Question about Olympus D-535 Zoom / C370 Zoom Digital Camera
Olympus D-535 batteries are charge, but camrea dead ,can you reset
  • Anonymous Apr 07, 2009
    no.
  • kvr2002 May 22, 2009
    I turned on the camera, seen the battery light flash" low", turned off the camera, opened the battery compartment before the lens fully retracted. I change the batteries, but nothing happens? Lens is still open, camera will not start up. No lights come on of any kind? Dead in the water. Is there a reset button of some sort? I have hooked up the USB cord to the computor & the camera & still nothing happens? Any suggestions?
  • 51 Answers
Well..remove the battries again ..and re insert the battries...
while inseting the battries ensure that u follow the steps given below..
Make sure camera is turned off
The monitor is turned off.
The green lamp and orange lamp on camera is off.
The lens is not extended.
Posted on Jun 04, 2008
1994 Yamaha XV 535 Virago DX will not start
Hi, Jen before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1987 Virago will not start
What to do When Your Motorcycle Won Start
Yamaha XV 535 DX Virago Service Manual
OEM parts for Yamaha
Yamaha 1994 XV535F Owner Manual
May 10, 2017 | 1994 Yamaha XV 535 Virago DX
My battery goes dead within an hour of riding my bike. We have put in a new battery. I have an '88 Virago 535
I to bot two 535,s I redone one for now and working on the other they set for 2 years too ones carb,s were trasht I had prob,s with the other not running right it turnd out it was plug,s nothing was wrong with the carb,s 1fe7c704-1c1c-49c5-913a-419e51398500.jpg
Jun 03, 2012 | 1988 Yamaha XV 535 Virago DX
I broke my battery charger for my Olympus D-535 Zoom, is this cam can be charge like cellphone, i got this from a friend and has no accesories like charger. If it does where can i buy it?
The D-535 uses two AA batteries, either disposable or alkaline. If you use rechargeables, you must charge them outside the camera. Rechargeable AA batteries and chargers should be available at just about any department, electronics. or office-supply store.
Jul 22, 2011 | Olympus Cameras
Olympus Camedia D 535 lights are on but no one is home
hi,
Please check the battery if the battery is fully charged then the camera is not getting power properly from the batteries .
Feb 17, 2010 | Olympus D-535 Zoom / C370 Zoom Digital...
Write protected only comes up when I want to take a movie. I have a Olympus D-535 zoom camera.
Hi guys, I had the "write protect" message on my Olimpus c-370 zoom for a while and I tried everything, including buy a new Xd card.  When the new card arrived I had the same problem, and I was giving up... then I tried the camera using "fresh charged" new batteries and it works!
Hope this can be useful.
Dec 02, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
No power on olympus D-535
Did You try to reverse the battery's (Put the left battery on the right side and etc)?
Oct 30, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
D-535 zoom
try to remove the battery for an hour.. then put it back again.. then charge the battery at least 3hours..
Jun 27, 2008 | Olympus D-535 Zoom / C370 Zoom Digital...
A/C adapter
There is an A/C adapter which is recommended for use with the D-535 Zoom Camera. The model is E-7AU. Use this 110V/120V AC Adapter to conserve batteries when downloading to your computer, for extended work in a studio, during printing, or while viewing images while connected to your TV or VCR. You can purchase this through the Olympus Emporium at https://emporium.olympus.com/ or 1-800-201-7766. The Olympus stock number is 200751.
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Battery life expectancy
The D-535Z uses two AA batteries, and Olympus includes alkalines in the box. Unfortunately those won't last long and will end up in the trash. So I recommend buying a four pack of NiMH rechargeables (plus a charger), which gives you a set for the camera plus a spare. Unfortunately Olympus doesn't publish any battery life statistics for the D-535, so I can't give you any exact numbers. It depends a lot on how much you use the flash and LCD screen. Don't leave the screen on all the time, use it sparingly and you should find an increase in shot numbers. BMW
Olympus D-535 Zoom / C370 Zoom Digital Camera Logo
242 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
