Question about Siemens Computers & Internet
My laptop is making a grating noise when i turn it on and also when it has been on for a while. The throttle button seems to stop it but i don't know if thats damaging my laptop more
    Sergeant:
  • 458 Answers
What is a throttle button? Is that on a joystick?
Sounds like your hard drive is going out or a CD is in the CD-ROM drive. It could be a fan going bad. You need to take that to someone and let them hear it. A shop should not charge you to listen to it. What kind of Laptop comes with a throttle? Is this in an Airplane?
Posted on Jun 04, 2008
Problem with my Acer 5740
sounds like you need to replace battery,,its sounds like the fan is making the noise clean the fan.
did your laptop get wet at anytime?if so that would stop keys working.
check to make sure all drivers are in and turnd on.
and check to make sure all programs are upto date.
May 30, 2014 | Acer Aspire 5740-6025 Notebook
2008 Element. Runs like a charm, just had its BIG tuneup done this spring (tires, timing belt, etc). Makes a VERY intermittent high-pitched whine. Doesn't seem connected to anything-not just when cold,...
still bad? doing old zero answer posts. (my bag)
finding noise is hard, and takes skills and can be dangerous.
my guess ????? it makes noise only moving.????
only clue is front, and presume outside of car and not under dash.
if car makes noise moving only, it can be dangerous , driving or even trouble shooting.
does it make noise in turns, or bumps,or loads (hills) or in all gears. or down hill, or coasting.?????
when it starts, does letting of throttle stop it, or more throttle>
or down shifting.? or cutting throttle and shifting to neutral.
I added many check to Doesn't seem connected to anything
my guess is the whine will progress to full time, many times this is true.
good FSM cover noise, here is more.
(tools can do wonders.)
http://www.fixkick.com/NOISE.html
Sep 10, 2013 | Honda Element Cars & Trucks
Car surging at idle, and making humming noise.
I can relate my experience with a similar noise on my 1994 car with Traction control. A electric valve in the air intake made a "Hum" or "Buzzing" noise when malfunctioning. For my car, the valve was suppose to reduce engine RPM so the wheel spin was stopped by choking off the air to the engine.
So the electric valve on your engine may be getting a bad signal from the Traction control system especially since you are not applying power. Or simply the electric contacts in the part you mention are worn out and "buzzing" because the contact points are burned out and can not connect.
Jul 05, 2013 | 2003 Ford Explorer
Hi there! Until 2 weeks ago my Samsung was working fine! I think its an older model then the SM710MP but they look the same. After two weeks holiday, when I tried to turn it on from the switch button on...
Yes,the tv have a power supply board have problems and slowly dying.U have all the tools and u understanding basic electronic and also can do basic soldering work too.Yes,check the tv power supply board carefully for dying and leaking capacitors parts.These capacitors parts will bulges up on to it tops or puffing onto it tops,all these capacitors parts must have to be replaced will solved this problems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Sep 02, 2011 | Samsung SyncMaster 710MP 17 in. LCD...
HI, my coolermaster laptop cooler, the U2 with 2 optional fans have been acting loud. only one fan has been acting up. it makes loud noises while the other one is silent. like a grating noise kind of. cant...
Sounds like the fan is going out. I would take it back to the store and swap it for a new one. Alternatively, if you decide to keep it you can try to put a drop of 3-in1 oil in the center of the fan to prolong and/or fix the noisy fan.
May 26, 2011 | Cooler Master NotePal U2 Notebook Cooler ...
SINCE 50,000k's I have experienced what feels like a slack cv-joint (vw aust showed little interest in solving the issue) - now at 160,000k's it's really uncomfortable on and off the throttle in traffic....
Usually when the CV axles start going out they will make a clicking noise when turning sharply in one direction or another. If you hear the noise while turning left, most likely the left axle, same for the reverse. Sorry, I don't know how many that particular vehicle has.
Oct 26, 2009 | 2001 Volkswagen Jetta TDI
No coffee is coming out of the machine...
in our machine we wanted a stronger coffee so we adjusted the auto grinder (where the coffee beans are housed) to the finest setting thinking the finer the grind the stronger the coffee...after doing this the machine wouldnot make coffee...we sent it away while still under warranty and the tech said that the grind selection was too low so they just turned the grinder back up a notch and it worked fine ....dont know if this will help but it's worth a try!
Mar 26, 2009 | Krups Orchestro Dialog FNF2 Espresso...
Computers & Internet Logo
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
