Question about InFocus LP 820 Multimedia Projector
Infocus LP-820 no power
I have an LP-820 and nothing happens when I plug it in. I took the bulb out and it is blown, but shouldn't I see a light or hear a fan or something?
  • ganstee Apr 04, 2009
    no power
  • 472 Answers
You should get some indication of power even without the globe. This can however be a problem relating to the globe not being inside the projector.
Most projectors use a switch inside so they know when a lamp is installed. Some have several of these and a fuse that is on the lamp unit itself.
Replace the lamp back into the projector and apply power again. If you get lights then you have that much solved at least.
If there are still no power lights at all, then you may have had a power surge that not only killed the globe, but has blown the internal fuse for the power supply as well (or even killed the power supply)
To get access to the power supply you will need to disassemble the whole unit almost. If your not comfortable doing this, then I would advise getting it checked over by your local tech. It could save you hundreds of dollars buying a new lamp when the projector may not be worth repairing.
Posted on Jun 16, 2008
Infocus lp820 i press power can not hear any fan moving lamp turn on with gray light after 10 sec lamp shut off and message says "fan stopped"
you need to replace the fans; they may have burned out. you could try to get one from an infocus service center or send it to them for repair, but know that this is an old machine and parts may not be available. you could try getting a used one on ebay that has a different problem and swap out the parts. if you do decide to send it in or find new parts, try av solutions in ny. they're really good. www.avsolutionsny.com
Nov 12, 2009 | InFocus LP 820 Multimedia Projector
InFocus LP650 will not come on
First try a firmware upgrade. If that doesn't help, it seems it might be a power supply issue since you said the led comes on very light. I repair these power supplies. My ebay id is gtitubro
May 29, 2009 | InFocus LP650 Projector Lamp
Infocus LP530 no power
the power supply needs replacing. sometimes the caps are dried up, but show no signs of damage. when the caps doesn't work, the ps doesn't work.
May 07, 2009 | InFocus LP 530 Multimedia Projector
Infocous LP 530 Light comes on then stops
this could be one of three issues. the power supply. the firmware or the lamp. thebulbman.com
Feb 03, 2009 | InFocus LP 530 Multimedia Projector
Red Spot in the picture of my Infocus LP-820
This would appear to be a componeent failing and I doubt if it is user fixable.
If it unser warranty send it back whence it came,
Further support try here
http://www.google.co.uk/url?q=http://www.infocus.com/support.aspx&sa=X&oi=smap&resnum=1&ct=result&cd=2&usg=AFQjCNFdFuwQfzBpULQpcHnzxmC_n12fdA
Aug 20, 2008 | InFocus LP 820 Multimedia Projector
InFocus LP530 projector not powering on
the power supply needs to be replaced. it goes after a while in this model.
Feb 09, 2008 | InFocus LP530V Video Projector 2000 ANSI...
Infocus LP725 projector
The Projector will turn off after so many hours of running the same bulb module. The counter will turn on a replace bulb LED. Installing the new bulb module should reset the counter and turn off the LED.
Check the projector’s lamp to ensure that it is securely connected
in the lamp module. Make sure by removing it and reinserting it.
Check the cables for problems.
When testing, power up in this order. Projector, Computer monitor, Computer.
A minor power surge may cause the lamp to shut off. Turn the
projector off, wait at least 30 seconds, then turn it back on.
I hope these suggestions help
May 25, 2007 | InFocus LP725 and LP735 Replacement...
InFocus LP 820 Multimedia Projector Logo
724 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
