MMC problem Hi there! a week ago my phone ran out of battery and it shut down so recharged it and restart it again. Afterthat my phone stopped notifying me of any message that comes in or any missed call. i restarted it again but nothing changes. so now if wanna know if hv a msg or not the only thing i do is going to message box n check, the same with th missed calls.it doesnt also give a tone for the recieved msgs.today i took the MMC off the phone n it worked well without it. i inserted the MMC again and discovered tht all msgs saved on it are gone. wht went wrong with my phone? wht should i do to get my msgs back. P.S, all pictures, calender info and contacts no.s are still there. Thanks, sara
If AC adapter is connected and the system gets shutdown automatically it is for sure that this problem is not for battery. You can try going to properties of My computer - Advance system setting - startup and recovery settings - automatically restart
Have you tried to use your computer when power charger is connected to power supply? Then try it to check if your computer does not shut down. If do not shut down it self. You had problem with the battery or with charger not compatible with the battery. Normal problem of shutting down computer is that your battery have no charge, your battery is not compatible with your laptop or ever defective. Tr
What about the fuel filter in the frame? Did the Ford mechanic check it?
Is a diesel? If that is the case, it could be the electric cellanoid switch in the injector pump. But usually it would start and stop it would just shut down with that.
Thank you for using Fix Ya Your rating is always appreciated.
for overcoming this problem first format ur memory card using ur phone
or by personal computer..................and also dont add too many
themes in ur mobile it ll cause this restarting
problem....................
