Question about Samsung Refrigerators
Hi my Samsung fridge freezer is not freezing, The lower freezer section is chilling but is not quite cold enough to freeze wereas the refridgerator is not quite cold enough to chill. I can hear the fan working and the light comes on the the fridge is opened.
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
Some good stuff on youtube re
samsung fridge freezer help
also samsung diy video help
Posted on Oct 19, 2010
  • 4 Answers
I had the same problem. As a child I hung with the men working and remember them saying the freezer has to have space in back away from the walls so the coils don't freeze up. Defrost the freezer completely of all ice and water. This time even thought the instructions say give 2-4 inches of space from the back wall so the coils won't freeze up try 8 or 10 inches away from the back wall. The fridge may stick out some from the space it's supposed to be in but it hasn't froze up yet.
Kimsukie
Posted on Dec 09, 2009
Check that the foo foo valve is adjusted correctly!
Posted on Nov 05, 2008
SOURCE:
The refrigerator is not cooling
Do you find that the freezer section is freezing up more too.
If you place you hand at the top of the fridge you should feel the cold air blowing through and also hear the fan kicking in to chill with door open. If freezer section is freezing up open freezer door press the door switch in and hold it in. you should hear the fan kick in. If not it could be frozen and all the channel too . you can take back panel off and remove the ice or switch it off and defrost it . Try this and let me know out come.
Jeff
Jun 10, 2014 | Samsung RS265TD
The lower part of my samsung cooltech fridge is freezing all food.
Hi nalin, sounds like you may have a problem with with your defrost timer. Defrost timers can fail due to wear and tear. If this happens during the cooling mode, it will allow excessive frost to accumulate on the cooling coils causing the refridgeration compartment to over shoot its chilling operation in turn causing everything to freeze. Best bet would be to call up a local Appliance Service Technician while the fridge is still manageable so you save on time and money. Also it wouldnt be a bad idea checking the thermostat rotational knob on the rear inner wall of the fridge (if there is one) just to make sure that the machine isnt fully dialed to max chill, hope this helps.
May 01, 2011 | Samsung Refrigerators
I have a westinghouse 2 door fridge that is not getting cold enough, 7 degrees in the fridge, freezer seems ok. not sure where to set the controls as i have no manual. its a 2 door,freeze at the top and...
i think your ref working normal try to adjust thermostat setting on the fridge if you want to cool lower than 7 degrees but this temp. allready can chill the food. then you said that freezer ok.
Feb 12, 2011 | Westinghouse Refrigerators
LG GR431SCA fridge will not cool properly and top half of freezer and ice maker section will not freeze. The bottom half of the freezer (below the shelf) freezes well, but above the shelf and the ice...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | LG LRBN20510WW Bottom Freezer Refrigerator
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Aug 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
Fridgidare, freezer cold fridge warm
sounds like you may have gotten a refridgerant leak causing a low charge condition. some refridgerators have a evaporator fan if this quit working it will cause it to freeze up .thus the freezer does not use a fan and it will still get cold
Jan 05, 2009 | Frigidaire FRS26ZSG
GE side by side refridgerator
YOU NEED TO CHECK THAT YOUR HEATER ELEMENT AND SENSORS ARE FUNCTIONING WELL AS THAT WILL CAUSE THE ICE BUILD UP AND THE UNIT NOT TO WORK PROPERLY. GOODLUCK.MOHAMED
Sep 17, 2008 | Refrigerators
Food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Sep 01, 2008 | Refrigerators
Too cold in bottom section
Had the same problem and referred to another post regarding ice build up around the evaporator coils in the freezer unit. I had no ice build up but flat foil guard had dropped down across the freezer outlet which caused more cold air to be forced up into the lower section of the fridge. This caused the freezing of the vegetables.
Follow barkbugs steps first www.fixya.com/support/t970724-fisher_paykel_fridge_freezer and see if that is the problem.
Also while starting to remove items from the freezer check to see if something has moved back and is blocking the air vent. Even a packet of food may cause enough blockage. A slicker pad was also part of our problem.
Oct 31, 2007 | Refrigerators
Refrigerators Logo
654 people viewed this question
Top Samsung Refrigerators Experts
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
