Question about BenQ G2400W Monitor
Monitor won't go into standby when in HDMI mode
I am trying to use the monitor to connect both my PC and Playstation 3. When both are on (either through DVI in or HDMI in) then the picture is perfect. When I power down the DVI device, the monitor goes dark after approx 5 seconds. When I Power down the HDMI device, the monitor glows bright blue.
It doesn't matter whether I turn the device off or unplug the device, the monitor still shows a blue monochrome screen
  • 1 more comment
  • Anonymous Jun 19, 2008
    Same problem ... only D-Sub can be in standby mode, DVI and HDMI got same matter
  • ppck Nov 29, 2008
    I have exactly the same problem ... No standby when input set to HDMI
  • dfsg Dec 22, 2008
    Same here...
    Have talked to BenQ and they admit a bug but they are not going to fix it !!!
    The suggested to use DVI-input instead of HDMI-input.
    But in the DVI I have another computer!
    **** them !
SOURCE: Benq monitor powers off immediately
Hi This is radbrad Took the monitor in - they did some soldering and repaird it? any way it was a physical problem
Posted on May 09, 2007
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
SOURCE: dvi connection to ps3
try to hold the power button for like 6 seconds until u hear a beep...
it will reset the display and adjust it to ur monitor...
hope this helps
Posted on Nov 16, 2008
saumyar
  • 174 Answers
SOURCE: The monitor screen goes dark about 10 minutes
Please verify the power option setting present in 'control pannel' option once. If you have selected to turn off the power supply after 10mins, (once the system is in idle state) then the SMPS will stop supplying power.
thanks.
Posted on Jul 20, 2009
  • 732 Answers
SOURCE: Monitor turns black after 3 seconds
teo6925, "Switch-mode-power-supply" is in partial shutdown mode. Can you see any electrolytic filter capacitors that have a slight "swelling" to their tops? They should be flat!! You may also need to inspect all the soldered component connections very closely for cold, thermally intermittant, "frosty" looking solder joint connections. May need large magnifying glass or 10x to 20x inspection microscope to locate these thermal/vibration "fractures" and then resolder them! If you have a capacitor problem, then you will need to carefully remove and replace with new ones. If you are novice at soldering I suggest that you document your work with digital camera or video tape so you can get everything back together with no "leftover" pieces! Teo, all you need to do to find out how BAD the problem of poorly manufactured capacitors is would be to search WEB for BAD CAPACITORS!!! Look for pic's of ELITE capacitors or CAPXON brand. You will be stunned beyond belief!!! Reading is free!! READ, READ, READ. Let us know what you find and do additional comment here on FIXYA. 12fixlouie
Posted on Jan 09, 2010
New generation ps3 system on but no video
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
Black screen pushing red to green donot work do not hear any beep
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor)....
No video or sound
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).......
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
My TV screen says that ( not supported mode) and I have the play station on HDMI2
"no signal" showing on tv screen
Jun 29, 2010 | Sony Playstation 3 (PS3) Console
Problem connecting my ps3 to my samsung le23r71bx tv using an hdmi lead. I get an error message "mode can not be supported"
Jun 28, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is not working it wont show a picture and when you try to turn it og it goes bip bip bip
I have a playstation 3. there is power but no communication with tv. i have tried new rc cables as well no luck please help. tnx
My ps3 will not output anything over 480p. I have used it at 720p for 8 months now. When I loaded Modern Warfare 2 it blipped and the tv said Mode Not Supported. It cycles through all the tv options and...
May be worth a try
Jun 27, 2010 | Sony Playstation 3 (PS3) Console
Ps3 output rainbow blocks and screen flashes
Jun 26, 2010 | Sony Playstation 3 (PS3) Console
BenQ G2400W Monitor Logo
1,387 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
