Question about Canon PIXMA iP1600 Printer
Canon Printer The waste ink collector is full.
    Master:
  • 638 Answers
Get your printer serviced so that the technician can clean of the absorber and place it back.
Posted on Jun 04, 2008
SOURCE: waste ink tank full error 5b00
Check out:
http://www.fixyourownprinter.com/forums/inkjet/50418#1
Posted on May 01, 2008
  • 1550 Answers
SOURCE: Reset Waste INk Canon MX318
Waste Ink Counter Reset.
(1) Turn off the printer.
(2) Press and hold the RESUME button, then press and hold the POWER button.
(3) Release the RESUME button, Next press and release the RESUME button two(2) more times in
succession. Note: you are still holding the POWER button). The printer's carriage will "reset"
or move momentarily. If the above was properly performed the printer will enter the
"Service Mode".
(4) Press the RESUME button 4 times, this will select the clear waste ink counter function. The lamp
will alternate (change) color with each key press.
1. Service/Factory test printout, including ink sensor check.
2. EEPROM - Info printout.
3. EEPROM - Initialization.
4. Reset the Waste ink counter.
5. Printer model setting. (More selections beyond this point - However it is best leave them unaltered - You have been warned!)
After selecting the desired mode (eg 4), press the POWER button to "set" the change, and return to the top of the function selection menu. Press the POWER button again to restart the printer.
Thanks for using Fixya
SAM ANDERSON
Posted on Sep 16, 2008
SOURCE: Waste Ink Absorber is full In Canon Pixma IP3300
please give me resetting soft for canon Pixma iP 3300 printer.
Posted on Oct 06, 2008
SOURCE: waste ink absorber full
my printer is very broken in this so absorber full,it make reset manual,can helm me
Posted on Feb 22, 2009
  • 33 Answers
SOURCE: Waste ink near full
Here is a link that provides info about this problem. hope this helps.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=2610&modelid=10443#SupportDetailAct
Posted on May 03, 2009
Canon iP90 printer message: The waste ink absorber is full. How to replace the waste ink absorber?
it is usually a foam pad that has tubes that **** the ink out and the collector may have an issue you may want to replace your printer if at all possible but canon printers are hard to find parts for sometimes
Feb 26, 2011 | Canon PIXMA iP90 Mobile Printer
Ink absorber almost full
Hi
This issue with Canon Printers occurs when the Waste Ink absorber becomes full or sometimes due to sensor error.
To clear this error you can first try to clean the waste ink collector pads. Before proceeding please turn off your printer and unplug it from power source.
To locate these pads open the cover of the printer, move the cartridges with your hand. Now you can use a absorbent paper towel to clean these pads. These pads are on the right side of the cartridges.
After this you'll need to restart your printer. This will resolve your issue.
Daniel Scott
Jun 08, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Canon mp 210. I try to start printing and there comes a window: The collector of ink is full. It does not operate
I used the wrong term.
The waste tank is full. I found out in the manual I need to visit an
authorised dealer to replace a part of the printer.
Is there another solution??
Feb 07, 2010 | Canon Pixma MP500 All-In-One InkJet...
I am getting a message on screen saying that the waste ink collector is full. It is telling me to contact service. What can I do myself? Canon Pixma iP 6210D
Hello sir; You have to clean upthe ink collector by yourself, the procedure as follow; turn on the power open the top part ( same as when repace the cartridge) let cartridge carrrier move to the center then UN-PLUG the power, now you may move the carriage freely, move it to all the wayto the opposite direction from the ink collector, now you can clean the cell, after you clean up, turn the power switch off before you plug in the power cord.
Nov 22, 2009 | Canon Pixma iP6210D InkJet Photo Printer
What is the wasted ink collector? A sentence appears when I try to print out a page. It tells me that the collector for the wasted ink is nearly full.
there is a waste ink tank that stores excess ink from the printing process.
it is almost full and would need to be cleaned or replaced. and then the printer needs to be reset. Recommend Canon service for that problem, there are instructions for it posted online if you care to look around.
Jul 13, 2009 | Canon PIXMA MP170 All-In-One InkJet...
How do I find waste ink collector
there no any waste ink collector, this printer have only a pad for waste ink, (you don't need to replace first time indication) only take the printer to service center to reset this indication.
or
for immidiate printing -
just switch off printer from main (power) swtich then push and hold the on key and paper key then switch on from power. (it's work some time in some pixma)
Jun 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
The waste ink collector/tank is nearly full
The ink collector should be found underneath where the cartridges normally rests. Put some tissue paper on the ink padand let it absorb the ink. You might have to repeat the procedure a few times to get rid of all the ink.
May 18, 2009 | Canon PIXMA MP170 All-In-One InkJet...
How do you find the waste ink collector on a printer/scanner ?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
The waste ink absorption pads are inside the printer, in the very bottom. They are usually soaked with ink when full and are very messy.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
What does Waste ink near full mean
When the printer cleans the print heads it draws ink and disposes it to a foam collector in the base of the printer. Frequent cleaning via software causes this to to become saturated. To my knowledge it cannot be emptied or replaced easily and it is essentially the end of the printers life when full because the excess ink has nowhere to go and cakes on the print head. You can confirm with Canon or check the manual for replacement instructions.
Dec 08, 2008 | Canon Office Equipment & Supplies
This is a Canon PIXMA MP 780!!! Waste Ink Full Problem
You can try to read these articles on how to reset the waste ink full error on canon printer. http://www.fastrepairguide.com/waste-ink-full-error/how-to-repair-canon-ip1000-waste-ink-full.html http://www.fastrepairguide.com/waste-ink-full-error/canon-waste-ink-full-error.html They even provide the service tool program for reset the printer eeprom data(set as factory default).
Sep 10, 2007 | Canon I990 InkJet Photo Printer
Canon PIXMA iP1600 Printer Logo
24 people viewed this question
old marine
old marine
