Question about Canon imageCLASS MF5750 All-In-One Laser Printer
Main drive assembly
I got a canon mf 5750 printer that has the main drive gears worn out. the gear that i am talking about is a small movable one that drives the fuser pressure roller. I guess iam looking for the part number and if anyone can give me the parts guide for this model so i can order the parts pliz email me raj_2fijian@yahoo.com
  • Anonymous Sep 03, 2008
    i don't have a cd.
Check this site: http://www.precisionroller.com/find/canon_imageclass_mf5750.htm
Posted on Jul 29, 2008
Canon ir2535 e00020 repair
Dear in most cases if toner refilled (or the life of the hopper assy.)the worm gear of the hopper assy. worn out. so the sensor at developing assy.detect no toner flowing to the developer from the hopper assy. where as the hopper assy. sensor detects toner. check the sensor, If you have knowledge enough to dis-assembly the the hopper assy. check the worm gear connected to a small motor driving toner gear. clean the sensor( may toner got inside the windows of sensor, clean it). check the harness, check the DC_CON pcb. Note if no experience donot open hopper assy. take assistance of trained engineer. Thanks.
Feb 21, 2015 | Canon Office Equipment & Supplies
Missfeed 010B canon ir7105
Your fuser assembly is not rotating, the drive gear is broken, the bushings inside the bearing is broken or worn out.worst case fuser drive motor. those fusers are rated at 500k. Take the front cover of the fuser assembly off and inspect that area for the problem. look for broken gear.
May 22, 2014 | Canon Office Equipment & Supplies
How do i fit a drive gear on to a mculloch gladiator 550 as i have bought the new part and dont know how to fit it
If you are talking about the main small drive gear that drives the larger crown wheel, then you need to remove the four screws holding the gearbob assembly onto the engine, the drive gear is screwed thriugh the bearing and into the drum, they are usually very tight, so you need to clamp the damaged drive gear with a suitable pair of grips and turn the drum to unscrew it, it should be a normal right hand thread.
Jun 08, 2011 | Garden
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
My canon ix4000 gives a service error 5750 - Could you please help
its a ps cam sensor error, check the sheet feed unit, replace logic board assembly, check output support unit, check output support gear unit
Aug 16, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Printer canon mf 5750 thankyou verymuch
please chack your paper feed sensor i guss it was broken
Aug 04, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
64 bit laptop not compatible with ImageClass MF 5750 to scan
I have Windows Vista Home Basic. I anm using 5750 scanner after downloading the following software MF5700_PrtDriverV300_Win_EN.exe &MF5700_PrtDriverV300_Win_EN from the Canon site. I am not an expert in knowing what are all these. But it just worked after downloading them and running.
Mar 30, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
XEROX WORKCENTER XD100 NOISE
Most likely the fuser gear is worn. The noise is prominant in the right side toward the back I am assuming.
You can replace the heat roll drive gear itself, but honestly I would recommend replacing the entire fuser assembly. It is probably very very tight and would wear another gear out quickly.
You want to get that replaced before the drive gear on the main motor assembly wears out. It would not rewuire replacing that entire main drive assembly, But it is a real difficult part to replace.
Go onto google and do a search for The Parts Drop. It will be the first item to come up. CLick it on and call and talk to Britt.
He will have what you need for a reasonable price.
if you go that route and need instructions to replace that part. let me know. Its not very difficult.
Jul 16, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Printer drivers
Hi - You can download the software from the link underlined in blue below:
canon image class mf 5750
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 10, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
126 people viewed this question
old marine
old marine
