Question about HP LaserJet 4 plus Printer
Printing is too light on the right side of paper
I just moved my printer from one place to another and now the printing is not consistent on my pages.
    Brigadier General:
  • 6,966 Answers
possibility is that the toner particles inside the cartridge has been displaced and unevenly spread when the printer was moved. Try removing the toner cartridge, shake vigorously, to even out the thin powdery toner particles inside.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 04, 2008
How to copy 2 sided
If your printer does not have a duplex unit then the printer cannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn the page upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for the rest of the document.
I suggest you try a test page first, to get the printing the right way up on both sides of the page so it reads correctly.
Mar 31, 2013 | HP Office Equipment & Supplies
Brother 4800 printer how to print on both sides
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Apr 28, 2012 | Brother MFC 4800 All-In-One Laser Printer
Epson 1400 will not use double sided paper
Mar 04, 2012 | Epson Stylus 1400 InkJet Photo Printer
How to print on both sides of the paper in canon lbp2900?
Jun 06, 2011 | Office Equipment & Supplies
I'm having problems with my 1720 Dell printer...the load paper light comes on after one page printing out however I can occassional get it to print if I cancel the job and put paper in the manual feeder...
it sounds like your driver is set to print to the manual feeder OR set to a different paper size (like legal) Check your driver settings under printers in the control panel. (it'll be along the lines of "paper type" or "tray settings" under printing prefrences. Just as a heads up, it could also be the software causing the issue. MS word tends to hijack settings and create problems as well.
CHeers
Jan 05, 2010 | Dell 1720dn Laser Printer
Printer cuts off 1'' off print on the right side of paper all the time. It doesn't matter what our margin settings are. What could be the problem?
Print a test page by holding down the UPPER LEVEL button for 2 seconds.
If this test page prints fine it may be a driver issue.
If the test page has the right side cut off as well then something is blocking the laser on that side of the printer. Most likely place is something around the drum cartridge area. If you are familiar with the printer and this cartridge you can try removing it and checking this area for a scrap of paper or something blocking the laser light from reaching the drum.
Oct 18, 2009 | Samsung CLP-500 Laser Printer
Paper feed not move
If I recall the KXP series, it is a track feed printer as well as sheet feed, there should be a lever on the top that you can move to different positions, one position is for feeding paper without the rollers, when the lever is placed in a different position it releases the rollers so the printer can feed the paper. The open position is for installing paper or clearing paper jams. Also if I recall, the lever is on the right side near the roller on the end. When you move the lever, and turn the roller, you fill feel it grab the paper. There is also a switch on the front for line feed and page feed allowing you to tear off a page and then pressing it again will reverse the paper to print position.
Aug 30, 2009 | Panasonic KX-P3696 Matrix Printer
Even thought there is NO paper jam, I still get an error message:
Please try this solution :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Feb 19, 2009 | HP DeskJet F4280 All In One Printer InkJet
Carriage jam on hp photosmart printer
The print carriage may get stuck on either side or in the middle of the printer. The Carriage Jam: Open Door, clear carriage jam, and then press OK to continue error message may display on the front panel of the all-in-one.
Solution
The print carriage is the device which contains the print head and moves left to right during printing.
Figure 1: Carriage Assembly
To resolve this issue, follow the steps below in the order presented.
Step one: Print a Self Test
Follow the steps below:
1. Press the Setup button.
2. Select Print Report and press OK .
3. The self-test page should print. If it prints a test page, there is no need to follow the remaining steps, as the error message may be false. Make sure the printer now prints from the computer (if installed on one). If it does not print, proceed to the step two.
Step two: Clear the paper path
Follow the steps below to clear the printer of any jammed paper and reset the printer.
1. Leave the printer on and then disconnect the power cable and the USB or Ethernet cable from the back of the printer. Do not reconnect them until instructed to later.
NOTE: Make sure the printer is on before disconnecting the power cord. Failure to disconnect the power cord from the rear of the unit can cause damage when removing jammed paper.
2. Open the top access door.
Figure 2: Opening the top access door
3. Make note of where the carriage is stuck and look for jammed paper. A paper jam can cause the error message and the carriage stall. Some paper may be jammed in different locations than those shown in the photos below.
Figure 3: Paper jammed on the left side
Figure 4: Top view of paper jammed on the left side
Figure 5: Paper jammed on the right side
Figure 6: Top view of paper jammed on the right side
NOTE: Do not use any tools or other devices to remove jammed paper. Always use caution when removing jammed paper from inside the unit.
If the carriage is stuck on the right side:
a. Check for any paper or object that may be restricting the carriage.
b. Move carriage all the way to the left side.
c. Check the paper path all the way to the right side and remove any paper still in the printer.
If the carriage is stuck on the left side:
d. Check for any paper or object that may be restricting the carriage.
e. Move carriage all the way to the right side.
f. Check the paper path all the way to the left side and remove any paper still in the printer.
If the carriage is stuck in the middle:
g. Check for any paper or object that may be restricting the carriage.
h. Move carriage all the way to the left side.
i. Check the paper path all the way to the right side and remove any paper still in the printer.
j. Move carriage all the way to the right side.
k. Check the paper path all the way to the left side and remove any paper still in the printer.
4. Remove the rear access door or duplexer (if installed) from the back of the printer.
5. Check for and remove any paper still in the printer.
6. Replace the rear access door, and close the top access door.
7. Reconnect only the power cable. If the printer does not automatically turn on, press the Power button.
NOTE: The printer may go through a warm-up period of up to two minutes. Lights may flash and the carriage may move. Wait until this warm-up period is complete before going to the next step.
8. If the Power light is on steady, print a self-test page as done in Step one.
If the Power light is not on steady and the carriage is still in a stalled position, proceed to the next step.
Step three: Plug the printer directly into a wall outlet
Verify that the printer is properly connected to a suitable power source by following the instructions below.
1. Verify that the computer and the printer have a three-prong power plug.
2. Remove the printer cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
3. Try the print job again to see if this step resolved the issue.
NOTE: If the printer prints when plugged directly into a wall outlet while disconnected from any power strips or surge suppressors, the power strip or surge suppressor may not be allowing sufficient voltage to reach the product.
4. If this did not resolve the issue, proceed to the next step.
Step four: Service the product
If you have completed all of the steps listed above and are still experiencing a problem, service your product.hope this helps
Jan 05, 2009 | HP Office Equipment & Supplies
HP LaserJet 4 plus Printer Logo
89 people viewed this question
Seeker5211
Seeker5211
