Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
Change Battery Pack _ Ixus 70
After I have have taken only two or three photos the change battery pack message comes up and the camera shuts down
I have tried three different batteries and two different chargers so I assume the problem is the camera not the batteries or chargers
Any suggestions?
  • helsolh Jun 25, 2008
    I have the same exact problem too. And he battery is charged.
  • 3 Answers
Hmmmmm, the only thing I can think of, are you using the correct type batteries ? Check your instruction manual for the correct type of batteries, if you still have a problem I send it in for repair work or return it if it's new. Good Luck
Posted on Jun 26, 2008
I heve the same problem. I have 5 fully charged batteries and the camera always either will not come on or says battery needs replacing. I tried a few things and found that if I put a piece of tape on the center pin of the batteries, the camera works just great. I don't know if it will tell me now when the battery is low or not. I am wondering if the problem is the charger or the camera.
Jim
Posted on Aug 09, 2010
4 Suggested Answers
Fishi
  • 255 Answers
SOURCE: Battery Problem
I figured out the problem. My AA battery recharger was not making good contact, so although it said the batteries were recharged, this was not the case. After fixing this and getting full recharges, the problem went away.
Posted on Aug 31, 2005
markevans
  • 148 Answers
SOURCE: xti wont power up
appears to be a defect and not user serviceable.
sorry for the news.
good luck.
mark.
Posted on Dec 24, 2007
SOURCE: keep getting change battery message and camera turns off.
I had this on mine. If you pen the battery compartment door, you will see a piece of plastic labelled "CR1220". You can pull this out and replace the little CR1220 battery that it holds. That ought to solve your problem.
Posted on Jun 26, 2010
I have the powershot SD3500IS abd it says i need to change the battery pack what is that and how can i fix it also if i dont have a charer can i charge it with the usb ?
"Change batter pack" means your battery is dead. The camera should have come with a charger in the bok that can plug into the outlet in your wall. It uses a lithium ion battery, so you can't use a regular AA batter charger, for instance. You cannot charge the battery via the usb into your computer.
Nov 06, 2010 | Canon PowerShot SD3500 IS / IXUS 210...
Canon Powershot SD780 - Change the Battery Pack!!! AARRRGGGHH!!
Actually, the problem here is that there isn't enough pressure on the battery. You need to put a small piece of cardboard on the battery facing the door to the battery chamber. That will force the battery onto the contacts a bit more.
Give it a try. It should work. That's how I got rid of the same error message.
Apr 19, 2010 | Canon PowerShot SD780 IS / IXUS 100 IS...
Camera is 3 years old. Lately I take a picture
All the battery have a life time fixed working hours. Your battery is charged but he complete is working time. Thats why these msg will come. Dont warry use the battery when you see the power going down after a while of charging then change the battery and buy new 1. Good luck.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
The LCD monitor setting was lost after changed battery pack
Take a picture with the new battery pack. Is the picture also blank? Are the menu selections still visible in the LCD? Have you tried pressing the DISP button on the back, but the screen still remains blank?
If the answer is yes to these three questions, this sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Dec 19, 2009 | Canon PowerShot SD110 / IXUS IIs Digital...
Change battery pack
How old is your battery? The rechargeable LI-ion battery is only meant to last a couple years at most. If your battery is a couple years old (or longer) it's probably time to consider a new battery.
Fortunately, due to the popularity of Canon cameras, generic versions of the NB-4L battery for your camera are widely available. This makes them very inexpensive. Recommend looking for one on Amazon with good user ratings. Here's some suggestions.
Nov 01, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon IXUS 100is battery pack problem.
Happened the same with mine. At the beginning I tough it was related with the sd card as when I removed the card the camera would turn ON. Later on I found it to be related with the camera contacts. After cleaning the battery contacts with alcohol and a cotton swab it started to work fine. SOLUTION: Clean battery gold contacts.
Oct 12, 2009 | Canon PowerShot S90 Digital Camera
Where to check for the abttery display option
When the battery is low or insufficient the message " Change the battery pack" displays.
You can then insert a fully charged battery into the camera or use the AC adapter Kit to charge the battery.
On long trips, it is recommended to keep an additional fully chaged battery along with you so that you are not caught without any charge!!
Mar 03, 2009 | Canon Digital SD900 / IXUS 900 Ti Digital...
Black Screen; Change Battery Message
simple! with my Canon S90 had the same problem until I changed the SD card from LEXAR for a TOSHIBA SD card and the message " Change the Battery Pack"disappeared.
Jun 27, 2008 | Cameras
Charged battery for first time
The battery does not work at all/the charger was shut down.
Dec 30, 2007 | Canon PowerShot SD500 / IXUS 700 Digital...
Battery Problem after very few Photos
Very likely Take batteries out and with the eraser at the end of the pencil gently polish the contacts. Do the same with the lid contacts plate. Close it and try. If it will only work with the lid being pressed try this Take a piece of foil and lay it across the batteries then close the lid this will help pack out the contact. BE careful however if the contact plate covers 4 batteries and is in two pieces make sure there are two separate pieces and do not let them touch
Jun 07, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
340 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
