Question about Samsung Cell Phones
My Phone is out of battery, so i plugged in the usb cable to my laptop to charge it up this normally works for it. But it switches on when i plugged the usb cable into it only comes up with charging what it is suppose to but then switches back off, like its wiped out.please help im 15 and i need my phone.
    Problem Solver:
  • 9 Answers
You need to have installed program for that,i think...
Posted on Jun 04, 2008
My Samsung s5 is not charging
try this
SAMSUNG GALAXY S5 - NO POWER, BATTERY, CHARGING AND CHARGER ISSUES alltabshighlighted.jpg
No power, battery, charging and charger issues
This guide contains troubleshooting steps and advice to help resolve issues you may experience when attempting to charge the handset.
After performing each step, please test to see if the issue is resolved.
Symptoms:
  • Battery not charging
  • Battery is not lasting long
  • Phone won't charge
  • Charging error
  • Failure to charge
  • Display remains black or blank
  • No power
  • Boot failure
  • Overheating
Troubleshooting Questions
  • Are you using the correct equipment?Make sure you are using an approved Samsung wall charger and USB charging cable. Other brands of charging accessories may have different voltage parameters and could cause charging issues when used with Samsung devices.
  • Have you charged your phone for longer than 30min? Leave your phone plugged in to the charger for about 30min without powering on. In some cases, it may take slightly longer for your phone to charge.
  • Is the battery icon displayed on the screen when charging? After charging your phone for a little while you should get a battery charging icon appear on the screen which will indicate that your battery is charging properly.
    If the charging icon appears, leave your phone for a little longer before you try to switch your phone on.
    If however, the screen is blank and nothing is displayed, follow the below troubleshooting steps.
  • Is the charging cable plugged into a USB port? Some charging cables can disconnect from the wall outlet adapter and plug directly into a USB port. However, when plugged into a USB port, the charging process is much slower due to the limited power output of USB ports. Instead, plug the device directly into a wall outlet to speed up the charging process.
  • Is the outlet faulty? Try a different outlet or check for a switch connected to the outlet. If possible, try powering a different device on the same outlet.
  • Does another USB cable, or wall charger work? Charging issues can occur if either the battery or charging cable is damaged. Verify that the charging contacts are clean. If necessary, clean the contacts using a cotton swab and rubbing on isopropyl alcohol.
    If possible, test the charging cable by plugging it into another device and seeing if the device charges. Alternatively, try charging the device with a different cable. This may mean changing out the cable or the adapter on two-piece chargers.
    If charging through a car charging kit, ensure that the car engine is running, and if possible try to charge other devices using other cables, through the same car kit. If none will charge, then it is likely there is a fault with the car charging kit. It is recommended to continue to cross-test devices, cables, and car kits until the problem device can be identified.
    If the device charges when using a different USB cable or wall charger, the issue most likely lies with the charging accessory. In this case, follow the approved charger repair / replacement process.
    Also, if the charger is connected via an extension or other multi-socket adapter, remove this and plug the charger directly into the wall-mounted socket. This will eliminate the possibility of a fault with the adapter.
    If you are still unable to charge your device, continue to the next step.
  • Has the phone experienced any shock or exposure to water? Accidental physical shock to a handset can sometimes cause problems to arise with battery or charger, as these components contain delicate parts, particularly. Damage can occur either to the component itself, or to the component's connection to the motherboard.
    Water exposure can also lead to damage of these components, however due to the slow way in which this type of damage can manifest itself, the cause may not always be readily obvious.
    With any physical damage of this nature, the only recourse is to contact the device manufacturer, and follow their approved repair or replacement process.
^_^
Jul 04, 2014 | Samsung Galaxy Cell Phones
My iphone not charging and on..help me!! :(
1. Check your charger with another iPhone. If it is working, your battery may be dead. If not, replace the charger. You can buy some at www.amazon.com or any other site you like. 2. Try charging the phone on your laptop via USB cable. Hope this helps. If so, please rate. Thank you
Jan 15, 2011 | Apple iPhone Smartphone
I am overseas and have been using my USB cable to charge my LG phone via my laptop. My laptop has been stolen, so is it possible to to charge my phone if I plug it into my friend's laptop using my USB...
It is not necessary to have the software downloaded as the USB is a universal port.So check to see if another USB port can be used on the laptop. However I would like to advice that such chargers are easily available and very economical( the chinese models could be less than $5 ) which will be the best for you than to always load up the laptop. So this becomes convenient and the battery of the phone will charge with the right current capacity required.
Dec 23, 2010 | Cell Phones
Blackberry curve 8900, red light will come on for eight seconds when connected to AC power then a battery with a blue lightning bolt will show up on screen. Once AC is removed device goes blank. I've put...
The battery is drain.
DO NOT use the USB cable to charge your Blackberry.
When the PC/Laptop/Mac go to power saving/SLEEP mode it will cut off the charge to the Blackberry.
Use the official AC charger to charge the Blackberry.
Make sure the AC power is not switch off to the power pack at night.
The mini USB connector can be loosen over time.
Plug in the cable and check for connectivity.
Oct 19, 2009 | Cell Phones
Phone can't charged & always being low battery & don't be switch on
check plug point and change the batteries then try to usb cable
May 30, 2009 | Motorola Mobility RAZR V3
HTC S710 Smartphone not switching on
The battery is flat.
If the battery is very flat sometimes the phone will not start charging or turn on even when a power cable is connected.
This worked for me:
- Remove battery
- Insert power cable/usb cable
- Orange charge light should start flashing
- Re-insert battery
- Leave phone charge for a couple of hours
- Turn on
Feb 03, 2009 | HTC S710 Smartphone
LG Secret charging
Dr Know, doesn't know what he's talking about. I have a LG KF750 and have experienced the same problem.
Solution - Really jam the cable into the socket! The connection is pretty rubbish. The phone charging icon will (with some force and wiggling) appear on screen. Then carefully put it down and don't touch it!
USB charges very slowly, if charging from a dead flat battery it may take a good 20mins of charging to boot up.
P.S. the red camera light is not supposed to come on when charging. Keep wiggling the cable and the light will go off when the phone charging icon appears.
Dec 16, 2008 | LG Secret ? KF750 Cellular Phone
Charging problem
I had this same problem, it's really irritating. Not exactly a full solution, but if you leave your phone connected to the usb for around 10 - 15 mins then disconnect it, remove and replace the battery and turn it on, it should have enough power to boot up, the just reinsert the usb and it should charge.
Dec 04, 2008 | LG Secret ? KF750 Cellular Phone
Motorola A1200 Problem
Easy step by step solution!
Hey guys had the same, Try this solution before buying a new battery/charging cable (it might not be the problem):
I did these steps after playing around with it for awhile and am at the stage where my phone turns on fully and says "Battery Charging" when plugged into the charger. It is now charging normally again... Finally! (I had the flashing moto logo too when charger plugged in) I believe this problem occurs because the battery is completely drained and is unable to turn on to charge bcuz the phone needs to be on to be charged, happened to me because i left it in a jacket pocket and forgot about it for weeks. Anyways...
1. You need a USB data cable for it, it should have come with the phone, if not than any USB data cable that fits the phone's charging slot should work (charge cable for the ps3 controller will work or maybe a cable from a digital camera with the same end)
2. Connect the phone to your computer via the USB cable and a USB port that works. Make sure it's plugged in and leave it (even if nothing happens and the screen on the phone is still blank). Although the screen is black, the phone is still charging via your computer (it's just too low on battery to produce the light on the display screen to load up your phone).
3. This might take anywhere between 15 and 45 minutes so be patient and leave it plugged in, beats buying a battery of charger with your money for something that can be solved for free.
4. At some point your computer will make the usual processing noises signalling that it is finally recognizing the phone as a usb device and shortly after your ming's screen will turn on stating that the battery is charging. Success! One of two things will happen, if you have previously installed the ming's drivers to your pc it will just recognize the phone. If you are like me and do not have the drivers installed, you may choose to do so via the cd that came with the phone or just not do it at all.
5. If you want to just charge it via the computer then congrats, your job is done, just leave it plugged in and wait until it is fully charged. If you wish to switch to your regular outlet charger please proceed to step 6.
6. At this point drivers installed or not, either safely remove device from the computer or just unplugg it. Now return your phone to your usual outlet charger making sure its connected. When plugged in you'll notice the moto logo appear (no longer flashing). After about 5 seconds that logo will disappear. At this time flip open the phone. The usual turn on sequence will play out and it will now load up with the battery charging screen similar to the screen from when it was plugged into the computer. Congratulations your phone should be back to normal now.
NOTE: This charge will take longer than your normal charging time but that's just for this time since your battery is super low it will be back to normal after that. Also if this did not work for your phone then now is the time to see if the charger/phone/battery is the problem.
So I hope this helps you out and eases your state of panic. I hope I saved you guys some money with this solution and that your mings are up and running again. I know i was pretty content when the problem was fixed. Please reply with any comments, questions or concerns you may have. Enjoy your once again working mings.
Jan 24, 2008 | Motorola Mobility MING A1200
Unable to charge
There could be corrosion on the charger, or the connection on the phone? If so, remove the battery and clean them both with a toothbrush and Isopropyl Alcohol. The phone may have gotten wet? Check behind the battery, there is a water indicator. Its normally white, if its gotten wet, it will be red. Best of Luck.
Sep 14, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
27 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
