Question about HP Officejet Pro L7680 All-In-One Printer
Fax Auto Answer
The auto answer on the fax was working fine but has now stopped. Even though the green light for the auto answer is on, we now have to go across to the machine to recieve faxes manually. Any help greatly appreciated.
  • timba83 Jun 09, 2008
    Thanks for that but it doesn't seem to work. The fax test shows everything as ok but the auto answer still does not work.
    Is there any way the machine can be reset?
    Novelist:
  • 79 Answers
u can try to run the fax test from front panel of the unit .
for fax test press setup >go to tools ( by pressing the arrow key ) > go to run fax test press ok .
it give u a report on the fax attributes. u can download the utility from the link below and see whether its a hardware issue or not . in case its hardware , contact HP Technical Support at 1800-474-6836 .
Diagnostic utility
Thanks
Posted on Jun 06, 2008
  • Prabhjeet  Singh
    Prabhjeet Singh Jun 21, 2008
    yes , u can try to reset the unit to its factory defaults by performing the following steps .
    unplug the power cord from the back of the unit without turning off the printer.
    press n hold # key and 6 key together n do not release the keys ,while holding them down plug in the power cord back into the unit.
    wait for a few seconds as it would make certain noises and turn off , when the unit turns off release the keys .
    after a few seconds turn on the printer , wait as it wud go into initialisation mode > might ask to press 1 for language (please follow instructions ) it would give 2 or 3 allignment sheets.
    5
    after its done try to copy , then try to send fax n see if the auto answer button works or not.
    note - after the RESET fax seeting are to be done again as it goes to factory default settings .
    Thanks
How activate auto answer?
1 Press {AUTO ANSWER} repeatedly to display the following.
FAX ONLY MODE 3 RINGS
The display will show the ring setting in FAX ONLY mode.
The {AUTO ANSWER} light is ON.
2 If you wish to change the ring setting, press
{A} or {B} repeatedly to display the desired
setting, and press {SET}.
How faxes are received
When receiving calls, the unit will automatically
answer all calls and only receive fax documents.
Mar 08, 2012 | Panasonic KX-FL611 Plain Paper Laser Fax
HOW DO I GET MY FAXES OUT OF THE MEMORY?
Receiving a fax
Receiving a fax automatically
1 Make sure the printer is on and is connected to a working phone line.
2 Make sure that Auto Answer is on.
To check if Auto Answer is on:
a From the printer control panel, press (tool icon).
b Press the arrow buttons until Fax Setup appears, and then press ok.
c Press the arrow buttons until Ringing and Answering appears, and then press ok.
d Press again.
Check to see if Auto Answer is set to On.
e If Auto Answer is not set to on, press the arrow buttons until On appears, and then press to save the setting.
3 Set the number of times the telephone rings before the printer automatically receives faxes:
a Press the arrow buttons until Pick-up On appears, and then press ok.
b Press the arrow buttons until the setting that you want appears, and then press to save the setting.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
Receiving a fax manually
1 Make sure the printer is on and is connected to a working telephone line.
2 Make sure that Auto Answer is off.
3 To receive the fax, press (green botton) or press * 9 * on the telephone after you answer it and hear fax tones.
4 Hang up the telephone.
The printer receives the fax.
Receiving a fax with an answering machine
1 Make sure that Auto Answer is on.
2 Make sure you have set the number of times the telephone rings before receiving a fax automatically.
When a telephone ring is detected, the answering machine picks up the call.
• If the printer detects a fax, it receives the fax and disconnects the answering machine.
• If the printer does not detect a fax, the answering machine receives the call.
3 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
Forwarding faxes
Use the fax-forwarding feature if you are going to be away, but still want to receive your faxes. There are three
fax-forwarding values or settings:
• Off—(Default)
• Forward—The printer sends the fax to the designated fax number.
• Print & Forward—The printer prints the fax and then sends it to the designated fax number.
2 Press the arrow buttons until Fax Setup appears, and then press ok.
3 Press the arrow buttons until Ringing and Answering appears, and then press ok.
4 Press the arrow buttons until Fax Forward appears, and then press ok.
5 Press the arrow buttons until Forward or Print & Forward appears, and then press ok.
6 Enter the number to which you want to forward the fax, and then press ok.
Aug 12, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
How do you change the number of rings, so that the fax will pick!
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Apr 28, 2010 | HP OfficeJet J4580 All-In-One Laser...
Xerox Work Center 657 Will Not Recieve, After Replacing Drum
Check to see if when he reset the fax reverted back to receive only as a default.
  1. Press [Menu] (the Up arrow key), and press [3], [1], [0], then press [1].
  2. Select the Answer Mode:
    • Press [1] to select Auto answer, then skip to step 3.
    • Press [2] to select Manual answer, the press [Stop] to return to the Standby mode.
  3. If you select the Auto answer feature, use the numeric keypad to enter the number of times (must be 2 digits, 01-10) the phone must ring before the machine answers, then press [Enter].
    NOTE: When the machine is set to Auto answer and the set number of rings occurs, the machine answers with a fax signal tone and enters the Auto Receive mode.
  4. Press [Stop] to return to the Standby mode.
Jun 30, 2009 | Xerox WorkCentre Pro 635 Laser Printer
Fax machine
You need to set the machine up to AutoAnswer as follows per HP:
Receiving faxes automatically If the Auto Answer option is set to On , the unit automatically answers incoming calls and receives faxes after the number of rings specified by the Rings to Answer setting. Press Auto Answer to turn on the Auto Answer option. 1: Setting the Auto Answer option
  1. 1 - Auto Answer button
    NOTE: The Auto Answer button is lit when the Auto Answer option is turned on.
  2. Press Auto Answer again to turn off the Auto Answer option.
Dec 30, 2008 | HP Officejet 6310 All-In-One InkJet...
Auto answer not working
First, unplug the power cord for 10 seconds to reset the fax.
If that doesn't work, you will have to scroll through the menus and set to AUTO or AUTO RECEIVE.
You should be GREEN for AUTO. RED means MANUAL MODE
Nov 24, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Fax machine
Somehow the fax go set from Auto Answer to Manual.
Setting Auto Answer to on
1 From the desktop, double-click the Productivity Studio icon.
2 From the Welcome Screen, click Fax History and Settings.
3 From the “I Want To” menu, click Adjust speed dial list and other fax settings.
4 Click the Ringing and Answering tab.
5 From the Auto Answer drop-down list, select On.
6 Click OK to save the setting.
The Auto Answer light on the control panel comes on. When the number of rings you set is detected, the printer automatically receives the incoming fax.
Sep 27, 2008 | Lexmark P4350 All-In-One InkJet Printer
Telephone callers get fax sound even when fax is in manual
Sounds as though you are answer ing a phone that is not connected to the unit and you have the Man/Auto switch set to on. Press Function then Data Registration press Set using the > scroll to RX Settings press Set scroll to Man/Auto Switch make sure it is turned to Off.
Apr 21, 2008 | Canon FAXPHONE L80 Laser
My fax sound but dont received any fax
hi,
check whether the auto answer is turned on...
either u have the button on the front panel of the printer itself "auto answer" or u will have it in the fax menu...
press the menu button and scroll down to fax setup or advanced fax setup, make sure the auto answer option is turned on....
thanks and regards
agnel
Mar 19, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP G85 auto-answer
yeppers...same thing happens to mine. So, I simply set it to receive faxes manually now.
Jan 18, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
HP Officejet Pro L7680 All-In-One Printer Logo
320 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
