Question about Logitech Webcam
Unable to communicate on msn with my genius videocam look webcam
Webcam is working fine, but others unable to hear me. have been into control panel and into sounds and devices, but still no luck. the testing scale for both recording and playback does seem to be ok. does my computer need a sound card, or does softwear come with webcam? thanks julie.
  • Logitech Master
  • 2,935 Answers
Have you set your mic to default ?
If you have a laptop - you already have a built in mic and if you have another with your webcam you need to make it 'default'
MIC SET-UP :- VISTA
TEST SPEAKERS
Right click on speaker icon in System Tray Select "Playback Devices" The speaker icon ( checked as working) and volume level graph should be visible Right click on the volume graph and click "Test" Left hand speakers followed by right hand should be heard
SET MIC DEFAULT & TEST
Click "Recording" tab. Set required mic as default - click on mic font to highlight and click "Properties" In lower dropbox display "Use this device enable" click OK Click "Levels" tab and set slider to 80% ( adjust to suit later) Return to "Recording". Test mic by speaking and make sure volume graph displays
Re-start Computer.
Now you have a default mic on your computer you have to make sure it is recognised in any chat program you want to use.
Do this by opening up the program and finding the default option
MSN = Open menu > tools > audio & video setup
Yahoo = Messenger >Preferences > audio & calling
Skype = Tools > Options > Audio set-up
Posted on Aug 24, 2009
    Scholar:
  • 33 Answers
Please rate me afterwards Step 1: The "Tools" menu of Windows Live Messenger
1. Recover Windows Live Messenger in our software if you do not have it yet.
2. Start the installation of the software.
3. Once this is done, go to the Tools menu software.
In this menu, two links are important in order to properly configure your camera:"Setting audio and video" and "Parameters of the webcam."This is the first that we will discuss first and foremost, the second used primarily to adjust the parameters of the image in the secondary stage but we are dealing with. Launch therefore setup wizard and click on "Next".
Step 2: The setting of loudspeakers
1. Select your hardware in the menu.
2. Check the box if you use a helmet.
3. Test finally your sound output in order to adjust the volume.
It is possible that you find in the menu several choices. That means you have several elements in your computer capable of transmitting sound, a dedicated card and your motherboard, for example. In this case, make sure to select well the correct input, what you quickly verify the test by loudspeakers.
Step 3: At the turn of the microphone
1. Select your sound source.
2. Start talking to your microphone.
3. Observe the cursor, if it moves, your microphone is working.
Two remarks on the stage configuration. On the one hand, if your camera has no microphone, you must go through a device that you must annex plug into the pink on your sound card. On the other hand, if your mouse does not work, you may have selected the wrong input device sound. Take particular care in this setting and not leave this page only when the cursor s'agitera,
indicating that your voice is recognized by the software.
Step 4: Turning finally to the image
1. Specify this time the source of the video.
2. Observe the window of return: if your setup is satisfactory, your image should appear.
3. Adjust the frame rendering through the "Option" button.
Posted on Aug 06, 2009
I don have my cd and i need download the software
Genius VideoCAM Messenger is the best choice for you to chat on MSN and share real image with friends is our latest VideoCAM Messenger. Follow this link to Softpedia to dowload the software... http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/GENIUS/Genius-VideoCAM-Messenger-20.shtml
Jul 12, 2010 | Genius VideoCAM Messenger Webcam
I can install my web camera but can't play on windows live
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
May 19, 2010 | Genius VideoCAM Eye Web Camera
I am unable to get my genius 310 working
Try here
http://www.nodevice.com/driver/company/Genius/PC_Camera.html
Post feedback - good or bad - to help others
May 06, 2010 | Genius VideoCAM Messenger Webcam
VideoCAM Express V2 CD key and series number
i cant install my genius webcam videocam express v2.....pls help me...thank you
Apr 05, 2010 | Genius VideoCAM Express Webcam
I need to install my genius videocam nb 100 cam!
That webcam is currently called GF112 /mine wanted to be called an NB 100 too but it worked as a GF112 only/:
http://drivers.softpedia.com/progDownload/Genius-VideoCAM-GF112-Webcam-Driver-1-00-00-Download-43141.html
Please let me know if it worked.
Feb 16, 2009 | Genius VideoCAM Messenger Webcam
VideoCam Messenger No Video
This is how I got the VideoCam Messenger to work on a computer running Windows 7 (32-bit):
VERY IMPORTANT!!!!!!!: DO NOT restart your computer at any point until the very end of these steps.
1. Plug in the webcam.
2. Windows will install their weird Sonix driver from 1994 automatically.
3. The most crucial part: Click "Devices" in the Windows Control Panel. Click on the USB Camera (whatever the webcam is called)... then you need to go to the "Properties" until you can UNINSTALL the driver that Windows automatically installed. I think you have to click Properties twice to be able to get to a place where it lets you uninstall the driver.
4. DO NOT restart.
5. Download this: http://download.geniusnet.com/webcam/VCMessenger_V.zip (Incase the link is broken, this is directly from the GeniusNet website and it's called "VideoCAM Messenger Driver for Win 7 / vista 32 bit")
6. Install this completely, but DO NOT restart. (Also, make sure you click "Install this anyway" when it asks you about being an unsigned driver.)
7. After you do that and you DO NOT restart, it will automatically come up with a screen that shows Windows installing the driver, but this time it's installing the actual driver from the software you downloaded in step 4.
You may now restart your computer if you want.
If you do these steps correctly, I guarantee you will have your VideoCam Messenger webcam working.
Nov 14, 2007 | Genius VD3000022 Webcam
Internet cam
By GENIUS website, the combo version isn?t supported by messenger You can find drivers that will help you in the Microsoft website Or you can use a aid program recommended by GENIUS " VideoImpression by ArcSoft " Hope this will work Good luck Digger
Feb 23, 2006 | Genius VD3000022 Webcam
No sound on internet video chats
according to the Genius website, MSN doesnt support the combo version (cam + mic). check in microsoft website for drivers that can solve it. you can also you this software recommended by Genius - "VideoImpression by ArcSoft "
Feb 22, 2006 | Genius VD3000022 Webcam
Logitech Webcam Logo
122 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
