Question about Xerox WorkCentre C2424DN All-In-One Laser Printer
Xerox printer give system fault 07.010.043:1985
    President:
  • 2,072 Answers
That is fault caused by the print head not being able to move freely.
There are a few things that can cause that. Here are the most likely problems.
1. With the side covers removed, there is a stainless steel block located about midway back toward the bottom of the frame. If is silver and about 1 inch square. What happens with that is some ink spills into that print block and the print head will not move back and forth properly. You remove the spring holder over that block and most likely need some channel lock pliers to slide the block off if it has ink in it. Clean that and the shaft thoroughly
2. The wiper blade is stuck between the print head and the drum. Normally happens with a power failure or not properly shutting the machine down properly. You have to remove the document feeder, scanner, side covers and ink loader ( where you put the ink sticks).That will expose the drum/print head area. See if the blade is stuck and gently peel it from the print head, then run the remove light stripes procedure in troubleshooting from the user interface.
3. The Process control motor can come out of timeing. But 90 percent of the time it is a contaminated print block or stuck blade.
Posted on Jun 05, 2008
FUJI XEROX 016 757 ERROR CODE
Could be: The entered password is wrong or
Auditron security (A Xerox feature) is preventing users from Printing.
Then: Enter the correct password (Default 11111) or
Disable Auditron security settings from the Administrator menu.
Xerox Error Code 016 757 Tech on Tour
http://es.scribd.com/doc/21054313/Fault-Codes-Xerox
http://arts.ucalgary.ca/it/kb/221/xerox-printer-giving-016-757-error
Jun 25, 2014 | Dell 3100cn Laser Printer
Xerox Phaser 8860 error code 04, 025,.46:0?
Want to resolve your printer issues online then, dial Xerox Printer Support Phone Number1877-778-8@9@6@9 anytime as you like. For further Info Click:https://goo.gl/Co2Bom
Jul 02, 2012 | Xerox 8860dn Phaser All-In-One Thermal...
System fault 3-380
Remove and reinstall the print cartridge. If the error is still there you should replace the print cartridge.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=21,E=0000000001181489224,K=5792,Sxi=0,Case=obj(18087)
Jan 17, 2009 | Xerox DocuColor 12 Printer
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
System error
7,0XX.6x Errors - Program Faults
a.
Reset NVRAM and retest.
Jul 02, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
System fault
Refer to the link i posted and put in you question in the box and that should give you a correct information as its the manufacturer.
May 13, 2008 | Xerox DocuColor 12 Printer
DC12 System Fault
use this link to troubleshoot :
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=293,E=0000000000540253479,K=2161,Sxi=9,Case=obj(18087)
Mar 25, 2008 | Xerox DocuColor 12 Printer
Xerox WorkCentre C2424DN All-In-One Laser Printer Logo
88 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
