Question about Maytag Neptune FAV6800AW Top Load Washer
MAYTAG NEPTUNE TL WASHER
WON'T SPIN AFTER WASH AND RINSE. JUST REPLACED DOOR LOCK MECHANISM ON THE RIGHT SIDE.
  • 96 Answers
If you are not getting any error codes pertaining to the door lock and you are getting wash and rinse then the problem would seem to be that the water is not draining. Machine will not go into SPIN if the pressure switch senses that there is still water in the basket.
Posted on Jun 08, 2008
Tip
Maytag Neptune Front Load Washers No Spin Problem
A class suit was filed in the State of Illinois, USA and then later on won against Maytag in 2004 due to the high failure rate of the wax motor used in the door lock mechanism of their Neptune Front Load Washers. The wax motor is used to activate the door lock switch by extending its shaft when a voltage from the machine control is applied across its terminals. Its failure then leads to the breaking down of components in the expensive machine control board. This is the fact that angered the customers which led to the filing of the class suit.
The obvious symptom of a failed wax motor is the inability of the washer to advance to the spin cycle and the door lock lamp is not turned on. The washer stops momentarily at the end of the wash cycle then continue to tumble as the machine control checks the activation of the door lock switch. The control will not allow a spin speed higher than 51 revolutions per minute (RPM) unless the door lock switch is activated by the wax motor. It is a safety feature of the washer to prevent accident due to accidental opening of the washer door during a high speed spin.
Customers who purchased the Neptune Front Load Washers in the USA after April 1, 1997 and before August 9, 2004 are Class members and eligible for the repair reimbursement, replacement cost, or purchase certificate depending on the length of service of the machine. Call up Maytag at 1-888-MAYTAG (1-888-629824) for more information.
The models included in the class suit are as follows: MLE2000AYW, MLE2000AWW, MLE2000AZW, MLG2000AWW (Gas Stack Unit), MAH3000AAW, MAH3000AEW, MAH3000AGW, MAH3000AWA, MAH3000AWW, MAH3000BGW, MAH4000AWW, MAH4000BWW, MAH4000AWQ, MAH4000BWQ, MAH5500AWW, MAH5500BWW, MAH5500BWW, MAH5500BWQ, MAH55FLBWW, MAH55FLBWQ, MAH6500AWW, MAH6500AWQ, MAH7500AWW, MAH7500AWQ, MAH7550AAW, MAH7550AGW.
on May 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hi - my maytag top loader FA5800AWW is stuck on wash cycle. it won't do the spin only and it is sometimes getting stuck locked.
I feel you have a Clutch issue Google this phrase ""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Repost on that site in the Maytag forum and I will help.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
I HAVE AN OLDER MAYTAG NEPTUNE FRONT LOAD WASHER MOD# MAH3000AWA. I AM HAVING TROUBLE WITH IT, IT WILL NOT DO THE FINAL SPIN CYCLE IT SPINS WHEN IT WASHES, AND RINSE CYCLE, BUT THE FINAL CYCLE IT JUST...
Maytag Neptune defective door latch wax motor update
by: Anonymous
The older Neptunes, such as the 2000 Stackers, MAH3000, MAH4000 and the MAH5500A series had some issues which I am sure Maytag has corrected these issues in the newer machines...
There are thousands who have been burnt by the door latch wax motor failure. What happens is the machine will stop spinning because the door latch will fail to lock. Deep inside it is caused by the mechanism that locks the door. The wax motor will draw too much current and damage the control board by burning a resistor (R11) and a triac (Q6).
However, if Neptune owners know to replace the door latch wax motor they can prevent the control board failure from happening. Please tell everyone you know about this important fact.
The older Neptune’s also have a couple additional issues such as the moldy door boot and the reliability of the motor / motor control board. All three of these issues were involved in the class action lawsuit a couple of years ago. See http://www.neptunewaxmotor.com for more Neptune information.
Feb 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune won't advance from Rinse to SPIN
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
WASHER WON'T SPIN
You may have a defective lock mechanism, or since you just replaced it, there may be an adjustment to be made to the mechanism.
Jun 04, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune won;t rinse
Check latch mechanism for alignment. Often operation of machine loosens latch mechanism causing internal switch for "door open (or ajar)" preventing rinse or spin cycle. Opening and closing door presses latch mechanism closing internal switch allowing for continue processing to rinse or spin cycles.
Mar 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
211 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
