Question about AOpen AX4BS (91.32Q10.002) Motherboard
Bios does not find PS2 keyboard/mouse
Computer worked with USB keyboard/mouse, but not PS2. USB keyboard does not activate "del" setup. Bios reset to default using jumper 14 to return to basics, however, still does not find keyboard/mouse.
nigel@keskom.co.uk
  • 1 more comment
  • keskom Jun 05, 2008
    I was given the computer with no history. When setting up used PS2 keyboard/mouse and BIOS did not recognise keyboard and mouse, I then replaced PS2 with USB keyboard/mouse, went through "black screen" and loaded wndows xp, mouse/keyboard ok. Restart and BIOS did not recognise either PS2 or USB keyboard/mouse, so no way of enty in BIOS setup as pressing "del" did nothing. Decided to default BIOS hoping to get back PS2 and access to BIOS setup, this did not happen. So, as I can not access the setup because the POST can not find keyboard/mouse, and that is 4 different keyboards, any ideas?
  • keskom Jun 09, 2008
    Somehow this means of communication between TandN and kescom are getting lost, hopefully they have gone to TandN but seemingly not. Thanks, for you help and time, I have put fault down to hardware ie the connection of the PS2 connection and mobo. Thanks.
    TandN are you getting my replies?
I have a computer that stops at.... Keyboard and mouse not found Checksum error. Defaults loaded. Press Del to enter setup. F1 to continue. With no keyboard, unless you know different I can not access the BIOS setup. Problem not fixed. Await suggestions, something better than fit a new motherboard please.
Posted on Jun 05, 2008
    Sergeant:
  • 458 Answers
Did you go into the BIOS and set it to recognize the USB Keyboard after you reset the BIOS? Is windows not noticing it or the BIOS. You stated that it recognized the USB keyboard and then said that it did not.
What does all of this mean? USB keyboard does not activate "del" setup.
If it does not work, it is because you reset the BIOS and did not change the settings back for the USB keyboard.
I hope that I fixed your problem.
Posted on Jun 04, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    Did you try what I told you to do? I can keep helping you if you want me to. You need to tell me what you have tried.
  • Chappo07 Sep 06, 2017
    I have resolved a similar issue by running the motherboard setup disk which gives me the keyboard and mouse. Then go into bios and change boot sequence to CD drive and run windows repair.
Toshiba aspire boots normally but moving the cursor or any key and the screen goes dark.
Try using a PS2 mouse and PS2 keyboard. It may be that your USB ports have lost their setup (assuming that you are using USB or wireless mouse and keyboard). If the PS2 hardware works fine, check that your USB ports are enabled in the BIOS, then check your device drivers in Windows to see that the USB hardware is recognized.
Oct 12, 2013 | Computers & Internet
How to use a usb keyboard
as a P/S2 keyboard.plug it in the USB contact in the back.in any USB port.
Apr 08, 2013 | Dell Inspiron One 2305 Desktop Computer...
Keyboad failure on dell gx520 boot
Usb or Ps2 keyboard ?
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Enter bios restart your computer you will see a certain to press to enter set up usually the Delete or the F2 key this will vary depending on you computer and bios. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Enable PS2 & USB in BIOS You can enable PS2 and USB settings in BIOS by entering the BIOS setup screen when the computer boots. You will need to changes to the appropriate settings in this screen. The exact procedures vary by system, but there are a few common methods that may work if the motherboard manual is not available for guidance. The general procedure is the same for any modern computer system, but the menu arrangement and keystrokes to enter the setup program can vary greatly from one machine to the next. Power on or restart the computer and watch the initial boot screen to find the keystroke required to enter BIOS setup. This is often shown at the bottom of the screen. Typical keystrokes include pressing the "F1," "F2," "F9," "F10" or "Del" key. Press this key when the prompt appears on the screen. You can find the proper key in the computer's motherboard manual or on the website of the motherboard or computer manufacturer. Enter the BIOS setup screen and look for the "Advanced" or "Onboard Device Configuration" menu. Use the arrows to select your choice and press "Enter." Change the settings for the PS2 port by moving the menu choice to the "PS2" setting. Press "Enter" to bring up a smaller menu with the options to enable or disable the PS2 ports. Select "Enabled." You can also use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the PS2 port. Change the settings for the USB port by moving the menu choice to the "USB" setting. Press "Enter" to bring up a smaller menu with options to enable or disable the USB ports. Select "Enabled." Alternatively, use the arrow keys or the plus key to change the current selection from "Disabled" to "Enabled" in order to enable the USB port. Save the settings and exit by pressing "F10" or using the "Esc" key to back out of the current menu. Choose to save and exit from the main menu if needed. Follow any additional instructions on the screen to save or navigate the menus. Hope this helps.
Dec 13, 2012 | Dell OptiPlex GX520 PC Desktop
Hello, i currently use a IBM desktop with IBM keyboard and mouse but i just bought a microsoft wireless keyboard and mouse which i just installed into my desktop using the installation CD. They are both...
Hi Tony,
It appears that you have an IBM desktop whose BIOS isn't capable of booting off of a USB keyboard and mouse device. Older computers used to require that a PS2 mouse and keyboard be attached before booting, to prevent you from booting a machine without any way of controlling it. You have 3 options:
1. leave the corded mouse and keyboard attached and never use them
2. update the BIOS for your desktop to the newest one in hopes that the updated BIOS will allow for USB mouse and keyboard operation
3. go to a computer store and get a PS2 to USB converter/adapter. They're small and relatively inexpensive. It plugs into the PS2 port, and makes your computer think that there's a PS2 device connected, when it's actually a USB device.
Mar 03, 2010 | Microsoft Wireless Laser Mouse 6000 v2.0
Ps2 keyboard and mouse don't work. usb works fine
Assuming you have checked in setup that the PS2 is turned on the other option is to re-flash the bios .
At some time someone switched the mouse and keyboard and started up the computer this can cause you to need to re-flash the bios most likely the keyboard chip needs to be replaced sorry to bring bad news .
Dell seems to have this problem yet the USB works is good where most modern keyboards and mouse are USB.
Purple is Keyboard if not color coded the closest to the outer side of case is the keyboard.
Good luck hope this helps you
PS. You may try setting the jumper pins to default the main board back to factory defaults then remove the jumper pin and leave off for first boot .When doing this be aware not to have the power cables connected to the server remove all power cords and the monitor . Prior to doing the first power up plug in the PS2 keyboard only then the monitor. Cross you fingers If you lucky your PS2 port’s will be working again if so shut down re install the jumper pin install the PS2 mouse.
Sep 24, 2009 | Dell PowerEdge 1600SC Server
The ps2 ports for both keyboard and mouse do not work. i got around that by hooking both up with a usb connector. BUT when the computer is on with no mouse activity for a while, the mouse ''dies.'' Then...
HI,
Go into the BIOS utility and set the BIOS to defaults, hit F10, save the changes and exit the BIOS, the computer will restart, see if that helps.
To get into the BIOS hit the Esc or Del key when the computers just starting up.
Good luck.
Sep 14, 2009 | E-Machines eMachines Desktop PC
USB MOUSE x PC BOOT
Could be a problem with your system BIOS, enter the setup while your computer is booting (before it gets to windows) by hitting the F12 key probably. Make sure that the boot order is HDD first, not something else.
Aug 31, 2009 | Laser LX710 Keyboard and Mouse
I can't install vista any mouse or keyboard detected
Often times this happens when using a USB keyboard / Mouse.
Or when using a USB keyboard through a PS/2 Converter.
Try using a PS/2 Keyboard if available
(Small Round connector with a small amount of pins, similar to a S-Video connector.)
Also. Access your BIOS settings and assure that you have Legacy USB keyboard support.
Depending on your computer the BIOS / Setup Menu / Options Menu/ Etc. can be accessed by pressing the following key during boot:
F1
F2
ESC
DEL
F12
Let us know your setup(KB and Mouse Port type), and if you have any other issues.
Good luck
Apr 14, 2009 | ASUS P5V800-MX Motherboard
POST/BIOS does not find keyboard
I do not recall one ever doing that either. Why couldn't you get into the BIOS to check to make sure that the settings are on for USB. I do not understand why you can't get into the BIOS. That is the way that I have always done it. Strange how it can boot into windows. You must have the settings set so it will boot up without user name or password.
I have been doing computers for six plus years and I do not understand that one either. I am exhausted with solutions at this point. I am sure that is not the answer you wanted but I am as stumped as you are.
Jun 05, 2008 | AOpen AX4BS (91.32Q10.002) Motherboard
AOpen AX4BS (91.32Q10.002) Motherboard Logo
1,094 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
