Question about Sony PlayStation Portable (PSP) Console
Sony psp theres no umd play options on my psp.
The PSP doesnt realy have any play options when u insert a UMD it will either start atomaticly or you can choose through system settings to turn on or off the UMD auto start which enables the PSP to automaticly start or you can disable the auto start or you can press x on the UMD icon and it will start.Now when it comes to movies you can bring up the movie mode options wich alow you to rewind FF pause all that good stuff. just insert a umd and when it begins to play press triangle. hope this was helpfull
Posted on Jun 04, 2008
  • 55 Answers
SOURCE: Sony PSP wont play umd
Go and return this to Sony if it is under warranty or go to a nearby repair shop to fix it. I believe the diode has been damaged from the qtip being used. Those lasers are delicate things.
Posted on Aug 24, 2007
Rocket976
  • 31 Answers
SOURCE: UMD
That's an easy one, just install custom firmware from www.everything4psp.com then you will be able to play all your games from the memory stick. Support Rich
Posted on Aug 09, 2007
tholtpython
  • 71 Answers
SOURCE: psp region code
u kould get custom firmware put on it.
that is the only thing that would allow the movie to be played on ur psp
Posted on Dec 04, 2008
mehrbear
  • 35 Answers
SOURCE: I have a sony PSP(regular not slim version)in
You are going to have to get a new mem card, or delete everything on your mem card and put make on, even though you might have a lot of progression in your games you have to restart
Posted on Aug 09, 2009
  • 10 Answers
SOURCE: My psp wont play any
Dear,
If you are still not able to solve your problem then let me recommend you to try Easy PSP Repair Guide because it works like magic.
PSP Fix Manual is a complete eBook that fixes almost all major problems of PSP. It is very easy to understand because it contains several pictures and easy to understand instructions. With the help of this PSP repair guide, you can save hundreds of dollars and save yourself from taking your gaming console to the sony repair shop again and again. Good luck!
Posted on Jun 07, 2011
My son psp beep when you put a game in and the umd does not come up can you help please
f you are experiencing issues when using a Universal Media Disc (UMD™) on the PSP system, try these troubleshooting options:
  • Issues with PlayStation®Store content Click here for help with content purchased from the PlayStation Store.
  • Restore Default Settings Restore Default settings will default the PSP system to its original settings. A setting change may be the reason the PSP system is having difficulties. Click here to learn how to restore default settings on the PSPgo / PSP system.
  • Confirm UMD is properly inserted
    Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
    Please note, it is normal for the PSP system to make noises while it is reading from a UMD.
    For PSP-1001, slide the latch to open the UMD door. For the PSP-2001 and PSP-3001, simply lift the door open.
  • Try playing the UMD on a different PSP system If possible, try playing the UMD on a different PSP system. If the disc still does not function properly, it might need to be replaced. If the disc does function properly, the PSP system may need service, see PSP Service for details.
  • Try playing a different UMD on the PSP system If possible, try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Check for moisture Do not let the PSP system or any PSP® accessories come in contact with liquid. Also check for moisture condensation in the PSP system. If moisture condensation occurs, remove the disc from the PSP and do not use the PSP until the condensation has evaporated, which can take an hour or two. In general, if any part of the PSP gets wet, discontinue use until it is completely dry.
  • Check the regional code Check the regional code on the UMD™ Video. The only regional codes that the North American PSP® is tested to work properly with are "ALL" and "1.
Tried these steps and still need help?
If you have tried the troubleshooting information above, but continue to experience problems, please contact our Consumer Services department to have your PSP system serviced.
Jun 28, 2011 | Sony PlayStation Portable (PSP) Console
When I switch on my PSP, it directly goes onto load the UMD game and when I try to quit using HOME button, the buttons and consoles dont work. Then I need to use the hold button after which though the...
Hi. Since you're in UMD Autoload mode, you need to configure that in the PSP Settings. To do this, turn off your PSP and remove your UMD. Now, turn it back on and it won't autoload your UMD since it wasn't there anymore.
Now, go to "Settings" and scroll down to "System Settings" and press X. Scroll down again the selection until you see "UMD Auto-Start" and press X. At the right side will appear the options "ON" and "OFF". Select "OFF" and press O button several times to go back to main screen.
Insert your UMD. Now, try playing games from Memory Stick. You may have to turn off your PSP and turn it on again to finally play homebrew...
I hope this helps...
Jun 07, 2011 | Sony PlayStation Portable (PSP) Console
My psp isnt playing a brand new game. it wont load the umd. the umd is pretty clean. i wait for it to load and it wont.
Below where the UMD game appears on screen try the button below that should say 'Update PSP'. The game could have an update for the PSP and won't play without it. If this doesn't work contact Sony Website Forums and see if anybody there has had the problem.
Oct 31, 2010 | Sony PlayStation Portable (PSP) Console
Can't play games, psp says I must update software then when it starts it comes back an says"could not start game,dadadadad" how do I fix
well if you have the psp umd then simply while the umd is in the psp go to your game section and you will see a few options there and it will have a update option
Apr 02, 2010 | Sony PlayStation Portable (PSP) Console
My PSP Don't Read Any UMD!!
get your psp modded,i mod them in cali and its great you play games of the memory stick so no need to use the umd drive.play emulators,homebrews and back ups
Feb 03, 2009 | Sony PlayStation Portable (PSP) Console
Psp(1001)won't read umd games or movies
If your PSP isn't reading games and/or movies and the problem isn't that your trying to play dirty, bent, or damaged UMD discs there are a number of other reasons your PSP is not reading disks correctly =
- Your UMD motor may be malfunctioning.
- Your laser may have worn down from use over time.
- Your UMD drive tray may be bent.
- There may be a foreign object in your UMD drive
Common symptoms
* disks fail to load
* extremely slow loading
* strange whirring noise when trying to read disks
For whatever reason your PSP has stopped reading games and/or movies we will get your PSP back to you and playing like like new fast! Our price includes labor, parts, and return shipping via priority mail.
Visit PSP UMD Drive REPAIR if you are interested in an affordable and reliable PSP repair service. We have been serving the whole United States for more than 2 years!
Jan 05, 2009 | Sony PlayStation Portable (PSP) Console
Psp region code
Aug 23, 2008 | Sony PlayStation Portable (PSP) Console
Psp-lazer ain't reading the games
This link should help.
  • Make sure the UMD is properly inserted with the label facing the back of the PSP system. Try removing the UMD and reinserting it.
  • Try playing the UMD on a different PSP system. If the UMD plays, the original PSP system may be the problem. If the UMD does not play, the problem may be isolated to the UMD itself.
  • Try playing a different UMD on the PSP system. If another UMD plays, the original UMD may be the problem. If none of the UMD's play, the problem may be isolated to the PSP system.
  • Make sure the exposed UMD surface and plastic casing is not damaged[2]. Do not use if plastic casing is cracked, collapsed, or if foreign materials have entered inside the UMD enclosure.
Nov 10, 2007 | Sony PlayStation Portable (PSP) Console
Same with my PSP. My son accidentally broken a spring sensor for the UMD when you close the UMD cover of the PSP. That's why the drive doesn't recognize if there's a UMD. Sony Service Center here in the Philippines doesn't have a replacement part for this.
Aug 19, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
89 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
