Hi there i have the above dryer but my problem is, the water empty light stays on even thoe the water is empty and all the stuff has been cleaned.
Ny help would be great thank you.
you might want to check the sensor for the water inside the dryer. you say that even if you already put water in it, the light is still on correct? which means that the dryer does not detect or sense that water is already there. so please check if the sensor is working and if not, replace the sensor.
Is there a position on the dial showing a symbol for a tub with a line above it? if it has position this against the mark and switch on then the pump will empty the sump into the water container and the machine can then be reset for normal operation
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Remove lower left filter from dryer, and wash it out under running water. Reach inside the compartment and clean any fluff and gunge you can find there.
Get a plastic bag tie or similar, and feel for and locate a small hole at the rear of compartment, poke it clear with bag tie.
If you are certain that the element and stats are o/k , and it still does not heat and the light stays on, then that indicates that the float switch is stuck or is faulty.
To access this involves stripping the dryer down, not an easy job.
Plz rate my solution.
Thanks.
Remove lower left filter,and washout under running water, reach into the opening and clear out all fluff and gunge, get a plastic bag tie or similar, and feel for and locate small hole at rear of compartment and poke clear with plastic
Make sure the air vents are clear back and front and try again, if still showing light then probably the float switch is sticking or faulty, this involves a complete strip down of dryer to fix.
Thanks.
I have had a similar problem, my wife tried drying clothes that were too wet, causing the machine to flood. Even though she emptied the tank, the empty water light was always on!!
What I did was take the electrical plug out and tip the machine to one side, you probably will find there will be a collection of water in the base, which will leak out. Once you think you emptied it, plug it back it back in and try it.
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
the black wire that was moving water from down condenser to up - water container - remove it. Use cotton swabs to "clean" the holes, do a run of the dryer without that black wire connected ( carefull, cause some wated might spill at this point), reattach black wire, and enjoy :)
It worked for me anyway. ( fingers crossed, its been on for 20 mins and still no red lights flashing)
