Question about ViewSonic VX2235WM Monitor
Cannot get correct resolution
I have the latest drivers for the video card and monitor installed but cannot get the Viewsonic VX2235wm monitor to change to 1680x1050 it is into in the available settings, I can go higher or lower, any ideas.thanks
  • 1 more comment
  • gbs931 Aug 22, 2008
    How do I change the video from Analog to Digital; there doesn't seem to be any "properties" in the Device Manager relating to the Monitor?
  • ellen575 Feb 16, 2009
    My monitor will not allow the 1680x1050 setting either. The monitor settings changed when I plugged in my camcorder through a firewire connection, and I can't recover the previous settings. Everything was fine before.
  • newhaven May 02, 2009
    I too have the same problem, the Viewsonic VX 2235WM monitor was working fine, then overnight- no longer able to access a resolution higher than 1024x768!
    I remember having this problem originally when I purchased the monitor and I remember someone telling me of a quick fix (which worked) unfortunatly I don't remember what it was!
    If anyone has any ideas please let me know! I think I have been on every forum relating to this with no luck!
  • 55 Answers
1. It could be limitation of your video card. Older cards would not support high resolution for LCD monitors.
2. Be sure to use DVI(digital) output from your video card. You will not get a good resolution with VGA(analog)
3. When installing driver for a monitor sometimes you will get a chose to install analog(VGA) or digital(DVI) driver. Choose the correct driver.
Posted on Jun 04, 2008
I have installed viewsonic va1716w monitor using windows xp. I am unable to set its resolution to 1440X900. from display properties it going from 1024X768 to 1280X1024
It is possible that the video driver cannot support 1440X900 resolution.
Try installing the latest video driver and then try the higher screen resolution.
Mar 19, 2011 | ViewSonic VA1716w Monitor
I cannot install the driver for Viewsonic VX2235wm (XP pro) Cannot select 1680x1050 res for this monitor
Well your LCD supports 1680x1050 resolution.
You have to check the video/ graphics card of your PC, if it supports the same resolution or not. Let me know the model no. and your motherboard details for a better assistance.
Looking forward for your response
CreativeTECH
Nov 13, 2010 | ViewSonic VX2235WM Monitor
Can't set 1680x1050 resolution on viewsonic monitor
I found the solution for my problem.
Initially I thought it's a monitor problem and was trying to find the drivers for it.
The problems is not with my monitor but with the video adapter I use.
My video adapter has a intel chipset (Mobile Intel(R) 965 Express Chipset Family). Apparently the driver that I was using was quite old.
The only thing I had to do is:
1. Download the latest video adapter driver
2. Uninstall the current video adapter driver
3. Restart the system (Windows XP)
4. Install the new driver.
5. Restart the system.
May 19, 2009 | ViewSonic VA2026w Monitor
I just bought a viewsonic vx2240w. When I change the resolution to 1680x1050 the page becomes too wide for the screen. I have to scroll left and write just to see it.
This sounds like an issue with the windows driver for your video card. I have to load the viewsonic driver for my monitor first and make sure the device monitor is showing the vx2235 and not default monitor. Then make sure your video board will support the 10 x 16 format and check for any settings about horizontal scrolling. If you are running an ATI card, get the latest version of the Catalyst drivers from their web site. Hope this helps.
Feb 02, 2009 | ViewSonic VX2235WM Monitor
Can't get improved resolution
You need to download the most recent video driver for the video card in the computer. Open it up, look at the video card and then google the name of the card for the latest windows xp driver.
May 05, 2017 | ViewSonic G810 21" CRT Monitor
28 inch monitor doesn't let me see my entire desktop
you need to download an updated driver for your video card. Try windows update or go to your video cards website
Dec 07, 2008 | ViewSonic VX2235wm LCD Monitor
Hi i have big problem with my ViewSonic VX2235wm monitor
check did you insert external display card or using internal if not inserted then internal display card will not support above 600x800 if you want to work with high resolution then insert AGP card and reinstall drivers there are 4 type cards 1x,2x,4xand 8x you use 8x AGP card then select high resolution also you can look best movie and good support to 3D games
Nov 18, 2008 | ViewSonic VX2235WM Monitor
No signal analog
Press the front screen button that has an arrow. It will be switching from analog to digital and digital to analog if you press it again.
Mar 12, 2008 | ViewSonic VX2235WM Monitor
Monitor resolution
when you increase considerable resolution windows will ask you do you want to keep these settings? you select yes then that will be saved
Feb 15, 2008 | ViewSonic VX2235WM Monitor
ViewSonic VX2235WM Monitor Logo
420 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
