Question about Maytag Refrigerators
Relates to Maytag GC2228EEDB fridge freezer when the icemaker is making ice the water dispenser intermitantley depspeses water onto the floor . and now when connected to the mains power the fridge causes the elctricity power circuit brakers to trip . I hace checked the fuse in the appliance plug bur this is OK.
Trying to take the doors off Maytag GC2228EEDB and need to disconnect the water supply to the left door,the connector dosnt want to budge is there a nack to this??
Posted on Jul 06, 2011
Water is building up on bottom of fridge
If you have water build-up on the floor of the food compartment, or ice buildup on the floor of the freezer compartment, you are probably suffering from either a frost problem or from a clogged defrost drain.
Remove everything from your freezer, including all food and any shelves. Do not remove the icemaker (if installed.)
Look at and feel the panel covering the bottom or back of the freezer compartment. Is it thick with frost?
On top freezer models, are the holes in the top of the food compartment that lead to the evaporator choked with ice?
Is there ice forming on, or lots of water on the ceiling of the food compartment?
If the answer is yes to any of these questions, there's probably a defrost problem.
If you suspect a defrost problem, first remove any icemaker that may be installed. You will see a removable panel covering the entire back or bottom of your freezer compartment. There may be 6 to 10 or more screws holding it on. In some units there is a light socket attached to the panel; you'll see this arrangement most often in side-by-sides.
If you start to get an unusual buildup of ice in one particular spot in your freezer, especially beneath the icemaker, check for water leaks.
Water leaking onto the kitchen floor not traceable to one of the problems in Chapters 4 or 6 may be from a leak in the icemaker or door dispenser water system. Icemakers have a water solenoid valve mounted on the back of the fridge, usually behind the back bottom panel, and a water tube that leads straight up the back of the fridge to the icemaker. Door dispensers have a similar water solenoid valve with a water tube that leads beneath the fridge and into the door through a hollow hinge. If your fridge has both features, it's usually a dual water solenoid valve. It can be simple or not-so-simple to fix, but basically it's just a plumbing job.
Jun 13, 2016 | Refrigerators
Where do I find the ice maker inlet water valve or solenoid? The valve on the back of my fridge has only one hose going to both the water dispenser and ice maker and the water dispenser works fine.
Since there is water that flows to the water dispenser, the water valve is working. Now, there's a spout that water flows from to the icemaker tray. Look for it. It's located on the back wall inside the freezer and maybe behind the icemaker tray. Check and see if it's frozen. If so, defrost your freezer by turning the temperature gauge to off position. Wait a while until it's defrosted, then turn it back on.
Next, make sure that the metal wire is in down position.
If that doesn't work, your icemaker maybe defective and needs replacement.
Nov 01, 2014 | Maytag MFI2665XEM Stainless Steel
Ice maker not producing ice. no water flowing to ice making unit. water coming out of dispenser
You have to hook the icemaker up to the electrical circuit powering your refrigerator. Make sure wiring is correct. Some time it won't work if there is a loose connection.
samsung fridge freezer
Oct 30, 2010 | Maytag Refrigerators
My Maytag side-by-side refrigerator/freezer Leak
There is a pan and drain hose under the freezer coil that is there to catch any water when the freezer goes into defrost. I feel strongly that is where you will find your leak.
I hope this helps.
Apr 19, 2010 | Maytag MSD2756G Side by Side Refrigerator
Water dispenser doesn't work
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Aug 12, 2009 | Maytag 24 in. MDB5601AWS Stainless Steel...
Maytag ice maker will not release cubes
Sounds like it has a " seeping " water valve . Only thing to do is replace the water inlet valve . There is a certain amount of water to go into icemaker at fill . A seeping valve will let water continually drip into icemaker , making large cubes which icemaker cannot dump . A larger amount of seeping , will overfill the icemaker , and drip into the freezer and floor .
Aug 12, 2009 | Maytag Refrigerators
Ice-maker problem
if the water runs constantly when you turn the water on its your valve but if it does it periodacally it probably your icemaker
Apr 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water dispenser / ice maker whirlpool fridge frezzer
Check that you haven't turned the ice maker off in the menu.
thanks J
Jan 15, 2008 | Freezers
Refrigerators Logo
167 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
