Question about D-Link DP 301P (DP-301P) Print Server
DP-301P+ Express EtherNetworkTM Fast Ethernet Print Server
How can i recover DP-301P+ Express EtherNetworkTM Fast Ethernet Print Server defult IP?
help plzz
  • 2 more comments
  • jinpuli Jun 20, 2008
    how to configure the IP in printer server DP-300U
  • shobyDEL Aug 22, 2008
    I change the IP as well as Workgroup Information after that my Print Setrver IP not pinging and i am unable to retrieve it
  • Bond 003 Dec 01, 2008
    How to change the IP address of DP-301P+ print server.
  • Trevor Lewis
    Trevor Lewis May 11, 2010
    Do you mean you've lost the IP to it and are now unable to find it on your network, or did I misunderstand your question?
    Problem Solver:
  • 20 Answers
You need to connect to it (using the broswer at the PC of same LAN with the current ip of the print server). Then click on Tools TAB, click on "Reset" at left. You should see "Do you want to restore this device to factory default setting?". Click on "Apply"
Posted on Dec 01, 2009
  • typien Dec 01, 2009
    The first step, is to connect the DP-301P+.
    Connect the print server to a router which acts as DHCP server, that will assign a local ip to the print server. Use the PC in the same LAN and logon to the router, find out the ip that has been assigned to the printer server (such as in the link of "Attached Devices"). (Give the router some time, it may take couple mins to be appeared there, try "Refresh" the list) Then try to connect to that address. The D-Link, DP-301P+ can connect with the DHCP client address OR the manually assigned fixed ip address (which is default at or any ip that you assigned.) (note: the ip of the PC need to be at same subset.)
Change ip address
The IP address is configured through your DHCP server in your router. You're going to have to either look in your router for connected devices or use a tool like netscan.exe (free) to find the assigned IPs in your network, If you don't have too many connected devices, you can keep putting the IPs that are there into your web browser until the device page comes up. They SHOULD HAVE put a reset button on this thing, but they didn't.
Aug 17, 2013 | D-Link DP 301P (DP-301P) Print Server
I want to reset the print server D-Link DP-301P+. I forgot IP address which I was changed according to network settings.
There are two steps that we can suggest,
1) Install the psadmin software if you have not already. If you have lost the psadmin software then search for it on the web.
2) Start the psadmin software and click "factory reset".
3) If the software demands a password, try "SYSxxxx", where xxxx stands for the last four digits of the MAC address located on the underside of your server. (Example: if your MAC address were "63 XE 29 44 F2 96", then your password would be SYSF296.)
4) Click yes to confirm the reset.
On the back of the print server you will find a pin hole, insert a paper clip for 30 secs with the print server powered on. All lights will flash. Try to setup the server again.
Hope this helps.
Jun 01, 2011 | D-Link DP 301P (DP-301P) Print Server
I have connected the d-link to a KOT printer,my network cannot find the server.And according to the manual I cannot browse the default ip of the DP-301P+ sever.please assist me immediately.
I have D link DP- 301P Print server I am using it in Epson M188D Printer for KOT Printing but its shows some times printer not found on network, please help me to solve the problem.
Mar 22, 2011 | D-Link DP 301P (DP-301P) Print Server
I have print server DP-301U Pls let me know the default IP address for configuration
As far as I can remember the default IP is 192.168.0 .10, subnet
If this isn't the correct IP address, you'll need to reset the d-link print server Hope this helps
Regards, c0d3
Feb 09, 2011 | D-Link DP 301P (DP-301P) Print Server
Hi sir how can i change ip address for Dlink printer server DP-301P+
Logon to the Print Server web configuration and begin managing the DP-301P+, simply launch the browser (e.g. Internet Explorer) and type dlink-xxxxxx, where xxxxxx are the last six digits of DP-301P+'s MAC address. The MAC address can be found on the bottom side of
the DP-301P+ device.
Default IP Address of DP-301P+ is set as automatically getting from DHCP server or Router with build-in DHCP server. Please note that the PC's IP Address must be in the same subnet as the print server's IP Address for the two devices to communicate. (For example, if print server's IP
Address is, with a subnet mask of, then your computer's IP Address should be 192.168.0.x, where x is a value between 1-254, excluding 10.)
For additional information, please refer to Dlink printer server DP-301P+ Product Manual
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
Jan 11, 2011 | D-Link DP 301P (DP-301P) Print Server
How to reset the administrator password of the D-Link DP-301P+
i forgot password Printer Server D_link Dp-301p
Please Help Me
Jul 30, 2009 | D-Link DP 301P (DP-301P) Print Server
I would know if D-Link DP 301P Print Server supports SNMP protocol because i need to print from IBM iseries thank you
It supports all below protocol so you can give print from IBM iseries .
TCP/IP Protocols Supported :
  • SNMP
  • Telnet
  • TFTP
  • FTP
  • LPD
  • RARP
  • DHCP
Jul 28, 2009 | D-Link DP 301P (DP-301P) Print Server
I forgtten the IP of the Print Server D-Link 300U. Please tell me , that how to reset the IP
usually by resetting it. pushing the reset button on the back it (tiny hole on the back) for 30 seconds, while plugged in to power,
Jun 15, 2009 | D-Link DP 301P (DP-301P) Print Server
Forgotted the Ip of D-Link DP 300U print server
You may use the PSAdmin software to configure your print server even if you don't know the IP address. The only requirement is that the DP-300U has to be in the same network (subnet) as your PC running PSAdmin. In the PSAdmin, you will then be able to view or change the IP address.
Here is the link to download PSAdmin:
Remember that if you also have forgotten the Admin password, you will have to ship the unit to D-Link in order to have it factory reset.
May 10, 2008 | D-Link DP 301P (DP-301P) Print Server
No printing threw terminal service
do you have the options set correctly on the remote computers assistant to use local devices
Dec 25, 2007 | D-Link DP 301P (DP-301P) Print Server
D-Link DP 301P (DP-301P) Print Server Logo
2,142 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
