Error code of ricoh af1053SC 321.322. 326
I have a problem of my ricoh copier model af1035,it keeps giving error codes 322,321,326
    Brigadier General:
  • 6,966 Answers
To my knowledge below error codes refer to:
1. 321 - No Laser Writing Signal (F-Gate)
Error-1 Transfer Belt Signal Error
2. 322 - 1st Laser Synchronization Signal Error
3. 326 - 2nd Laser Synchronization Error
G Gate 2 Error
This would be a possible Laser failure or the transfer belt and would require service confirmation and possibly replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 04, 2008
some potentially useful information can be found here: what the error codes mean, and the services manual; (I have pointed to error code 792 but the others are different pages), there is a copy of the service manual too. This is only a starting point ! 2022&page=6
(link hasn't copied well, last line is part of it)
Try also this
for Error sc792 see
for sc870
Thread Ricoh 2238c SC 870 Address book error
for sc548
Thread RICOH Aficio MP C3500 Error Code SC 548 and 549
hope that lot help :)
May 25, 2016 | Office Equipment & Supplies
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer:
I do find the error code for a different Ricoh model (Aficio 1018).
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
Sc 900 error code appear
You don't mention the make or model of your printer/copier, but a quick Google would indicate that it is a Ricoh machine.
I give below a link to a site which lists many models of many makes of printer and error codes. their description and cause, which will help you identify what is wiring and correct it:
Error Codes Ricoh Aficio SP4100N Code 900
On this site you can change the make, model, and error code on your machine by using the drop down menus near the top of the page. Also you can download a pdf format Service Manual for the machine by using the link just above the error table.
Hope this is helpful, if so would you please register that with Fixya
Nov 30, 2014 | Office Equipment & Supplies
My ricoh aficio code a 990 how to fix them ?
An SC990 is usually an error indicating maintenance is overdue. The only way to verify that is by printing out the SMC report and seeing the subcodes. In the case of this model when is the last time the drum and developer was replaced?
Nov 15, 2014 | Ricoh Aficio 1015 All-In-One Laser Printer
Streak in the middle of the copie/print with drum and blade replaced
Please clean the drum charge roller use the izopropilalcool,clean the charge roller cleaning roller,clean use the vacuum cleaner the waste toner (located under transfer assembly 6 screw),activate the ATDC and AIDC sensor configuration.
Jan 08, 2012 | Ricoh Aficio 1035 Copier
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
RICOH Aficio copier is giving error code SC320, what is the problem?
i have a ricoh aficio 450 pick the paper from the tray and after afew seconds the paper will come without coping.(plain paper)
Jun 14, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio MP 161 giving me an error code of SC670 and SC 980. It stops working all the time and I have to turn it off and back on.
One of the following controllers is
installed to the basic model:
* The controller of the MFP
copier/facsimile model
The controller of the optional
printer/scanner is installed to one of
the following models:
* The MFP model
* The copier/facsimile model
* The printer/scanner/copier
Dec 04, 2009 | Ricoh Aficio 450 Copier
Error Code SC541
The Fuser Thermister is not working properly. The Fuser may need to be replaced or the two Thermisters need to be replaced on the fuser. This is what the code is calling for. A local Ricoh tech should have these parts. Hope this helped!
Mar 13, 2009 | Office Equipment & Supplies
Service codes of Ricoh FT5832
send me an email I can help is it a 450 or 5832
Feb 18, 2009 | Ricoh Aficio 450 Copier
165 people viewed this question
