Question about Jensen XA2150 Car Audio Amplifier
Wiring i have an us audio amp. i don't know which wire should be inserted first, kindly help me which wire should be put first (ground, remote, power)???  fyi: the amplifier was already installed i removed it for trunk space and i want it back/// thank you
  • 33 Answers
You need to wire the ground wire first, because this will make sure that the amplifier doesn't blow when you connect power. Your power cable comes last. First do the ground, then remote and follow with the power. Make sure the ground is attached to the body of the car properly, otherwise you will get poor sound
Posted on Jun 04, 2008
Don't know how to hook up the amp. It came with a wiring kit and I have no idea on how to hook it up.
You need to connect the Power wire (Most likely red wire with fuse) to the battery and run it to where you put the amp. You need to also drill a whole in the car and make sure it is grinded up and bare metal is shown. Screw the ground wire there with a bolt and nut. You will then need to run the rca cables from the amp location to either the back of the headunit if it has RCA outputs, or use a Line out converter, you can get them at best buy. Then you need to find your cars wiring harness code and figure out which is the remote ignition turn on and tap into that and feed that wire back to the amp to turn it on. Hook all wires up and make sure power and ground DO NOT TOUCH.
Jul 24, 2011 | Visonik Dual Bass Box with Amplifier Car...
I wanna put it into my car myself but dont know how and was hoping for a lil instruction
you will need a amp install kit witch comes with a 15 ft patch cable power line for amp and a blue line for remote. these wires run from the radio to the amp. The blue wire is called remote it turns the amp on or off depending on the radio state. the patch cable is rca jacks on both ends the back of the radio should have the female part of the rca jacks hanging from it. The other end goes into the amp. and last but not least the heavy red wire will go from the battery to the amp usually there is a fuse holder that you need to put between the battery and the amp. As far as grounding just ground the amps negative to the car chasis some where.
Good Luck Hope this helps
May 04, 2011 | Visonik Dual Bass Box with Amplifier Car...
Wont turn on i bought it though craigslist
well this is what you do to check it to see if you bought a blown amp.
wire it into your car and then take a digital volt meter check to see if you have power and ground and remote turn on .
take the red lead and put it on the battery wire at amp and the black lead to the ground then see if you get 12volt to 14.4 use the amps ground for the black test lead if nothing you may have blown fuse or bad ground.
check the remote wire same way as about if you get 12 to 14.4 volt it works if not could be blown from radio or bad ground
checking the ground put the black meter lead on ground wire and the red lead on 12 volt power source if nothing a bad ground.
if your get voltage on the remote wire and battery wire and have good ground then you need to call the seller and get your money back ..
Oct 16, 2010 | Eclipse EA3422 Car Audio Amplifier
Amp
you want to put a 30A into the amp and the inline fuse that you put onto the wire should be greater than 30A but not too high for what the wire is rated. The best bet for wire is to buy a wiring kit which comes with fuse holder, right size fuse, wire for main power ground and remote. You may want to double check what is written on amp for the size to put in there. Technically you can put a 100A onto the wire if it is big enough and the fuse on amp will protect the amp from problems. Hope this helps, Good Luck
Mar 25, 2010 | Ultra Linear UL801 Car Amp
My amp is not turning on.
check power from battery
ground
and remote
if you have power from battery then either your ground or remote power is not working
Apr 03, 2009 | Sony XM-1502SX Car Audio Amplifier
Jonny Rafael Every time i turn on my amp it stops and says Amp Err and shuts down and wont let me turn on like in about 20 min.I dont know wats wrong but i need help please.
Says amp error on the amp? what kind of amp? Have you checked the fuses and are you properly installed ie. remote wire to a remote power source. Properly grounded? Power wire to a constant power source? Please be more specific?
Aug 31, 2008 | Pioneer Audio Players & Recorders
A electronic subwoofer crossover
connect speaker wiring for car to speaker wire side. plug the rca's into the amp ground the ground wire. run a live from the battery to the power on the crossover and run the remote wire to the blue (iso connector) wire coming from the back of the radio
Jul 24, 2008 | Car Audio & Video
No bass thru cd player
it seems like you connected the wrong remote wire to the amp.
Alpine has two remote wires.
BLUE (only) This is the pwr antenna remote wire,every time you insert a cd this remote wire,the pwr cut out.
BLUE/WHITE STRIPE This is the AMP REMOTE WIRE,THIS IS THE REMOTE WIRE THAT YOU NEED TO CONNECT TO THE AMP
LET ME KNOW IF IT WORKS
thank's
Dec 25, 2007 | Alpine CDA-9807 CD Player
How do i by pass the parking brake no video
1. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
2. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
From here:
http://forum.ecoustics.com/bbs/messages/4/302701.html
Oct 09, 2007 | Dual XDVD8181 Car Video Player
Jensen XA2150 Car Audio Amplifier Logo
118 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
