the Event Viewer log)
5. Run windows updates and install any critical/important updates.
hope this helps
Oct 01, 2009 | Microsoft Windows Vista Home Premium with...
Error: Action failed for file avgwdsvc.exe: starting service.
open services.msc from run window and then find avgwdsvc.exe. right click and select properties then check the disabled checkbox. Apply and get out of services.msc. now try to install the new version of avg.
May 16, 2009 | Computers & Internet
Anti virus
You of course can run multiple instances of anti-virus programs in your computer assuming that the anti-virus will allow competition in the resources. However. more often, this would only eat on your memory and processor so it is not advisable and there is no significant gain if using 2 or more anti virus bot several downside.
How to check what anti-virus is running, there are several ways:
1. Go Start, All Programs and check what anti virus has been installed;
2. Go to Control Panel, Add/Remove Program, the programs installed would be listed including your anti-virus;
3. Go to Start, Run, type "msconfig". next window go to Startup tab, it will show what programs are running upon Windows start up including your anti-virus.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 24, 2008 | Microsoft Windows Vista Ultimate Edition
Computer is showing fatal error
That fatal error warning message is not coming from your operating system - it is coming from a virus. Do not follow whatever instructions boxes like that may tell you until after the following process.
Turn on your machine's firewall and tick NO EXCEPTIONS. Download an anti-virus product like AVG from download.com. Install it, update it until it says it has all updates, and then do a complete scan of your machine removing viruses.
Reboot.
Navigate to WINDOWS UPDATE on your start bar and allow it to install all updates it can, even optional ones.
Reboot.
Go to ADD REMOVE PROGRAMS from CONTROL PANEL and remove all security software besides the anti-virus you just installed, since this software has failed and is now unreliable.
Good luck...
Nov 18, 2007 | Compaq fs740 17" CRT Monitor
Norton Anti-viruses problem Error 5, Pc Security Failed!
use the another software like MAC AFFE,AVG,KASPER SKY,QUICK HEAL etc
Oct 04, 2007 | Symantec Norton AntiVirus 2004 - (Open...
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
