How to scan using OCR
How do I get my Canon MP610 to scan a sheet of text into MS Word so it can then be edited?
  • shoerep Jun 04, 2008
  • 19,396 Answers
You must select text document in scan panel, instead of color picture. The document will be automatically redirected to ocr.
Posted on Jun 04, 2008
  • Ginko
    Ginko Jun 04, 2008
    Here is a way to scan on ocr from Microsoft Word for example:
    Acquire Text
    The following instructions will give
    you the basic instructions to acquire text from a scanned document in
    Office Word 2007 using OmniPage SE.
    1. Ensure the Canon scanner driver and OmniPage SE are installed and that your scanner has been setup.
      Note: If OmniPage SE is not installed, the required Add-in for Office Word 2007 will not be installed
    2. Place the document(s) to scan on the platen or on the Automatic Document Feeder (ADF) (if applicable).
    3. Open Office Word 2007.
    4. From the ribbon menu, select the 'Add-Ins' tab.
    5. In the Add-Ins tab, click 'OmniPage' and then select 'Acquire Text Settings (OmniPage SE)'.
      The Options window will open.
    6. On the Direct OCR tab, click the 'Image Source' drop-down to select 'Scan'.
    7. Confirm 'Scan' is shown in Image Source section and then click 'OK'.
      The Options window will close and you'll return to Office Word 2007.
    8. Click 'OmniPage' and select 'Acquire Text (OmniPage SE)' to scan your document.
    9. After the document(s) is scanned, make corrections to the text items as appropriate.
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
How can i scan a document on my mp240
download this free OCR program, install it and when you open your scanned image, just click on the OCR button and the scan will be converted to editable text.
Or just click on the MS Word button on the interface, and it will open it in Microsoft Word. In either case, you can re-work the document and re-save it or print it.
Here is the program
click here
Dec 23, 2010 | Canon PIXMA MP240 All-In-One InkJet...
I have Canon Lide 60 Scanner. I have to use OCR function to convert printed text to MS Word 2007. I click "OCR" on CanoScan Toolbox, select Black and White (OCR) Scan Mode. Then, it gives me...
Hello
you are doing well, just select MS word program Exe file in C:\program file\Microsoft office\officexx\winword.exe in set option of canoscan.
Then your scan will open in MS Word
Hope it will helps and do rate the solution if so
Dec 21, 2010 | Canon CanoScan LiDE 60
I have a hp 1310 AIO Printer how do you scan documents to computer using such programmes as ms word
MS Word cannot open scanned documents to edit. You need to run a scanned document through an OCR program (optical character recognition program) which converts the scanned document into a text document. Then you open Ms Word and import or open this text document to edit or change the text.
Nov 25, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
What are the functions of ocr
An OCR program (optical character recognition program) converts scanned text documents into a text file which you can then open with a word processor to edit and or add addition text to this document.
Apr 04, 2010 | Canon ScanFile OCR Full Version for PC
CAN'T SCAN TEXT
If you scan the document, make sure it is saved in JPEG format. What you do afterwards is to download FreeOCR. This program is free and works better than most of the ones you purchase.
Just install it in 5 minutes, open your scanned jpeg image and click on OCR button and in seconds, the program will bring it up in editable format for you to change, correct or whatever. Or just click on the OCR MS Word button, and it will open it up in Microsoft Word. Here is the link..
http://www.freewarefiles.com/Free-OCR_pr…
Mar 08, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
How do you scan a document using the Canon MP240?
Here is the program
click here
Oct 20, 2009 | Canon PIXMA MP240 All-In-One InkJet...
How to scan and edit text document
You must use an OCR (Optical Character Recognition) program
Run the "ScanSoft OmniPage" software that came with your printer.
Load the document into the scanner and "acquire" the document through OmniPage.
The pictures will not show up and the text may not be 100% accurate.
Run the resulting document into your wordprocessor (MS Word? or Works?), and run spellcheck.
Oct 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Problem using OCR with Canon MP610 all-in-one
I got this message too, before I installed an OCR program. It may be that you need to install one (or specify it, if you have one already). With my MP610, an installation disk was included that contained the OmniPage SE program for OCR. When I installed that on my computer, and told MP Navigator (another Canon-supplied program, that controls scanning) to use it as the "Open With" program for OCR, it worked.
Dec 15, 2008 | Canon MP610 Photo All-In-One Printer
459 people viewed this question
k24674
