Question about Compaq (176763001) 120-Watt Power Supply
450 power supply
I'm hearing a clicking sound from my power supply and my computer does not boot up. I have noticed that the red light is blinking on my cpu and the cd rom drive's green light is also blinking. If i open the cd rom the computer boots up, but when i inserted a cd and close the cd rom the clicking sound will be heard from the power supply and the system shuts off. pls help.
  • 165 Answers
The cd may be bad, or if the power supply is just marginal, it may be failing when the cd motor spins up.
Posted on Jun 08, 2008
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
I have dell optiplex 360 but LED ligth remain on does not turn green when i powerd on.no signal , beep sound and display
Believe it or not it is probably your Power Supply. Just because it lights makes the system lights up does not mean it is working properly. Sometimes it has enough power to make the light glow, but not enough power to make the fan in the power supply start or any other functions.
You can also try the things below to see if they work, if not replace the power supply.
When you plug in the power cord is there any lightswhatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the computer is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Most times the problem is with the Memory or Video Card when you hear beep tones or blinking lights. Notice the pattern of the lights and blinks. Do you get 1 Long Blink or Beep? Maybe you get 1 Long followed by 2 Short Blinks or Beeps.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Memory Chip might be bad.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 22, 2012 | Dell Computers & Internet
No beep sound,orange ligth remian on does not go off dell optiplex 360
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the Memory or Video Card when you hear beep tones or blinking lights. Notice the pattern of the lights and blinks. Do you get 1 Long Blink or Beep? Maybe you get 1 Long followed by 2 Short Blinks or Beeps.
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
When i turned on switch dell vostro 230 it give no display and led colour is red
No Display, so does it seem like the computer booted up and is running except that the Display is black? Do you hear fans running, disk drive spinning, blinking lights or beeps?
I'm going to assume that in your case since you mentioned a red light that it is not booting up all the way. Therefore your problem is probably with the memory, the video card or some other motherboard issue.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 19, 2012 | Computers & Internet
Cant turn my computer on and there is a yellow blinking light
How many blinks? Count and notice the patterns of the blinks (3 long blinks or 1 long blink followed by two short blinks).
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.If all the above fails, you problem could be your Video Card or a motherboard issue.
Apr 14, 2012 | Dell Dimension E510 PC Desktop
What causes red led on starting?
Remove Power Cord then press and hold the power button for 30 seconds, then put the cord back in and try to start it.
When you press the Power Button are you hearing the fans run, the disk drive running, the cd drive click and the light on it comes on for a second or two?
Anything shows up on the LCD Screen?
If you press the power button and absolutely nothing is happening then you most likely have a bad power supply.
If you press the power button and you start hearing beep sounds or blinking lights in a continuous pattern (ex. 1 long followed by 2 short) then you have a motherboard issue. Those beep sounds and blinking lights tells the technician what is going on with the computer.
Mar 23, 2012 | Dell Dimension 4600 PC Desktop
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
Set is getting power, but no sound or picture. we purchased it black friday
Power supply issue such as bad caps etc. But need the model number of the set in order to assist further.
Feb 08, 2012 | Hisense Televison & Video
TV won't turn on, red light flashes on TV and hear a clicking sound in back of unit is it worth fixing?
Yes,the LED power lite on the front panel stable?Yes,mean the DM power supply board is good.LED power like blinking,mean the DM power supply board is dead.DM power supply is good,still making that clicking sound,when turn on.Mean ur Blast board is dead,that the board that help to light up the projection lamp.
Jun 24, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Digi002 interface not powering on
I just talked to Digidesign and apparently this is a problem with the DC power harness.  You can call them and they will send you a replacement harness at no cost, since it is a repair and a known issue.  Basically I was told that the problem was due to oxidation on the power contacts.  The oxidation prevents the unit from having constant power.  The clicking you hear are the relays going through the initial power sequence multiple times as they get power and then lose it again. In theory you could fix the problem temporarily with some contact cleaner.  They will be sending me a a package with the new (and improved) harness, instructions and contact cleaner.  I am assuming this will fix the problem once I get the chance to swap the harness myself.
Nov 22, 2008 | Digidesign Digi 002 Rack FireWire Pro...
Compaq (176763001) 120-Watt Power Supply Logo
102 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
