Question about NetGear WGR614 Router
Re: "Not able to communicate with Primary DNS Server"
I have had this router since '94'. I have never had a problem with it. It was accidently turned off and for some reason the internet was not connected, so I started the whole process again, as if it was the first time. Which included 'reset' from the little button behind the unit.
The whole process works, step by step, until it asks me to enter the IP address and the other addresses.
Then it thinks for a while and a pop up comes up and says
I have done this whole process over ten times and the same problem occurs. I checked the IP address and other in the "network & sharing" option..
Can somebody help?
Thank you for getting back to me. I was able to fix via the reset button. I didn't know the unit had one??!! lol..
I pushed the reset button, then started the process from the start, and it worked.
Thank again!!
Billy
Posted on Nov 04, 2008
  • 488 Answers
Whats the DHCP status?is it enabled?try using these Open DNS settings fot the primary DNS server
208.67.222.222 preferred DNS
208.67.220.220 alternate DNS
please let me know if it helped..
Posted on Oct 30, 2008
Set DNS to Open DNS
Most D-Link devices use the 192.168.0.X range.
  1. Enter the router password. ...
  2. Click on the Manual Internet Connection Setup button at the bottom.
  3. Enter the OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in Primary DNS Server and Secondary DNS Server fields.
  4. Click Save Settings button at the top.
Oct 19, 2016 | Computers & Internet
I CANT ACCESS A FEW SPECIFIC SITES.
Hi Pauline,
Try different using a different DNS address. OpenDNS provides free, fast servers that are used by millions. Here's how to do it with and without a router in your set up:
WITHOUT A ROUTER:
Mac OS X
  1. Go to System Preferences.
  2. Click on Network.
  3. Select the first connection in your list and click Advanced.
  4. Select the DNS tab and add 208.67.222.222 and 208.67.220.220 to the list of DNS servers.
  5. Click OK
Windows 7
  1. Click the Start Orb, then select Control Panel.
  2. Click on Network and Sharing Center.
  3. Click on your primary connection or Local Area Connection under Active Networks.
  4. Click the Properties button.
    Windows 7 may prompt you for permission to make network setting changes.
  5. Highlight 'Internet Protocol Version 4' and click Properties.
  6. Click the radio button 'Use the following DNS server addresses:' and type 208.67.222.222 and 208.67.220.220 in the Preferred DNS server and Alternate DNS server fields.
  7. Click OK button, then the Close button, then Close again. Finally, close the Network and Sharing Center window.
    At this point, we highly suggest that you flush your DNS resolver cache and web browser caches to ensure that your new configuration settings take effect.
Windows XP
  1. Select Control Panel from the Start menu.
  2. Click Network Connections from the Control Panel choices.
  3. Choose your connection from the Network Connections window.
    If you have more than one, choose your default/current connection.
  4. Click Properties button.
  5. Select Internet Protocol (TCP/IP) and click Properties.
  6. Click the radio button Use the following DNS server addresses and type 208.67.222.222 and 208.67.220.220 in the Preferred DNS server and Alternate DNS server fields.
  7. Click OK
Windows Vista
  2. Click on View network status and tasks.
  3. Click on View status.
  5. Vista may ask for your permission to make changes. If so, click the Continue button.
  6. Select Internet Protocol Version 4 (TCP/IPv4), then click the Properties button.
  7. Click the radio button "Use the following DNS server addresses:" and type in OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in the Preferred DNS server and Alternate DNS server fields.
  8. Click the OK button, then the Close button, and the Close button again. Close the Network and Sharing Center window.
WITH A ROUTER:
Generic Router
  1. Open the preferences for your router. Often, the preferences are set in your web browser, via a URL with numbers (example: http://192.168.0.1). You may need a password.
    If you're like us, and you set the router password long ago and cannot remember it now, you can often reset the password to the manufacturer default by pressing a button on the router itself.
    Or preferences may be set via specific application for your router, which you installed on your computer when you added the router.
  2. Find the DNS server settings.
    Scan for the letters DNS next to a field which allows two or three sets of numbers, each broken into four groups of one to three numbers.
  3. Put in the OpenDNS server addresses, 208.67.222.222 and 208.67.220.220, as your DNS server settings and save/apply.
Linksys Router
  1. Visit the router's IP address in a new browser window.
    http://192.168.1.1 is the default Linksys router IP address.
  2. Enter the Network password.
    The "Enter Network Password" window will appear. Skip user name and type the router's password (admin is the default password, if you haven't changed it) and click the OK button.
  3. Type in OpenDNS addresses, 208.67.222.222, 208.67.220.220, in Static DNS 1 and Static DNS 2 fields.
  4. Click Save Settings button.
Netgear Router
  1. Type the router's setup URL (http://www.routerlogin.net, http://192.168.0.1 or http://192.168.1.1) into a web browser address bar.
    http://192.168.1.1 is the default Netgear router IP address.
  2. Enter the password.
  3. Type in OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in Primary DNS and Secondary DNS fields.
  4. Click Apply button.
  5. Wait for the settings to be updated.
D-Link Router
  1. Visit the router's IP address (http://192.168.0.1) in a new browser window.
    If you are attempting to configure a D-Link router, take note of your computer's Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. Most D-Link devices use the 192.168.0.X range.
  2. Enter the router password.
    Note: if you have not changed the original settings, the default username is admin and the password is blank (nothing).
  3. Click on the Manual Internet Connection Setup button at the bottom.
  4. Enter the OpenDNS addresses, 208.67.222.222 and 208.67.220.220, in Primary DNS Server and Secondary DNS Server fields.
  5. Click Save Settings button at the top.
Oct 07, 2014 | Computers & Internet
Hi all\r\n Newbie to servers, ive been given an computer with server 2003 loaded on it it has been through the first stage setup and now im with a few things, mainly when i run the email and internet...
DNS-servers translate names, such as 'www.fixya.com' to IP-addresses, because routing of IP-packets on the Internet is done using the IP-addresses, not by using the names of each computer.
If you have a router between your computers and your cable-modem (or DSL-modem), then the router can automatically supply the "Primary DNS Server" and "Secondary DNS Server" and "IP Address" to your server computer, if you configure the network-adapter on the server to "automatically obtain an IP Address".
As long as you leave your server running, the "dynamic" IP-address that it obtains will, in effect, become a "static" (namely "non-changing") IP-address.
Feb 03, 2011 | Microsoft Windows Small Business Server...
Newbie to servers, ive been given an computer with server 2003 loaded on it it has been through the first stage setup and now im with a few things, mainly when i run the email and internet connection...
Feb 03, 2011 | Computers & Internet
What is the primary DNS and secondary DNS?
There are two basic types of DNS - primary DNS and secondary DNS, which are generally applied to each newly registered domain. They are name server computers where the record of your domain name is stored. The information on both servers is identical. The two DNS values are usually configured by your ISPor hosting provider and given to you as a very important part of your domain registration order details.
In general, domain names can work with only one name server - the primary DNS. However, practice has shown that a domain name needs to have at least two name servers assigned in order to be available at any time. In case there is a problem with the primary name server, the secondary name server will be able to answer the online request for a particular domain. This back-up requirement has turned into an accepted Internet standard that prevents domain names from going offline.
Sep 23, 2009 | D-Link DSL-G604T Wireless Router
PS3 DNS error (80710102)
see i hav the same prob try putting this in
primary dns 208.67.222.222
secondary dns 208.67.220.220
ip address 192.168.1.45
if that dont work people say u should unplug your router 4 a couple of minutes then plug it back in
Aug 22, 2009 | Sony Playstation 3 (PS3) Console
Linksy router
a DNS server stands for domain name service. The DNS server translatesnames from IP addresses. The internet sees IP addresses such as 209.235.250.53 but the DNS server provided by your ISP translates it for you into fixya.com. You should be able to aquire the DNS server information from your internet provider (ISP) hope this helps.
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
I cannot communicate with primary dns server 172.29.71.1 is there a way i can reset it automaticaly or manually
You cam try doing a power cycle. Turn off the modem, router (if you have one) and your computer. after 1 minute turn on modem first then router and computer. If you still can't communicate or ping the DNS it could be a firewall that is blocking it.
Oct 08, 2008 | Computers & Internet
Hooking up my playstation 3 to the internet with a wireless connection
enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server
Feb 01, 2008 | Sony Playstation 3 (PS3) Console
NetGear WGR614 Router Logo
100 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
