Question about Irons
Problem with steam iorn
How to de-scale aqua turbo 215
  • 304 Answers
Make a solution of half water and half white vinegar. Fill up your iron and get it good and hot then let it sit a couple hours. flush out and repeat as necessary. Hope you find this helpful. Please give me a fixya rating If this works for you. It works very well as long as it is not completely filled with scale. Once you have it good and clean By a gallon of bottled water at the market and use that for your Iron and you will never have a scale problem again. I learned how to do this 20 years ago from a 80 year old woman from england. If it is really bad you can up the vinegar concentration but do not go higher than 2 cup to 1.
George
Posted on Jul 24, 2008
Water coming out of steam holes
Either: the iron is not hot enough to heat the water to steam temperature or the internal water-flow valve is leaking so that too much water is getting through. Check the iron is getting hot enough first. If it is then run some de-scaler (as used in kettles) through the iron to try to clean all the passageways. Always ensure that you fully re-flush the iron after de-scaling or you'll damage your clothes with any acidic residue left in the iron.
Good luck.
Dec 04, 2016 | Irons
Why does water leak out of bottom of iron base unit when ironing .could it be the filter unit ?
Probably not the filter.
If it is a new iron and the drops of water are excessive I would suspect it is faulty.
If the iron is well-used I would suspect it has a scale problem where localised scale build up is preventing some of the water from closely contacting the heated metal and turning to steam. This could be particularly true if you live in a hard water area.
Steam irons originally soon caused problems unless distilled or de-ionised water was used. It is reckoned modern irons can use tap water but hard water can still cause trouble.
A descaler additive might help but I haven't had good results in the past...
Oct 19, 2015 | Irons
Why has my Perfectcare aqua stopped emitting steam
You should hear the boiler heat up the water. When you pull/push the trigger, a pump should be activated and steam should be released. If the pump is not working, it could be a defective capacitor according to this article:
https://lieven.kks36.be/2016/06/11/philips-perfectcare-aqua-does-not-pump-solved
A spare capacitor should cost you no more than a few dollars, just find somebody with electronics/soldering repair skills.
Aug 31, 2014 | Irons
How do I get the boiler on my rowenta steam generator to fill? I was given this model.
You should only use distiller water in the steamer. Never ever use tap water! This is what caused lime and scale build up.
Since it's to late, you have nothing to loose by trying this to descale the unit:
Put up to one cup of white vinegar into the reservoir. Fill 3/4 of the way with water. Turn unit on and let it heat up, but DO NOT RUN STEAM THROUGH THE LINE. Once heated up, turn unit off and let it set for hours. Drain and rinse well. Then run a water only batch through the steam cycle. There are companies that sell special de scaling solutions. But hopefully, the vinegar will work.
Apr 25, 2014 | Rowenta Steam Generator DG050 Iron
Brown water and seems like sand or fine grit comes from iron ,when first put on with the steam
sounds like it is time to de-scale the iron to loosen all the deposits inside the unit.
add some white viegar to the water ( which should be distilled water ) and heat up and let the iron steam out the solution. now add just water to the unit shake it and rinse out with water and drain. now do one more vinegar / water de-scaling and rinse out again. now fill with just distilled water and let it steam out and now your iron should be clean as new.
c...
Feb 12, 2011 | Russell Hobbs 13153 Iron
4268 iron leaving residue
This will probably just need de-scaling. Buy some descaler and there should be instructions on the packet of how to de-scale an iron. Usually by warming the iron slightly, switching off, emptying out the water and then adding the diluted de-scaler to the iron and leaving it in an almost horizontal but raised position in a bowl or something so that some of the de-scaler will drain through. Then emptying out, re-filling with water and then iron something that you don't mind getting marked while any residue get's flushed out.
Aug 04, 2009 | Sunbeam Irons
Water in iron box
Yes... you can use it dry...
Cleaning a Steam Iron White Scale and Brown Water
http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown
heatman101
Aug 15, 2008 | Panasonic Cordless Steam Iron - White/Aqua
Tefal proline express steam generator iron needs de scaling
George
Jul 13, 2008 | Irons
Insufficient steam
Try a commercial De-Scaler.
If your in a hard-water area. the iron will be heavilly scaled-up.
If there is a steam surge button, on the iron. Face it downwards and push the button several times.
Mike @ Compurepair.
Feb 18, 2008 | Tefal Aquaspeed 170 Iron
Irons Logo
134 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
