Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
Auto Cad2007 Help
i use AutoCAD2007
Recently i got internet connection,
when i press F1 Key for help, it is connecting to net. I don't want to coonect to net. Same thing happens when i click Help menu
Please suggest remedy
Try type HELP in command window
Posted on Jun 07, 2008
Press f1 start windows
It may be asking you to press the "F1" key because it is having a hardware problem which should be checked, or you may need to adjust the settings in BIOS. It can also be an indication that you need to replace the CMOS battery. Try this: Go to your BIOS and load default settings.2 Mar 2012
Press F1 key to start Windows - Ccm.net
ccm.net/faq/9372-press-f1-key-to-start-windows.
also go to this link might help you out. Press f1 start windows Google Search
Oct 13, 2017 | ASUS Computers & Internet
When i press fn and f1 my option list does not shown can't get on to the internet
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"imake sure its enabledPci device arrows key scroll to nstalled. Hope this helps.
Jan 14, 2013 | Computers & Internet
Lost wireless connection in ubuntu laptop
Try recycling the router by unplugging it and plugging it back up.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Jun 02, 2012 | Computers & Internet
I need to connect to wireless on my laptop. There is no switch but the keyboard has the F1 key with a wireless sign. How do I turn it on? I have tried it with the Fn key without any luck. Thanks
Hi miksibanda,
Did you try Fn and F1 pressing at same time? On the right bottom side of the of the task bar a wireless signal bars? If you see that the wireless is on. double click a click view wireless network connection. The ssid of your router you will show then connect and enter the wep key or passphrase. I hope this will help you connect wirelessly.
HRH
Jan 05, 2011 | Computers & Internet
WIndows doesn't load ,frozen, internet connection problems
For that when you power up the computer press F1 or F2 or del or ALt+F2 key to enter in bios.
Then go to boot menu and set first boot device as your harddrive.
Also disable boot from lan in advanced menu.
Disable SATA in bios.
Then save settings and exit then check.
Let me know if you need further assistance.
Thanks for using FixYa.
May 14, 2010 | Acer Aspire One Netbook 8.9" Notebook
Fujitsu Siemens Amilo D7850, wireless internet, hi does it have
Tyr pressing Fn and f1 button or the combination or Fn and F2 it will turn the wireless ON on the laptop, then you will be able to see your router or modem's wireless connection and will be able to connect
Let me know if this will help
Regards
Dec 03, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
I have the same problem with my Compaq. Its frozen on the logo
hi there..
turn of your computer..
unplug all the cables...
press and hold down the power key which is on your cpu for atleast 5 - 10 secs..
after that ..please connect the power cable.. mouse.. key board. monitor and your internet cable..
and then restart your computer..
when you restart your computer keep tapping the f1 key (i hope this is for bios)..
restore to default over there.. press enter to save.. once done this would automatically reboot..
this should fix this problem...
please post your answers.. or comments...
Aug 20, 2009 | Compaq Computers & Internet
Every time i want to connect to the net on my nc10 i have to go into all programes .can i configure it to auto connect when i press the internet explorer key
Yes setup as Internet explorer your default browser in Internet Options,
See Manage the adds ons.
also set your internet icon on task bar for one click.
Aug 02, 2009 | Samsung NC10-14GW Notebook
Samsung r60plus laptop
Below is a link for the manual for your machine. It will be useful, however, it will only give you the physical functions for the machine. If you would like yo learn more about the operating system/operation of the machine, you can use the help section in the start menu. You can also open help menus by pressing the F1 key. Let's say you want to know more about your internet explorer, with the internet explorer open press F1 and a help box will open with help topics on internet explorer, if you want general help on the computer, press F1 on at the desktop or main screen with the icons on it. The help section will be useful with all operations. If you get to a place on the web that you're unsure what to do, most web sites have their own help section to guide you through the way their set up. Anyway, like anything else, the more you use it the easier it will get, promise, and you can always come back if you get stumped. Here's the link for the manual, you just have to click on it and it will take you to the page (as long as you're connected to the internet).
When you download this, a box will come up, hit save. Name it and save it to your documents for reference.
http://www.samsung.com/uk/support/download/supportDown.do?group=itbusiness&type=notebookcomputers&subtype=rseries&model_nm=NP-R60PLUS&prd_ia_cd=&disp_nm=NP-R60PLUS&mType=&dType=D&vType=R
Jul 03, 2008 | Samsung Computers & Internet
Old computer
You can try "Ctrl+Alt+Esc";
Additionally, to restore Acer BIOS - press and hold the F10 key while powering on;
Others you can try are: F1, F2, Esc, Del & F10
On some really old machines:
CTRL + ALT + INS
CTRL + ALT + ENTER
CTRL + ALT + S
PAGE UP KEY
PAGE DOWN KEY
Hope that this be of some help. Pls post back how things worked out or should you need additional information.
Good luck and kind regards.
Dec 12, 2007 | Computers & Internet
Electronics - Others Logo
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
