1995 Mercedes-Benz SL-Class Logo
Posted on Oct 18, 2010
Mersedes sl frant rear wheel size - 1995 Mercedes-Benz SL-Class
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Oct 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
Helped
5733
Points
16
Hi, Your OEM Tire Sizes Are: 225/55-16, 245/45-17, 245/40-18,275/35-18
My 1980 450sl AC works good while in park, when I start driving it blows hot air could this be a vaccum problem?
Well, yes they did borrow the system from Chrysler and the main problem was with the main controller unit where you adjust the temp and has the controls. They were known to separate at the unit allowing vacuum to leak and to cause this problem as well. Typically when it is running, you should be able to put your fingers at the rear of the unit and find the vacuum leak that way.
Need rear wheel for yardpro lawnmower front wheel drive.what is size of wheel or part #
like this front wheel drive
a universal one might do the rear ..not sure
search shows other crafstman wheels and sizes listed in this link
Lawn Mower Parts For Craftsman Lawnmowers Fix Your Lawnmower DIY
anything on ebay
or local yard pro mower repair shop
1helpful
What does ABS in mersedes e320 2003 mean
It stands for "
Anti-lock braking system"
The ABS system prevents the wheels from skidding in low-traction situations.
Top frant lach platic ect broke
the blue box above is not english, close.
FRANT , is front, go that but where is it , NAME THE SPOT.
plastic
ECT, is the ASE name for engine coolant Temperature sensor.
what is broke, ? and was double posted in same bad form.
I have a 2002 Saturn SL, can baccarat passion 1130 black wheel rims fit? if so wat size tire do I put on them?
need to measure the bolt pattern to ensure a proper fit. also the tires used should be about the same overall height as the original equipment size.
Hearing noise from right rear wheel on 99 saturn sl. sounds like flat tire while driving.
If pressing the brake pedal does not affect the sound, buy a pair of rear wheel bearings and pay a shop to install them for you. If the rear brakes have not been serviced in the past 10,000 miles then buy all that stuff, including slave cylinders if so equipped, and have it done as well as you will save on labor as the thing will be completely apart
2answers
I have a Hyundai, Genesis, 2010 coupe, 4 cyl. I have been having problems to establish what type and size of winter tire I should put on this vehicle for best performance both in snow and ice. I have...
HERE IS THE REAL QUESTION YOU SHOULD ASK OF THE DEALERS WHO ARE OFFERING 17" OR 18" TYRES FOR A TYRE SIZE THAT DOES NOT FIT YOUR EXISTING WHEELS......HAVE YOU GOT 17" OR 18"WHEELS???......225/45 ARE GOOD.
Dash lights out in 1998 saturn sl and cant find fuse for it
Lower left dash panel cover has pop out panel on back is a diagram with specific fuse size and purpose Near your left knee left of sterring wheel on dash panel rectangle pop off panel
turn it over voila' directions to the fuses..
How do i find out what size tires are on my 93 SL
Look at the sidewall of the tires that are on the car now. The tire and wheel size are printed on the sidewall, or take the car to an autoparts store and have them check for you. They will not charge for this service. Hope this helped and best wishes.
Front speaker size
6 3/4" front and the same for the rear.
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
