Question about WYSE Winterm 3150SE Network Terminal
Wyse terminal does not boot
After a power dip, 5 of my wyse 3150SE terminal does not boot. The button shows up yellow and then goes off when plugging in the power cable. Upon pressing the button to start up the terminal the button does not go green but flashes yellow and goes off.
Please can someone help?!
  • 868 Answers
It's not recieving a strong enough signal.try this ,unplug the power supply and if there is a reset pin on this ,push it in.Alot of reset pins are very very small,make sure you look real close.Wait for about 30seconds and re try with power.
Posted on Jun 04, 2008
  • 13,433 Answers
It should seem to be a hardware side problem.
Reset my MAcAir Terminal
Your best checking this support site >http://www.freewysemonkeys.com/modules.php?name=News&file=article&sid=55
May 31, 2014 | WYSE Winterm 3150SE Network Terminal
Tip
Reset a WYse WT3235LE back to Factory setting.
Hold down the G key when powering on and during the booting process to reset it back to factory settings. You can also do this in Control Panel under System.
NOTE: The G key trick is very picky so make sure you hold the G key before you press the power button and until it is booted. Also don't be frustrated if it doesn't work the first time.
on Feb 06, 2009 | WYSE WT3235LE (902032-68) Network Terminal
Power button
http://www.wyse.com/support/authorized-service-centers
unless you are a electrician don't risk doing it yourself in case something goes wrong and someone gets injured or worse
then
http://www.wyse.com/support/warranty-and-RMAs/spares
Apr 10, 2014 | WYSE Computers & Internet
Where can I get a factory manual?
google or you can normally download a pdf from the manufacturers website
May 04, 2011 | WYSE Winterm 3150SE Network Terminal
I wan to reboot my wyse 3150se what program do i need ??
Do you want to reset the configuration of the terminal box? If so, you may try unplug the power cord or pressing in a little hole on the back labeled as Reset. If you want to close the session with the server, you can logoff there in your terminal program (telnet, remote desktop, terminal emulator or a dial up terminal) or citrix.
Sep 12, 2010 | WYSE Winterm 3150SE Network Terminal
Wyse 3150 terminal - yellow light
Does it boot into BIOS if you hold down Delete while powering up the terminal?
Sep 03, 2008 | WYSE Winterm 3150SE Network Terminal
Internet Explorer Addon
Re-image the device with the latest firmware from the Wyse site.
This should enable you to use the latest IE addon without issues.
Aug 22, 2008 | WYSE Winterm 3150SE Network Terminal
Reconfigure winterm
try holding down the 'g' key when booting -this just worked for me.
Aug 11, 2008 | WYSE Winterm 3150SE Network Terminal
Wyse S10 Power UP issue after hung-up.
pull out the power cord for 5 minutes than put back in and turn on
Jan 29, 2008 | WYSE S10 (90210501) Network Terminal
WYSE S10 Power up problem
Replacing C38 will fix the problem. It's a Lytics SMD Capacitor 47uF/10.3V.
Oct 26, 2007 | WYSE Winterm S30 Network Terminal
WYSE Winterm 3150SE Network Terminal Logo
1,278 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
