I had the same problem before and was able to track it down to the rubber coated wheel used to pull out paper sheets from the tray. Over time it gets covered with fine dust from the paper so much, it does not provide enough friction to pull out one sheet properly on the first turn. When it continues to the second revolution, it takes two sheets out of the tray.
My works-got-me fix for this problem was to clean the wheel properly with a slightly damp (not soaking wet!) cloth. Best results come from gently wiping left to right, not in direction of the wheel's rotation. You will need to rinse the cloth a few times and repeat, the paper dust has a tendency to convert to a smeary goo if it gets wet, but will come off eventually.
When the rubber wheel is clean, give it time to dry properly before use of the printer again. Try to use higher quality paper, with cheap paper the problem occurs more frequently.
Testimonial: "Thank you a lot!"
I would try to clean the tires with alcohol, it's probably trying to pick up the other sheet but is slipping.
take out the tray and look inside for the pick-up and seperation tires.
