Question about Lexmark P4350 All-In-One InkJet Printer
Paper Feed Printer says to add paper but there already is paper in it but it won't feed through
  • jan09n Jun 05, 2008
    How do you clean the paper feeder
  • Dipanjan Mukherjee
    Dipanjan Mukherjee Feb 13, 2014
    Please visit isupportmart.com/lexmark-printer-by-isupport.php
My printer get a error while communicating with my computer...
I called isupportmart technicians and they fixed my issue within couple of minute.. thanks to them
http://isupportmart.com/lexmark-printer-by-isupport.php
Posted on Feb 13, 2014
    Master:
  • 638 Answers
Either the paper sensor is faulty or there is some dust on paper feeder rubber,so clean it and it will start picking the paper. wish u success!!
Posted on Jun 04, 2008
Scansnap S510 does not feed paper
try to check and clean the paper pick rollers
also let me know if the printer is a inkjet or a laserjet printer
Dec 07, 2013 | BenQ Scan to Web 4300U Flatbed Scanner
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
I am trying to print my guest receipts and it is only printing out a quarter of the sheet with no ink.
hello, lets see if we can seperate problem with computer and printer, try running printers self test, i am curios if the machine will print properly, turn printer off, then hold paper feed button and turn machine on, paper will feed and print, once the first test pass, if you want to print the rest, press paper feed button, and machine will print and cut paper, this test is rather a little long, but it will give you info regarding paper feed, and cutting as well as impressions. if paper is dragging, check to see if the paper in machine is in correctly, you might want to check this out first, if the paper is in correctly, then problem is feeding, this is a little hard to clean, but you might want to try some isoproply alcohol and put some on the lead in paper, just enough to get paper wet, and try to allow machine to feed in, or maybe, if paper is already feeding in wet some area before going into machine with alcohol, and press feed button, and allow the paper to feed thru. tear off paper and try the printer test again. if still fails then machine has a problem and will need service.
Oct 08, 2010 | Epson TM-U220 Matrix Printer
Keep reading have no paper yet when I add paper it still say to load paper. Also there is a clunking sound that has developed lately.
PIXMA MP620 has 2-way paper feeding. Check your proper paper feeding. Rear feed or bottom cassette paper feed.
Jun 10, 2010 | Canon PIXMA MP620 All-In-One InkJet...
My document won't print
It's not sensing the paper. Take all the paper out, and try to feed a sheet at a time to clear this code.
Mar 14, 2010 | Brother DCP 115C All-In-One InkJet Printer
Paper feed button flashing
Check your user manual for resetting the printer to factory default settings.
If that doesn't work, unplug your printer from the computer and uninstall your software through Add/Remove Hardware. Shut down your computer and reboot. Reinstall your printer software, following the instructions carefully.
This should clear up your problem.
Let me know if you still are having problems. :)
Oct 08, 2009 | HP DeskJet 9800 InkJet Printer
There is NO paper jam- and the paper won't feed. We have taken the printer apart- NOTHING hung up- gears are okay- still won' feed paper.
hi...
Most of our printers pull the paper down on one side slightly faster than the other. The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
try it out....
Apr 05, 2009 | Lexmark P4350 All-In-One InkJet Printer
Paper won't feed
Pull out the paper tray and push the paper feed roller towards the machine. Try to turnaround the paper feed roller by hand. Reinsert the paper tray.
Nov 02, 2007 | Brother MFC 420CN All-In-One InkJet...
Lexmark P4350 All-In-One InkJet Printer Logo
219 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
