Re: how do i sync my laptop to my HP IpaQ hand held
You have to use a driver to connect then a software to mediate with your ipaq and your laptop so u use bluetooth or uab cable as a connector and try to get the software and driver downloaded from the hp support site
you are now using outlook 2003 , probably cache , this means all the email is on your laptop. when you sync it will sync all the email (thousands). initialise your ppc (back to factory default). set up the sync via usb cable. then sync via bluetooth . then you are fully sync. now setup an auto backup of your email data (daily). if after some time , you have sync problem again , initialise the ppc, restore from backup and you are back to sync (last full backup). try this , you will never need to do it all again. Regards David Ng
just install itunes and you can sync calendar and contact to your iphone. You cannot sync the notes and tasks but. I have just bought an iphone and before I was using an HP ipaq like you. Everything is synced except for the notes and tasks. You cannot even see any word or excel files you had on your ipaq. Cheers
i would need more info to assist you. How long has this been happening? Has anything changed, either on the PDA or Laptop since this started? any more info would help.
The Microsoft Windows Mobile Device Center requires that the first sync be made via the USB sync cable. After the h4150 is plugged into the Vista machine, the WMDC opens and prompts you through setting up a partnership. Then you can set the h4150 to sync via Bluetooth.
ActiveSync works fine with Vista. Ignore that other guys post.
This could be due to a few issues, try these soloutions in order below:
1) If you have a jacket connected to the ipaq it could be preventing the ipaq from locating correctly on the connector. Remove jacket and try insering again.
2) Check that active sync is set up to detect the device on the usb port. The cradle for the ipaq may have a serial and usb connector. Ensure that just the usb connector is attached to your laptop. Try connecting again.
3) You may need to uninstall the USB cradle if it was connected before installing active sync. Try the following steps if this was the case:
a) unplug the USB cradle
b) uninstall active sync
c)Click start then click control pannel then click system. Then click on the hardware tab.
Look for the device under USB, right click on the device and then select uninstall.
d) restart the laptop
e) Install active sync
f) ONLY after active sync has installed you can now plug the cradle back into the usb socket.
g) Now connect the ipaq, it should now detect it.
What model is your iPaq? What version of software does it have?
