Question about Sharp AR-BC260 Color Copier
Sharp arc262 Hi, I have now got a new massage for maintenence code fk,any idea what is that and how it can be fixed,also how can i check life of consumables? regards mujh92
  • tahir malik Jun 08, 2008
    extreemly helpful advice
    Sniper:
  • 54 Answers
FK is Fuser Kit. You can check supply status by hitting P * C * then 22 start then 1 start. You can scroll down pages. Alot of the numbers displayed will make no sense to you, because they are values not meter counts.
Don't forget to rate your answers please.
Posted on Jun 08, 2008
My sharp MX-C311 shows maintenance required Code TA
Hi, TA code refers to maintenance all counter has reached its specified limit. This usually means all the consumable parts have reached the end of their service life. If you have a maintenance contract with a Sharp dealer then they should replace all the units that require replacing & reset the maintenance counters for you, if you don't then, if the copy quality is still ok, you should be able to continue to use the machine as normal.
Hope this helps.
Dave.
Oct 15, 2017 | Sharp Office Equipment & Supplies
I need the code of Sharp Tv model 21 - V - FK - 200M
Check 012, 110, 132
for more details check the bellow link. fin the code for your remote suing the search tab , add the brand and model number for the remote there.
www.electro-medical.blogspot.com
Oct 27, 2015 | Sharp Televison & Video
What is sub code of fk1
FK1 refers to the maintenance life counter for the fuser unit.
The fuser rollers have a fixed life count & when that count is reached FK1 is displayed. If the rollers are worn they should be replaced but if they are ok you can reset the fuser maintenance counter in SIM 24-4 FUSER UNIT
Aug 08, 2014 | Sharp MX-2300N Color Copier
How can I properly maintain my leather electric massage chair to ensure long life?
Massage chair maintenance is crucial, especially if your chair is made from leather. First always check the tag attached to your chair for cleaning suggestions or you could contact the manufacturer. If none of these options are available, here is what you can do. Basic cleaning can be done using a gentle moisturizing soap and a soft cloth. Remember when doing so that your massage chair is made up of mechanical materials so it is very important not to over-saturate your chair while cleaning. It is also very important to dust your massage chair regularly.
Aug 06, 2012 | Furniture
Maintenance code TA does the printer go offline
Ok so the TA code means that the all maintenance counter has reached its limit
To clear this you need to clear this easy you want
# , * , c , *
To enter service mode
Type in code 24 press start
Then you want sub code 04
Then you can select what you want to clear so the maintenance count all
Execute this yes then press the CA key the machine will restart and away you go
I also do advise that you service representative comes along at some point to check the machine it could need parts because if you stretch the life of parts your machine could become unreliable... But that is up to you.
Jun 05, 2010 | Sharp MX-2700N Color Copier
Sharp AR BC-320 maintenance codes FK and TK?
FK
TK
Low toner density in the developer
Aug 25, 2009 | Office Equipment & Supplies
What do it do to fix ''maintenance required Code: CA''
The service acces code C-0-0-C,or C - interupt key -0-interupt key.Acces the list of commands maintenance preset counter setting and set to a new value,or maintenance counter clear.
Aug 01, 2009 | Sharp Office Equipment & Supplies
I am getting a message "maintenacne required code:dk"
DK means the black drum has reached its maintenance life - 50k copies. you need to buy an ARC26DU drum unit. The drum counter will need to be reset after its installed.
here is a starting point : http://electronics.pricegrabber.com/fax-copier-supplies/Sharp-ARC26DU-Developer-Toner-Drum-Cartridges/m12754437.html
Hope that helps.
Apr 10, 2009 | Sharp AR-BC260 Color Copier
Sharp arc 262 m
It means the drum for Cyan is due for replacement. Can reset with sim 24-7. Hit P * C * on control panel hit 24 then start (copy button) then select 7 enter. Select Cyan or C. Hit execute, then Yes. After complete hit CA button twice.
Don't forget to rate your answers please!
May 28, 2008 | Sharp AR-BC260 Color Copier
Maintanance kit replace
Problem:
The machine displays the Replace Maintenance Kit after the Maintenance Kit has been replaced.
Cause:
There may two causes for this issue.
  1. The machine does not recognize that the Maintenance Kit was removed. This would likely be caused by a defective Drum Maintenance Pivot Plate.
  2. The machine corrupts the CRUM on the new Maintenance Kit. This may be caused by a defective Drum Maintenance Pivot Plate or IO Board.
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix.
  1. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message does not change to "Maintenance Kit Missing," replace the Drum Maintenance Pivot Plate and install a new Maintenance Kit.
  2. While the Replace Maintenance Kit message is displayed, remove the Maintenance Kit. If the displayed message changes to "Maintenance Kit Missing," replace the IO Board and then install a different NEW Maintenance Kit. If the problem persists, replace the Drum Maintenance Pivot Plate and install a different NEW Maintenance Kit.
ETI v1.3.20.0 610606.Replace Maintenance Kit Message after it Has Been Replaced 2007-11-18 21:37:39
Mar 30, 2008 | Xerox Phaser 8400 Laser Printer
Sharp AR-BC260 Color Copier Logo
240 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
