DVD/CDRW drive not recognising any DVD's
I have a Toshiba Satellite A10 with a matshita ujda750 DVD/cdrw combo drive. For some unknown reason it does not recognise DVDs. Basicly when I insert a DVD it's as if there is no disc in the drive. Interesting enough I can still burn & player standard CD's. I have uninstalled the drivers and windows detects the drive & reinstalls the drivers, and this doesn't fix the problem. Missed the driver file for this, pl. try to get it. Thanks in advance
The Laser Light Reader is out of adjustmjent or is very dusty. Manufactures will not fix the problem if the product in out of warranty. Your only choice is to consider it a CD-RW reader/writer only or buy a new one.
Sorry.
Posted on Jun 05, 2008
My matshita ujda760 dvd/cdrw read and burn cd but can't read dvd rom. I uninstalled the drivers and reinstalled but the problem continue.
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Feb 04, 2011 | Panasonic (UJDA750) CD-RW/DVD-ROM (Combo)...
Is the Matshita UJDA775 DVD/CDRW a DVD Writer ?
Download this little program DISCinfo 1.6.1. When you run it it will give you all the info you need about all your drives. It's good, I use it. Get if from here [http://discinfo.rpc1.org/#Download]
Mar 19, 2010 | Panasonic Computers & Internet
What is the drive type used in the Toshiba 2415 S205 laptop?
Specifications of TOSHIBA Satellite? 2415 Series
P4 2000MHz/15.0”XGA/256MB/40GB/DVD-CDRW/Mdm/LAN/WinXP Home
Satellite 2415-S206
P4 2000MHz/15.0”XGA/256MB/40GB/DVD-CDRW/Mdm/LAN/WinXP Pro
Performance
Mobile Intel® Pentium® 4 processor-M at 2.00GHz
Memmory 256MB expandable to 1024MB
All-in-one design
40GB* hard disk drive
DVD-ROM/CDRW multi-function drive
Mar 15, 2010 | Toshiba Satellite 2415-S205 Notebook
Can this unit create (burn) DVD R?
No it is a CDRW which can only burn a CD! The kinf of drive you need is DVD+\CDRW. This drive will burn DVD and CD.
Dec 04, 2009 | Panasonic (UJDA750) CD-RW/DVD-ROM (Combo)...
Toshiba dvd rom
Toshiba Satellite 1400 Series DVD/CDRW Combo Drive (P000347430)
hope that helps
Jun 11, 2009 | Toshiba Satellite A105 Notebook
My Matshita UJDA 750 DVD/CDRW wont recognize a blank DVD discs. How ever it does read both CDs and DVDs and only burns CDs.... please help
Are you trying to burn a dvd? If so from the spec you gave in the problem description your drive will burn cds(CDRW) but will only play dvds(DVD). If it stated DVDRW then you would be able to burn DVDs as in the CDRW.
Mar 06, 2009 | Evesham Voyager 6400 Notebook
My Samsung CDRW/DVD SM352F plays commercial DVDs but will not recognise an inserted DVD/RW for recording picture files and shows properties as O bytes used space and O bytes free space. What is wrong?
the drive you are using is called a combo drive
CDRW- means CD WRITER
DVD- means DVD READER
DVD WRITER is not included in this combo...
only cd could be read and also written
but is case of DVD , it could only be read..
thankyou,.
regards
JC
Aug 13, 2008 | Computers & Internet
Cd/dvd rom
HELLO. IT SOUND'S LIKE IT COULD BE A COUPLE OFM THING'S MAYBE.? THE FIRST THING IS TO SEE IF . ON YOUR DESKTOP . IN (MY COMPUTER) SHOW'S YOUR DEVICES WITH REMOVABLE STORAGE ... DVD/CD-RW DRIVE WITH A LETTER...LIKE (D:) OR (E:) THEN YOU NEED TO OPEN THE PROPERTIES ON IT.!!!! AND YOU THEN NEED.!!! TO GO ARCROSS THE TOP OF THAT PAGE TO WHERE IT SAY'S HARDWARE AND CLICK ON IT. !!!I IT WILL SHOW YOU HARD DRIVE AND SHOULD SHOW YOUR DVD/CDRW.!!! THEN YOU NEED TO CLICK ON IT.!!! AND OPEN IT.!!! IT WILL SHOW THE PROPERTIES OF DVD/CDRW.!!! AND TELL YOU IF IT IS WORKING PROPERLY.!!! OR NOT.!!! IF NOT YOU NEED TO REINSTALL THE DRIVER'S .!!! FIND THIS OUT AND GET BACK TO ME AND LET ME KNOW.OK.!!! "GOOD LUCK"
Jan 19, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Hi people!!
This fixed my problem. Give it a go, I have access and am using my burner once more.
Good luck!!
Alex
Note: The solution provided requires editing of the registry.
  1. To begin the process, start the Registry Editor.
    • Click Start, click Run, type regedit, and then click OK.
    • On Vista machines, Run is accessible through Accessories.
    • Click the plus sign (+) next to the following folders in the left side of the window pane:
    • HKEY_LOCAL_MACHINE
    • SYSTEM
    • CurrentControlSet
    • Control
    • Class
    • {4D36E965-E325-11CE-BFC1-08002BE10318}
  2. Look for any of the following names in the right side of the window pane:
    • UpperFilters
    • LowerFilters
  3. If any of the items above are listed, right-click on the item and select Delete.
  4. Be sure to restart your computer after you have deleted the files in the registry.
  5. Open My Computer (XP) or Computer (Vista) and check to see if your CD or DVD drives have returned.
  6. In some cases, you may need to reinstall some programs such as CD or DVD burning software, iTunes, or Nero
Mar 13, 2007 | Panasonic (UJDA750) CD-RW/DVD-ROM (Combo)...
Toshiba A30 - DVD-ROM CDRW
Wow, That's a weird malfunction. Only TDK??? What about other media types? Did you try a diffrent burning software?
May 12, 2006 | Toshiba (SD-R2412) for Satellite A10, A15,...
Computers & Internet Logo
648 people viewed this question
David Payne
David Payne
